Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
.NET
Topic:
Loading .NET .dll In Startup Suite??
« previous
next »
Print
Pages:
1
2
All
Go Down
Author
Topic: Loading .NET .dll In Startup Suite?? (Read 5729 times)
wannabe
Guest
Re: Loading .NET .dll In Startup Suite??
Reply #15 on:
June 02, 2009, 04:03:27 PM »
I've got it working at home....first time.
The setup at work is a bit obfuscating with all the customisation folders and the recent migration to a new I.T setup. I'll talk to the guys higher up and see what I can come up with.
So cheers for all the help. On my way now, cheers.
Logged
Mesozoic relic
Seagull
class keyThumper<T>:ILazy<T>
Reply #16 on:
June 03, 2009, 03:23:03 AM »
wannabe ,
just a thought .. are you netloading from a local drive or from a Network ??
I know your sample is from C:\\ .. BUT you posted that from home, yes ??
Logged
wannabe
Guest
Reply #17 on:
June 03, 2009, 05:54:58 AM »
It's been a local drive on each location.
I think the errors may have occured due to the fact we have the ACAD2008 and ACADDOC2008 as-well-as another ACAD.LSP and ACADDOC.LSP in our customisations folder.
I reset the latter 2 the original files, and just updated the ACAD2008.LSP as per the load in Sinc's last post that specified the .dll on a local drive.
When I get chance I'll add your original code to this file and see what the return is.
Cheers all.
Logged
sinc
Guest
Reply #18 on:
June 03, 2009, 10:13:58 AM »
You shouldn't modify ACAD2008.lsp or ACADDOC2008.lsp. Those should be left untouched, and you should always use the default files, because Autodesk may make important changes to those files in service pack updates.
Logged
wannabe
Guest
Reply #19 on:
June 03, 2009, 11:14:25 AM »
Thanks. Lesson learnt and error rectified.
Logged
Print
Pages:
1
2
All
Go Up
« previous
next »
TheSwamp
Code Red
.NET
Topic:
