Here's some code from 1992-94. I've used it faithfully for a long time. I did however comment out the time date stuff as I thought a bit superfluous 'cause I have a clock on my desk.
;LDTOPS.LSP
;10/20/92 - Patrick Murphy, Applied Computing Services.
;12/08/94 - Corrected the date endings, finally.
; Filename added to status line.
;Added C:RDA command as a bonus program, at bottom of file.
;Program to set MODEMACRO to show:
;the current Layer, DrawingName, Date, Time, Tablet, Ortho, Pspace and Snap.
;E.G.: TEXT C:\ACAD\DWGNAME Tue Oct 20th 7:35p T Ortho P Snap
;I modified the MODE1.LSP file found in on page 120 and code on page 126
;of the AutoCAD R12 Customization Manual to arrive at this.
;Have this code loaded by the ACAD.LSP file and run with S::STARTUP.
;Once run, you can have it set to NIL later in S::STARTUP and free up
;a little memory.
;i.e. in your ACAD.LSP file:
; (load "ldtops") ;When ACAD.LSP loads, so would LDTOPS.LSP
; ;if there isn't an S:STARTUP function already, you could use this:
; (defun S::STARTUP ()
; (ldtops) ;this would run LDTOPS
; (setq ldtops nil) ;this would free up a little memory -
; ) ;because MODEMACRO would already be set.
;----------------------------------------------------------------(ldtops)
(defun ldtops (/ daysfx dtst)
(setvar "CMDECHO" 0)
(setq daysfx (substr (rtos (getvar "CDATE") 2 4) 7 2)
dtst daysfx
daysfx
((= "11" daysfx) "th");determine the day suffix
((= "12" daysfx) "th")
((= "13" daysfx) "th")
((= "21" daysfx) "st")
((= "22" daysfx) "nd")
((= "23" daysfx) "rd")
((= "31" daysfx) "st")
((= "01" daysfx) "st")
((= "02" daysfx) "nd")
((= "03" daysfx) "rd")
(T "th")))
(setvar "modemacro"
(strcat
"$(substr,$(getvar,clayer),1,8)"
"$(substr, ,1,$(-,8,$(strlen,$(getvar,clayer)))) "
"$(getvar,dwgname)"
; "$(edtime,$(getvar,date), "
; " " ;Had to call EDTIME twice because
; "DDD MON D)" ;I wanted the suffix for the day
; daysfx ;(i.e. 'st') and if EDTIME was only
; "$(edtime,$(getvar,date), " ;called once the suffix became one
; "H:MMam/pm)" ;of the EDTIME parameters, rather
" " ;than text on the status line.
; "$(if,$(getvar,tabmode), T, )"
"$(if,$(and,$(=,$(getvar,tilemode),0),$(=,$(getvar,cvport),1)), P, M)"
"$(if,$(getvar,orthomode), Ortho, )"
"$(if,$(getvar,snapmode), Snap)"
"$(getvar,cmdnames)"
);defun LDTOPS
-David
