Author Topic: Compare 2 list  (Read 4672 times)
m4rdy
Compare 2 list
« on: June 04, 2009, 09:30:01 AM »
I have 2 lists.
1. (nil nil T T T nil T)
2. (1 3 7 11 5 6 4)
What i want is :
list (1 3 6)
Thank you.
Autocad 2007, Windows XP
Re: Compare 2 list
« Reply #1 on: June 04, 2009, 09:48:50 AM »
Perhaps something like this ..
(setq L1 '(nil nil T T T nil T))
(setq L2 '(1 3 7 11 5 6 4))
(setq L3 '() )
;; assume the data lists are the same length
(setq  index 0)
(foreach item L1
   (if (not item)
       (setq L3 (cons  (nth index L2) L3))
   (setq index (1+ index))
(setq L3 (reverse L3))
(alert (VL-PRINC-TO-STRING L3))
m4rdy
Re: Compare 2 list
« Reply #2 on: June 04, 2009, 09:56:53 AM »
Thank you for your reply Kerry, It works.
One more thing, what about if I want to use with mapcar or vl-remove (something like that).
Thank's again.
m4rdy
ElpanovEvgeniy
  • Moscow (Russia)
Re: Compare 2 list
« Reply #3 on: June 04, 2009, 10:08:59 AM »
(defun test (a b)
 (if a
  (if (null(car a))
   (cons (car b) (test (cdr a) (cdr b)))
  ) ;_  if
 ) ;_  if
Re: Compare 2 list
« Reply #4 on: June 04, 2009, 10:19:31 AM »
Great Solution ElpanovEvgeniy  - I doubt that'll be beaten for simplicity  :-)
m4rdy
Re: Compare 2 list
« Reply #5 on: June 04, 2009, 10:32:03 AM »
Thank you Evgeniy. It works also. I think this is enough for now. I will continue for learning Vlisp.
I think this is the best forum (for me) for studying & learning Vlisp.
Re: Compare 2 list
« Reply #6 on: June 04, 2009, 12:02:14 PM »
(setq l1 '(t nil nil t t nil)
      l2 '(1 2 3 4 5 6 7))
(defun test (l1 l2 / l3)
  (mapcar '(lambda(x y)(if x (setq l3 (cons y l3)))) l1 l2)
  (reverse l3)
(test l1 l2)
Note: if no matching t/nil assumes nil
« Last Edit: June 04, 2009, 02:14:21 PM by CAB »
gile
  • Marseille, France
Re: Compare 2 list
« Reply #7 on: June 04, 2009, 12:28:51 PM »
      l2 '(1 2 3 4 5 6 7)
(apply
  'append
  (mapcar
    '(lambda (x1 x2)
       (if (not x1)
(list x2)
    l1
    l2
Re: Compare 2 list
« Reply #8 on: June 04, 2009, 12:55:10 PM »
Unimaginative but trying to avoid replicating previous entries ---
(defun _DeleteItems ( items predicates )
    (vl-remove-if 'null
        (mapcar
           '(lambda (item predicate) (if (null predicate) item))
            items
            predicates
(_DeleteItems
   '(1 3 7 11 5 6 4)
=> (1 3 6)
Flaw: Will remove perfectly legit nil items if in original list. Small comfort: Not only solution that suffers from said malady.
Re: Compare 2 list
« Reply #9 on: June 04, 2009, 02:19:33 PM »
Mine will remove any item if the T/nil list is too short. It assumes nil. :-)
uncoolperson
Re: Compare 2 list
« Reply #10 on: June 04, 2009, 03:42:35 PM »
ain't good, fast, or pretty... but they were fun
four was the funnest
(defun one ()
  (setq list1 '(nil nil T T T nil T))
  (setq list2 '(1 3 7 11 5 6 4))
  (mapcar '(lambda (item) (cdr item))
 (vl-remove-if
   '(lambda (item
      (car item)
   (mapcar '(lambda (i1 i2) (cons i1 i2)) list1 list2)
(defun two ()
  (setq list4 nil)
  (setq list3 (mapcar '(lambda (i1 i2) (cons i1 i2)) list1 list2))
  (while (assoc nil list3)
    (setq list4 (cons (setq item (cdr (assoc nil list3))) list4))
    (setq list3 (subst (cons t item) (assoc nil list3) list3))
  (reverse list4)
(defun three ()
  (setq list3 nil)
  (setq len (length list1))
  (while (member nil list1)
    (setq list3
  (cons (nth (- (1- len)
(length (setq list1 (cdr (member nil list1))))
     list2
list3
  (reverse list3)
(defun four ()
  (setq list3 (mapcar '(lambda (item1 item2) (cons item1 item2)) list1 list2))
  (mapcar 'cdr
 (vl-sort (vl-member-if-not
    '(lambda (item) (car item))
    (vl-sort list3 '(lambda (item1 item2) (car item1)))
     (< (vl-position (cdr item1) list2)
(vl-position (cdr item2) list2)
« Last Edit: June 04, 2009, 06:13:58 PM by uncoolperson »
Spike Wilbury
Re: Compare 2 list
« Reply #11 on: June 04, 2009, 07:25:08 PM »
just want to participate....
(setq lst1 '(nil nil T T T nil T))
(setq lst2 '(1 3 7 11 5 6 4))
(setq lst nil)
(setq i 0)
(reverse (mapcar '(lambda (item)
    (if (not item)
      (setq lst (cons (nth i lst2) lst))
    (setq i (1+ i))
lst1
lst
_$
(1 3 7 11 5 6 4)
nil
0
(7 6 5 4 3 2 1)
(6 3 1)  <<<======
_$
an ex lisper....
Re: Compare 2 list
« Reply #12 on: June 04, 2009, 09:37:20 PM »
Luis, Don't you miss LISP. :-)
mkweaver
Re: Compare 2 list
« Reply #13 on: June 04, 2009, 11:35:38 PM »
Very similar to MP's
      l2 '(1 2 3 4 5 6 7)
(vl-remove-if 'null
  (mapcar
    (function
      (lambda(a b)
(if a b)
    l1 l2
Spike Wilbury
Re: Compare 2 list
« Reply #14 on: June 05, 2009, 10:00:03 AM »
some times :)
