Author Topic: Opening Drawings using LISP  (Read 12131 times)
Re: Opening Drawings using LISP
« Reply #15 on: June 10, 2009, 03:11:21 PM »
No real reason to close the OBDX document.  ' Save ' doesn't work, the method, so you have to use ' SaveAs '.  So just use ' SaveAs ' after you have added your circle.
« Reply #16 on: June 10, 2009, 03:17:39 PM »
So in my code something like:
(vla-saveas dbx dwg)
I see you mention that you don't have to close the ODBX drawing... Even though I am using vla-open, is the drawing actually opened in this process?
« Reply #17 on: June 10, 2009, 03:19:18 PM »
Tim, it worked! Your a genius  8-)
« Reply #18 on: June 10, 2009, 04:15:15 PM »
Good to hear, and you're welcome.  Not sure about the genius part though.   :wink:
When you release the ODBX variable, it will close the connection with the application.  The way I think of ODBX is, it is an autocad drawing reader/editor that only functions in single document mode, so when you open one the other one will close.  You can have more that one application of ODBX open, but they can all only have one drawing open at a time.  Hope that makes sense.
« Reply #19 on: June 10, 2009, 04:23:50 PM »
I think I understand - thanks  :-)
By the way, currently, I am performing my (vlax-release-object)'s at the end of my code (using a sub-routine ObjRel), and also in my Error Handler, but is it better to release the object as soon as I am finished with it? (like in the Directory Browser part for example). Or does it make no difference?
Thanks for your continued help Tim, it is appreciated - I am learning a ton today  :lol:
Lee
« Reply #20 on: June 10, 2009, 04:49:34 PM »
Most people I think would say to release as soon as your done with it.  This will just free up memory, as the computer doesn't have to hold pointers to said objects within memory.  When you start doing code that does more, and is more time consuming, then you might want to release objects as soon as you're done with them.
You're welcome.  If you're here to learn, then there are people here willing to teach.  That's why I'm here.  To learn.
« Reply #21 on: June 10, 2009, 06:53:19 PM »
Ok, thanks for your advice Tim.   :-)
I hope I am not over-stepping the mark with all my questions, but I do have another:
I need to carry variables between document namespaces, would it be better to use functions such as: vl-bb-set, and vl-bb-ref or rather vl-propagate?
And, if using vl-bb-set/ref, is there a function you have to use to "wipe the blackboard clean" when finished?
Thanks as always,
Lee
« Reply #22 on: June 10, 2009, 07:13:20 PM »
I use ' vl-propagate '.  I think it is just personal preference.
As long as you're willing to do the work, then I'm sure most here will be willing to answer a few questions.  :-)
« Reply #23 on: June 10, 2009, 07:23:42 PM »
OK, I have been experimenting with the blackboard functions - but may have to resort to vl-propagate if I cannot get this working...
Below is the code I have been working on (don't laugh  :-P ) - it is designed to Extract all attributes from a list of drawings, based on a user-specified block list.
I am trying to collect all the information that I need, before attempting to write it to Excel (I realise that there exists EATTEXT, but this is also a learning exercise more than anything...)
Ok, I have highlighted the part I am struggline with:
;;; ================= Global Attribute Extractor =================
;;;                        by Lee McDonnell
;;;    FUNCTION: MacAtt
;;;    Will Retrieve all Attributes from Blocks in a user
;;;    compiled list from Multiple Drawings in a Selected
;;;    Directory.
