Author Topic: Divide List  (Read 5176 times)
Re: Divide List
« Reply #15 on: June 06, 2009, 03:43:57 PM »
Michael, could the speed not be improved by adding a simple:
(DivideList
           '(1 2 3 4 5 6 7 8 9)
           [color=red](function[/color] (lambda (x) (zerop (rem x 3))))
Significantly:
Elapsed milliseconds / relative speed for 16384 iteration(s):
    (_SUBDIVIDE (QUOTE (1 2 3 4 5 6 7 8 ...).....1466 / 1.16 <fastest>
    (DIVIDELIST (QUOTE (1 2 3 4 5 6 7 8 ...).....1700 / 1.00 <slowest> [color=green];; (function (lambda ...)) form[/color]
Still prefer the non quoted form myself. :)
Re: Divide List
« Reply #16 on: June 06, 2009, 07:49:50 PM »
I only mentioned it 'cause I saw VovKa say a bit about using it in another thread on here...   ^-^
Re: Divide List
« Reply #17 on: June 08, 2009, 09:20:03 AM »
VovKa
  • Ukraine
Re: Divide List
« Reply #18 on: June 08, 2009, 04:50:23 PM »
someone needs a recursion?
(defun test (lst fun)
  (if lst
    ((lambda (rest)
       (if (fun (car lst))
(list (cons (car lst) (car rest)) (cadr rest))
(list (car rest) (cons (car lst) (cadr rest)))
      (test (cdr lst) fun)
    '(nil nil)
;;;(test '(1 2 3 4 5 6 7 8 9) (lambda (x) (zerop (rem x 3))))
WARNING!
It is slow...
Re: Divide List
« Reply #19 on: June 08, 2009, 06:59:14 PM »
I'm not sure if I am correct in my thinking, but I always try to limit my use of recursive methods to very small tasks, like, for example (something I got from Gile a think...):
(defun lst->pt (lst)
  (if lst
    (cons (list (car lst) (cadr lst) (caddr lst))
          (lst->pt (cdddr lst)))))
As I've heard that recursive methods have a limit that is the stack memory.
