Author Topic: Updating time on the status bar (modemacro command)  (Read 6391 times)
Dommy2Hotty
« on: October 26, 2004, 01:34:33 PM »
I wanted to put an updating time with the date in the status bar using the modemacro command.  I can get it to put the current date by using (getvar "cdate"), although I don't know how to format it.  How could I get it to update the time (if possible)?
daron
« Reply #1 on: October 26, 2004, 01:36:30 PM »
look into strcat.
« Reply #2 on: October 26, 2004, 01:49:13 PM »
Look up DIESEL.
whdjr
« Reply #3 on: October 26, 2004, 01:54:43 PM »
How about recursion with a timer?
daron
« Reply #4 on: October 26, 2004, 01:55:35 PM »
I wonder if that would begin to slow his computer down.
David Bethel
« Reply #5 on: October 26, 2004, 01:58:20 PM »
Here's some code from 1992-94.  I've used it faithfully for a long time.  I did however comment out the time date stuff as I thought a bit superfluous 'cause I have a clock on my desk.
;LDTOPS.LSP
;10/20/92  - Patrick Murphy, Applied Computing Services.
;12/08/94  - Corrected the date endings, finally.
;            Filename added to status line.
;Added C:RDA command as a bonus program, at bottom of file.
;Program to set MODEMACRO to show:
;the current Layer, DrawingName, Date, Time, Tablet, Ortho, Pspace and Snap.
;E.G.:  TEXT     C:\ACAD\DWGNAME Tue Oct 20th 7:35p   T Ortho P Snap
;I modified the MODE1.LSP file found in on page 120 and code on page 126
;of the AutoCAD R12 Customization Manual to arrive at this.
;Have this code loaded by the ACAD.LSP file and run with S::STARTUP.
;Once run, you can have it set to NIL later in S::STARTUP and free up
;a little memory.
;i.e. in your ACAD.LSP file:
;  (load "ldtops")     ;When ACAD.LSP loads, so would LDTOPS.LSP
;  ;if there isn't an S:STARTUP function already, you could use this:
;  (defun S::STARTUP ()
;   (ldtops)          ;this would run LDTOPS
;   (setq ldtops nil) ;this would free up a little memory -
;  )                  ;because MODEMACRO would already be set.
;----------------------------------------------------------------(ldtops)
(defun ldtops (/ daysfx dtst)
 (setvar "CMDECHO" 0)
 (setq daysfx (substr (rtos (getvar "CDATE") 2 4) 7 2)
  dtst daysfx
  daysfx
  ((= "11" daysfx) "th");determine the day suffix
  ((= "12" daysfx) "th")
  ((= "13" daysfx) "th")
  ((= "21" daysfx) "st")
  ((= "22" daysfx) "nd")
  ((= "23" daysfx) "rd")
  ((= "31" daysfx) "st")
  ((= "01" daysfx) "st")
  ((= "02" daysfx) "nd")
  ((= "03" daysfx) "rd")
  (T "th")))
  (setvar "modemacro"
   (strcat
   "$(substr,$(getvar,clayer),1,8)"
   "$(substr,        ,1,$(-,8,$(strlen,$(getvar,clayer)))) "
   "$(getvar,dwgname)"
 ;   "$(edtime,$(getvar,date), "
 ;  " "                         ;Had to call EDTIME twice because
 ;  "DDD MON D)"                ;I wanted the suffix for the day
 ;  daysfx                      ;(i.e. 'st') and if EDTIME was only
 ;  "$(edtime,$(getvar,date), " ;called once the suffix became one
 ;  "H:MMam/pm)"                ;of the EDTIME parameters, rather
   "  "                        ;than text on the status line.
 ;  "$(if,$(getvar,tabmode), T, )"
   "$(if,$(and,$(=,$(getvar,tilemode),0),$(=,$(getvar,cvport),1)), P, M)"
   "$(if,$(getvar,orthomode), Ortho, )"
   "$(if,$(getvar,snapmode), Snap)"
   "$(getvar,cmdnames)"
);defun LDTOPS
-David
R12 Dos - A2K
whdjr
« Reply #6 on: October 26, 2004, 01:58:42 PM »
It would probably be like a memory leak.
 :twisted:
« Reply #7 on: October 26, 2004, 03:12:42 PM »
Observation
Are not needed
« Reply #8 on: October 26, 2004, 03:32:46 PM »
You can readily do this in VBA if you would like I can post the entire code to do such a thing. I can also compile it into an executable that you run after you start AutoCAD and it will run in the background updating the time as needed... but it would be a lot more coding to make happen.
Dommy2Hotty
« Reply #9 on: October 26, 2004, 03:48:18 PM »
Thank you all for replies and suggestions...I think I'll just have it put our company name and the date...no time...I'll look up how to format the date and see if I can get it to work.  Thanks again! :twisted:
« Reply #10 on: October 26, 2004, 04:10:26 PM »
I have code to change the AutoCAD window name (not just the status bar) to whatever you want. You can put your company name there of you want.
Dommy2Hotty
« Reply #11 on: October 26, 2004, 06:02:54 PM »
Quote from: Keith
Ooh...me like!...gimme! gimme! gimme! :twisted:
« Reply #12 on: October 26, 2004, 08:23:53 PM »
Ok ... this is a VBA app so ....
In a new module paste the following code
Declare Function SetWindowText Lib "user32" Alias "SetWindowTextA" (ByVal HWND As Long, ByVal lpString As String) As Long
Sub SetText()
 Dim RetVal As Long
 RetVal = SetWindowText(Application.HWND, Interaction.InputBox("Please enter new name for AutoCAD application"))
End Sub
When you run the code it will request a new name which you can type in, then it will change the name to what you entered.
If you want to make it set to a preset value, simply remove this portion
and replace it with a string enclosed in quotes.. like so...
Sub SetText()
 Dim RetVal As Long
 RetVal = SetWindowText(Application.HWND, "Dommy2HottyCAD"))
End Sub
Dommy2Hotty
« Reply #13 on: November 08, 2004, 06:03:43 PM »
Thanks Keith...works like a charm!
« Reply #14 on: November 09, 2004, 08:36:35 AM »
Glad you like ... I also have one to change the Icon ...