;;;    AUTHOR:
;;;    Lee McDonnell  (Copyright (c) June 2009)
;;;    (Contact Lee Mac, CADTutor.net, TheSwamp.org)
;;;    ADDITIONAL THANKS TO:
;;;    Tony Tanzillo
;;;    Tim Willey
;;;    VERSION:
;;;    1.0  ~  11.06.2009  ~ First Release
(defun c:MacAtt (/ *error* *acad ExFlag BlkLst
                   Shell fDir Dir dbx acVer ss attLst)
  ;; Error Handler
  (defun *error* (e)
    (if ov (mapcar 'setvar vl ov))
    (ObjRel (list Shell dbx *acad))
    (if (not (wcmatch (strcase e) "*CANCEL*,*EXIT*"))
      (princ (strcat "\n<< Error: " e " >>")))
    (princ))
  ;; Get Block List
  (while (not ExFlag)
    (setq Str (getstring t "\nAdd Block Name to List [Space to View List]: "))
    (cond ((eq "" Str)
           (setq ExFlag T))
          ((eq (chr 32) Str)
           (foreach x (reverse BlkLst)
             (print x)) (textscr))
          ((snvalid Str)
           (setq BlkLst (cons Str BlkLst)))
          (t (princ "\n** Invalid Block Name **"))))
  (if BlkLst
  ;; Get Directory
  (setq *acad (vlax-get-acad-object)
        Shell (vla-getInterfaceObject *acad "Shell.Application")
        fDir (vlax-invoke-method Shell 'BrowseForFolder
               (vla-get-HWND *acad) "Select Directory: " 0))
  (if fDir
      (setq Dir
        (vlax-get-property
          (vlax-get-property fDir 'Self) 'Path))
      (if (not (eq "\\" (substr Dir (strlen Dir))))
        (setq Dir (strcat Dir "\\")))
      (if (< (atoi (setq acVer (substr (getvar "ACADVER") 1 2))) 16)
        (setq acVer "") (setq acVer (strcat (chr 46) acVer)))
      (setq dbx (vla-getInterfaceObject
                  *acad (strcat "ObjectDBX.AxDbDocument" acVer)))
      (princ "\nProcessing...")
      ;; Iterate Drawings
     [color=red] (foreach dwg (setq dwLst
                     (mapcar
                       (function
                         (lambda (x)
                           (strcat Dir x)))
                       (vl-directory-files Dir "*.dwg" 1)))
        (vla-open dbx dwg)
        (setq attlst (vl-bb-ref 'attlst))
        (foreach blk BlkLst
          (if (setq ss
                (ssget "_X" (list
                              (cons 0 "INSERT")
                              (cons 2 blk)
                              (cons 66 1))))
              (foreach att (mapcar
                             (function
                               (lambda (x)
                                 (vlax-safearray->list
                                   (vlax-variant-value
                                     (vla-getAttributes x)))))
                             (mapcar 'vlax-ename->vla-object
                                     (mapcar 'cadr (ssnamex ss))))
                (setq attLst
                  (cons (list (vla-get-TagString att)
                              (vla-get-TextString att)) attLst)))
              (setq attLst (cons blk attLst)))))
        (setq attLst (cons dwg attLst))
        (vl-bb-set 'attlst attlst)
        (princ (chr 46)))[/color]
      (alert (vl-princ-to-string (vl-bb-ref 'attlst)))
      (princ (strcat "\n<< " (rtos (length dwLst) 2 0) " Drawings Processed >>")))
    (princ "*Cancel*"))))
  ;; Garbage Collection
  (gc)
  (princ))
;; Release Objects ~ Requires List of Variables
(defun ObjRel (lst)
  (mapcar
    (function
      (lambda (x)
        (if (and (eq (type x) 'VLA-OBJECT)
                 (not (vlax-object-released-p x)))
          (vl-catch-all-apply
            'vlax-release-object (list x))))) lst))
I have tried to set the "data-list" to the blackboard namespace and then collect this during with the opening of every drawing. - But at the end, when I check the value of the blackboard variable (using "alert"), it only contains the drawing filenames, and no attribute information.
This leads me to believe that the error is not in the blackboard entry, but in the selection set collection. Perhaps one cannot collect a selection set in another document space?
Thanks for any input - as I say, I am new to this branch of LISP if some of my questions seem naive.
Thanks,
Lee
« Reply #24 on: June 10, 2009, 07:37:39 PM »
If you're using Odbx, then there is no need to use the backboard, or vl-propagate.  When using Odbx, you can only use ActiveX type code, so selection sets are out, but you can step though the drawing without it, and be about the same speed.
This shows how to get the attribute information from the blocks ( named within a list ) through only ActiveX controls.
Doc = valid document object
BlkNameList = list containing the name of blocks to get attributes from
AttList = will list the attributes in (tag . text) fashion
Hope it helps.
(vlax-for Lo (vla-get-Layouts Doc)
    (vlax-for Obj (vla-get-Block Lo)
            (and
                (= (vla-get-ObjectName Obj) "AcDbBlockReference")
                (vl-position (vla-get-Name Obj) BlkNameList)
            (foreach Att (append (vlax-invoke Obj 'GetAttributes) (vlax-invoke Obj 'GetConstantAttributes))
                (setq AttList (cons (cons (vla-get-TagString Att) (vla-get-TextString Att)) AttList))
I'm out for the rest of the day.  Have fun.   :wink:
« Reply #25 on: June 10, 2009, 07:55:06 PM »
Many thanks for your help Tim - I am very grateful.
I shall look over your code and see what I can do  :wink:
