Decided to try it in lisp and here's what i got so far. Still needs "clean up".
If in the model layout, it will close the active drawing and open the selected reference file with the same orientation/screen coords.
If in another layout, it will add the choice of switching to the model layout with the same orientation/screen coords.
Must be in model space (whether it's the model layout tab or an active viewport.)
Currently writes dcl and scr files to c:\temp. Suggestions are welcome.
Type XC to run.
[code;; NOTES:
;; The intent is similar to that of refedit
;; "xc" or "exchange" allows user to pick an xref to open and display the view/orientation of the current drawing.
;; If executed in a layout tab, option to exchange with Model Space is available
;; "sv" or "saveview" will capture view/orientation of current drawing
;; "gv" or "getview" will match view/orientation saved by "saveview" or "exchange" (only functions in modelspace)
;; Xref path found by using several functions by Joe Burke
;; Coordinates acquired by using VPCords by MP
(defun c:saveview()
(if (/= (getvar 'ctab) "Model")(vla-put-mspace (vla-get-ActiveDocument (vlax-get-Acad-Object)) :vlax-true))
(vl-cmdf "ucs" "v")
(setq *VLISP-NEW-FULL-INIT* (vpcords))
(if xlist
(setq *VLISP-NEW-FULL-INIT* (append *VLISP-NEW-FULL-INIT* xlist))
(setq *VLISP-NEW-FULL-INIT* (append *VLISP-NEW-FULL-INIT* (list (getvar 'ucsxdir))))
);defun
(defun c:sv()(c:saveview))
(defun c:getview()
(vl-cmdf "ucs" "w")
(vl-cmdf "ucs" "0,0")
(vl-cmdf (nth 2 *VLISP-NEW-FULL-INIT*) "")
(vl-cmdf "plan" "c")
(vl-cmdf "zoom" "window")
(vl-cmdf (nth 0 *VLISP-NEW-FULL-INIT*))
(vl-cmdf (nth 1 *VLISP-NEW-FULL-INIT*))
(vl-cmdf "ucs" "w")
);defun
(defun c:gv()(c:getview))
(defun VPCords (/ viewctr vphps vphms vpscale psvpctr difference psviewctr halfHeight aspectRatio offset)
(if (= (getvar 'ctab) "Model")
( (lambda (offset)
( (lambda (viewctr)
(list
(mapcar '- viewctr offset)
(mapcar '+ viewctr offset)
(getvar "viewctr") ;VPCords by MP
( (lambda (halfHeight aspectRatio)
(list
(* halfHeight aspectRatio)
halfHeight
(* 0.5 (getvar "viewsize"))
(apply '/ (getvar "screensize"))
);progn
(progn ;Acquired through VPCords-this version used to get model space coords while in a viewport
(setq viewctr (getvar "viewctr");Viewport Center in drawing units
vphps (cdr (assoc 41 (entget (acet-currentviewport-ename) '("ACAD"))))
vphms (getvar "viewsize")
vpscale (/ vphms vphps)
psvpctr (cdr (assoc 10 (entget (acet-currentviewport-ename) '("ACAD"))))
difference (mapcar (function (lambda (x y)(- y (* vpscale x)))) psvpctr viewctr)
xlist (list (getvar 'ucsxdir))
);setq
(vla-put-mspace (vla-get-ActiveDocument (vlax-get-Acad-Object)) :vlax-false)
(vl-cmdf "ucs" "w")
(setq psviewctr (mapcar (function (lambda (x y) (+ y (* vpscale x)))) (getvar "viewctr") difference)
halfHeight (* (* 0.5 (getvar "viewsize")) vpscale)
aspectRatio (apply '/ (getvar "screensize"))
offset (list (* halfHeight aspectRatio) halfheight)
(list (mapcar '- psviewctr offset)
(mapcar '+ psviewctr offset)
(defun c:switch (/ )
(if (and (= (getvar 'sdi) 1)(not Model))
(vl-cmdf
"_.vbastmt"
(strcat "AcadApplication.Documents.Open \"" xrefpath "\"")
);vl
);defun
(defun Is_ReadOnly (path / dwlfile x )
(setq dwlfile (vl-string-subst ".dwl" ".dwg" path))
(if (setq x (open dwlfile "r"))(progn (alert (strcat "The selected Xref is occupied by " (read-line x) ". Try again later."))(close x)(exit)))
(defun c:xc ()(c:exchange))
(defun c:exchange (/ blocks datalst cnt nestcnt doc xpathlst openscrfile file dwgpre dwglist *error* xrefpathlist
userclick xreflist BlkCol xrefinfo xrefselection xrefname xlist Model what)
(defun *error* ( msg )
((not msg))
((wcmatch (strcase msg) "*QUIT*,*CANCEL*"))
(T (princ (strcat "\nError: " msg)))
(setvar "cmdecho" 1)
);defun *error*
(if (and (/= (getvar 'ctab) "Model")(= (vla-get-mspace (vla-get-ActiveDocument (vlax-get-Acad-Object))) :vlax-false))(progn (alert "\nViewport must be active! Exiting XC.lsp... ")(exit)))
;; Argument: path string
;; Returns the path portion as a list of strings in reverse order.
