Author Topic: remove elements from a list with identifier of sub-list (recursive)  (Read 11461 times)
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
Re: remove elements from a list with identifier of sub-list (recursive)
« Reply #45 on: June 09, 2009, 05:53:51 PM »
well were you expecting anything else? ...try using foreach instead and you will really smoke us.
MP, quick question; I never quite understood what "relative speed for ... iteration(s):" meant? Is that the time per call?
Means that (NODOUPS BLAH) is 22.5 times faster than   (DOIT BLAH)
ie  1031:23203
Called Kerry in my other life
I live at UTC + 13.00
« Reply #46 on: June 09, 2009, 06:01:46 PM »
I'm pretty sure WHILE is faster than FOREACH.
In my test gile's was faster. :-o
gile
  • Marseille, France
« Reply #47 on: June 09, 2009, 06:04:32 PM »
If non recursive functions are allowed, here's mine
(defun gile2 (lst / item tmp result)
  (while lst
    (if (numberp (setq item (car lst)))
      (if (not (vl-position item tmp))
(setq tmp (cons item tmp))
      (setq result (append tmp result)
    tmp    (list item)
    (setq lst (cdr lst))
  (reverse (append tmp result))
« Reply #48 on: June 09, 2009, 06:16:04 PM »
Nice Gile.
My results.
   (GILE2 LST)............................1592 / 2.15 <fastest>
    (GILE LST).............................1632 / 2.09
    (NODOUPS LST)..........................1683 / 2.03
    (MP_FOO LST)...........................2504 / 1.36
    (REMOVE_DUPS_IN-BETWEEN-CHARS LST).....3415 / 1.00 <slowest>
Not sure why my test are different.
« Reply #49 on: June 09, 2009, 06:18:02 PM »
<Naive Question>:
Do you all have the same LISP to test the speed of these things?
« Reply #50 on: June 09, 2009, 06:19:28 PM »
Everyone except KB.  :-D
uncoolperson
« Reply #52 on: June 09, 2009, 07:16:01 PM »
ie  1031:23203
Ah, i see it. That makes total sense now that you put it that way...thanx!
kdub_nz
  • SuperMod
« Reply #54 on: June 09, 2009, 07:29:06 PM »
Yep :)
I have mine calculating the  fastest as base 1 unit, and all athers with a higher relative index representing how much longer it takes to run..
ie if the fastest is 1 and the slowest is 12.6 you know it takes 12.6 times as long to run
but that's just me :)
« Reply #55 on: June 09, 2009, 09:20:29 PM »
That sounds more logical, is that posted anywhere KB?
kdub_nz
  • SuperMod
« Reply #56 on: June 09, 2009, 09:50:25 PM »
                 ;;  Output:
                 ;;      Elapsed milliseconds / relative speed for 32768 iteration(s):
                 ;;    (+ 1 1.0).......1452 / 1.1152 <slowest>
                 ;;    (+ 1.0 1.0).....1412 / 1.0845
                 ;;    (+ 1 1).........1332 / 1.023
                 ;;    (1+ 1)..........1302 / 1 <fastest>
                 ;; Mods by KWB 2005 to display the smallest time with the smallest ratio
I've also modified this .. which [you] may want to revert to the original
  (defun _main
         (statements / boundary iterations timings slowest fastest lsetlen rsetlen index count)
    (setq boundary 500 ; originally 1000 [kwb]
          iterations 1
;; < ... big snip ...  >
« Reply #57 on: June 09, 2009, 10:17:54 PM »
Doesn't to me. I think in terms of "Function A is x times faster than function B". Guess that makes me weird. :ugly:
uncoolperson
« Reply #58 on: June 09, 2009, 11:36:34 PM »
yeah... only that
« Reply #59 on: June 10, 2009, 08:47:34 AM »
Sorry, I didnt mean that statement as an insult.
*lol*
