Author Topic: Loading .NET .dll In Startup Suite??  (Read 5693 times)
wannabe
« on: June 01, 2009, 02:21:11 PM »
Hi Everyone,
I'm just inquiring about the range of possibilities for auto-loading a .NET .dll when CAD starts up, potentially via a start up script, maybe?
This month's blog from Kean includes how to update the registry; I doubt this would apply to where I work with I.T permissions etc. Although I do plan to converse with the group CAD manager, and the CADD systems Manager to see if it would be possible.
However, I think for the time-being, just being able to load via  a start-up script would suffice for the one or two commands that are used frequently.
Any suggestions or ideas swampers currently implement?
gile
  • Marseille, France
Re: Loading .NET .dll In Startup Suite??
« Reply #1 on: June 01, 2009, 02:31:59 PM »
You can call the command LISP function in the S::STARTUP function
(defun-q S::STARUP () (command "_.netload" "MyLibrary.dll") (princ))
If you have yet a S::STARTUP function (defined with defun-q) in your acad.lsp or acaddoc.lsp or MNL file, you can append the (command "_.netload" ...) expressions.
(setq S::STARTUP (append S::STARTUP '((command "_.netload" "MyLibrary.dll") (princ))))
wannabe
« Reply #2 on: June 01, 2009, 02:39:17 PM »
Thanks for the riposte. I'll let you know how I get on and express further gratitude sometime tomorrow.
wannabe
« Reply #3 on: June 02, 2009, 03:28:01 AM »
My ACAD2008.LSP file now appears as follows:
(if (not (=  (substr (ver) 1 11) "Visual LISP")) (load "acad2008doc.lsp"))
;; Silent load.
(defun-q S::STARUP () (command "_.netload" "C:\Documents and Settings\39925NT\My Documents\Nick's CAD\CAD Dev\C#\dotNet Code\2.0 Files\PolyDist\CurveQuery\CurveQuery.dll") (princ))
However, my command is not being recognised.
I also tried the following:
(setq S::STARTUP (append S::STARTUP '((command "_.netload" "C:\Documents and Settings\39925NT\My Documents\Nick's CAD\CAD Dev\C#\dotNet Code\2.0 Files\PolyDist\CurveQuery\CurveQuery.dll") (princ))))
Also to no avail.
Can  you give me a slight nudge in the right direction, please? :-)
« Reply #4 on: June 02, 2009, 04:37:43 AM »
What happens if you change the folder delineators to \\ in place of \  ??
« Reply #5 on: June 02, 2009, 04:46:59 AM »
perhaps try something like this ..
(defun kdub_startup ()
    (load "C:/PROG/LISP/MyStuff.LSP")
    (Command "_.netload"  "C:\\whatever\\kdub\\MyStuff.dll")
(if s::startup
    (setq s::startup (append s::startup (quote ((kdub_startup)))))
   ;; (defun s::startup () (kdub_startup))
    (defun-q s::startup () (kdub_startup) (princ))
« Last Edit: June 02, 2009, 08:39:32 AM by Kerry Brown »
wannabe
« Reply #6 on: June 02, 2009, 05:24:32 AM »
Thanks for  your help, but my lack of LISP knowledge is inhibiting me here.
Here's how I amended my ACAD.LSP file to look:
;;;                                 STARTUP
(defun S::STARTUP ( / )
(command "-vbarun" "Loadtimestamp")
(setvar "modemacro" (strcat
" <> D=$(if,$(getvar,pstylemode),COLOUR MODE,STYLE MODE)"))
);endfun
    (Command "_.netload"  "C:\\Documents and Settings\\39925NT\\My Documents\\Nick's CAD\\CAD Dev\\C#\\dotNet Code\\2.0 Files\\PolyDist\CurveQuery\\CurveQuery.dll")
(if s::startup
I wasn't sure what the second line of  your code did, the call to "load", so I left it for now.
Cheers.
« Reply #7 on: June 02, 2009, 06:35:40 AM »
Comment it out
or remove it
or replace it with a file you WANT to load at startup
added;
does the file appload ?
does the .dll file netload ?
« Last Edit: June 02, 2009, 08:35:54 AM by Kerry Brown »
wannabe
« Reply #8 on: June 02, 2009, 07:17:26 AM »
"Appload"ing, responds with the following, via the command-line:
mmand: ; error: Invalid attempt to access a compiled function definition.
You may want to define it using defun-q: #<SUBR @07bab938 S::STARTUP>
« Reply #9 on: June 02, 2009, 08:59:00 AM »
So, what happens when you change the defun do defun-q
wannabe
« Reply #10 on: June 02, 2009, 09:05:59 AM »
When I change the intial defun to defun-q it loads without command-line error; the command still does not load into AutoCAD, though.
The netload definitely works.
David Hall
  • Automatic Duh Generator
« Reply #11 on: June 02, 2009, 09:21:18 AM »
from above
you neeed to add 1 more \ between PolyDist and CurveQuery.
wannabe
« Reply #12 on: June 02, 2009, 10:28:44 AM »
Sorry for that, gents. Cheers for your input.
wannabe
« Reply #13 on: June 02, 2009, 10:43:31 AM »
Arghhhhh. It's still giving me hassle.
What about a command that will netload the file, and I call that from within the ACAD.LSP.
Can anyone help me with that??
sinc
« Reply #14 on: June 02, 2009, 02:42:30 PM »
I typically just do something like this in my acad.lsp file:
(command "._netload" "C:/MyDLLs/myprog.dll")
As a result of this thread, I tried replacing the above line with this:
(defun-q MYSTARTUP ()
) ;_ defun-q
(setq S::STARTUP (append S::STARTUP MYSTARTUP))
I seemed to get the exact same results either way, with no difference I could discern.