;; (setq s "..\\..\\Common ABC\\XRefs ABC\\Plan Unit 3BR KLSC.dwg")
;; ("\\XRefs ABC" "\\Common ABC" "\\.." "\\..")
;; The file name is not included.
(defun PathList (str / idx pat pos lst)
(setq idx 0 pat "\\")
(while (setq pos (vl-string-search pat str idx))
(setq lst (cons (strcat pat (substr str (1+ idx) (- pos idx))) lst)
idx (1+ pos)
lst
) ;end
;; Returns a list of lists: (fullname fn blockname expath)
(defun XrefsData ( / blkname expath fullname fn xlst NestedXref)
;; Argument: block definition vla-object.
;; Returns a count number if the xref is nested, otherwise nil.
;; Based on code by Stephan Koster in a program named XrefTree.
;; Function renamed from nested_p.
;; The nestcnt variable is local to the primary routine.
;; There is a known flaw in the function which Jason pointed out.
;; If an xref is both nested and referenced as a parent, the
;; function does not flag it as nested. The fallout from that situation,
;; if it occurs, is handled near the end of the primary routine.
(defun NestedXref (blkdef / elst)
(setq elst (entget (vlax-vla-object->ename blkdef)))
(or
(not (vl-position '(102 . "{BLKREFS") elst))
(not (cdr (assoc 331 elst)))
(setq nestcnt (1+ nestcnt))
;; Else return nil to the parent function.
) ;end
(vlax-for x blocks
(= -1 (vlax-get x 'IsXref))
(setq blkname (vlax-get x 'Name))
;; Filter out nested xrefs.
(not (NestedXref x))
(setq expath (cdr (assoc 1 (tblsearch "block" blkname))))
(setq fn (strcat (vl-filename-base expath) ".dwg"))
;; Xref found at full or relative path.
((setq fullname (findfile expath)))
;; Xref found in the same folder as the active file
;; and it the xref has not been renamed.
((setq fullname (findfile fn)))
;; Xref not found so far. Substitute the path for full name.
(T (setq fullname expath))
(setq xlst (cons (list fullname fn blkname expath) xlst))
xlst
) ;end
(defun XrefSearch (strlst path dot / xpath)
(if (and strlst path dot)
(setq path (strcat "\\" path))
(while
strlst
(not (findfile (setq xpath (strcat dot
(substr (setq path (strcat (car strlst) path)) 2))))
(setq strlst (cdr strlst))
(setq dot (strcat dot dot))
(if (and xpath (findfile xpath))
xpath
) ;end
;;;; END SUB-FUNCTIONS ;;;;
;;;; START PRIMARY FUNCTION ;;;
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setvar "cmdecho" 0)
(setq blocks (vla-get-blocks doc)
cnt 0
nestcnt 0
datalst (XrefsData)
(foreach x datalst
(setq XrefList (append XrefList (list (caddr x))))
(setq xpathlst (append xpathlst (list (car x))))
(if XrefList (setq XrefList (acad_strlsort xreflist)))
(progn (initget "Reference Mspace")(setq what (getkword "\nExchange with [ Reference / Mspace] ?:<R> ")));progn
);if
(if (or (= what "Reference")(= what nil))
(if (/= (getvar 'ctab) "Model")(vla-put-mspace doc :vlax-true))
(setq xrefinfo (entget (car (entsel "\nSelect Xref to exchange with..."))))
(setq xrefselection (cdr (assoc 2 xrefinfo)))
(if (null xrefselection)(progn (alert "Selected object is not an xref.Try again.")(exit)))
(if Xpathlst (setq Xpathlst (acad_strlsort xpathlst)))
(foreach x xpathlst
(if (/= (vl-string-search xrefselection x) nil)(setq xrefpathlist (append xrefpathlist (list x))))
(setq xrefpath (nth 0 xrefpathlist))
(Is_Readonly xrefpath)
);if
(vl-cmdf "ucs" "v")
(if xlist
(if (= what "Mspace")(progn (setvar 'ctab "Model")(setq Model 1)(setq xrefpath 1)))
(progn (setq openscrfile (open (setq file (strcat "c:\\temp\\temp.scr")) "w")) ;derived from post by Ronjonp
(progn (foreach f (list xrefpath)
(if (and (= (getvar 'sdi) 0)(not Model))(write-line (strcat "_.open \"" f "\"") openscrfile))
(write-line "switch" openscrfile)
(if (and (= (getvar 'sdi) 1)(not Model))(write-line "Y" openscrfile))
(write-line "ucs w" openscrfile) ;
(write-line "ucs 0,0 (nth 2 *VLISP-NEW-FULL-INIT*) " openscrfile) ;
(write-line "plan c" openscrfile) ;
(write-line "zoom window" openscrfile) ;
(write-line "(nth 0 *VLISP-NEW-FULL-INIT*) (nth 1 *VLISP-NEW-FULL-INIT*)" openscrfile);
(close openscrfile)
(command ".script" file)
(vl-file-delete file)
);defun
replaced code
