Author Topic: Using VLA-ITEM  (Read 8627 times)
Using VLA-ITEM
« on: June 01, 2009, 10:30:48 AM »
I am not entirely confident in using this function, but I want to master it.
Currently, when extracting an item from a collection, I am using vlax-for to cycle through the collection, and using some kind of conditional within the loop to get the required object, for example:
(vlax-for lay (vla-get-layers
                (vla-get-ActiveDocument
                  (vlax-get-acad-object)))
  (if (eq "LayerName" (vla-get-Name lay))
    (setq layer lay)))
But is there a way to get at this item directly? I thought perhaps vla-item, but I may be mistaken.
[ And if it isn't Vla-item, then what exactly is Vla-item for...? ]
Many thanks for your time as always,
Cheers,
Lee
Re: Using VLA-ITEM
« Reply #1 on: June 01, 2009, 10:41:52 AM »
Try this:
(setq LayerName "Duct")
(setq LayerCollection (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))))
(setq LayObj (vl-catch-all-apply 'vla-Item (list LayerCollection LayerName)))
If the layername does not exist the catch all will save you.
Re: Using VLA-ITEM
« Reply #2 on: June 01, 2009, 10:47:33 AM »
Another way to get it. Not what you asked, I know.
(if (setq LayEnt (tblobjname "layer" Layername))
  (setq LayObj (vlax-ename->vla-object LayEnt))
Re: Using VLA-ITEM
« Reply #3 on: June 01, 2009, 10:48:25 AM »
Excellent Alan, thanks -
I have received some great help from RonJonP over at CADTutor on this also - and with your tip of using a touch of Error Trapping - this really helps.
Many thanks for your time, it is appreciated as always,
Cheers,
Lee
Re: Using VLA-ITEM
« Reply #4 on: June 01, 2009, 11:14:19 AM »
Don't forget vlax-map-collection
(vlax-map-collection (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object)))
  (function (lambda(x) (if (vlax-property-available-p x 'objectname)
         (print (vla-get-objectname x)))))
OR
(vlax-map-collection (vla-get-ModelSpace (vla-get-ActiveDocument (vlax-get-Acad-Object))) 'vlax-dump-object)
gile
  • Marseille, France
Re: Using VLA-ITEM
« Reply #5 on: June 01, 2009, 11:48:52 AM »
Because vla-item returns an error if the item isn't found in the collection, I wrote a little function which uses vl-catch-apply so that the function returns the vla-object or nil.
(defun GetItem (col name / obj)
  (vl-catch-all-apply
    '(lambda () (setq obj (vla-item col name)))
  obj
(GetItem (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) "0")
returns : #<VLA-OBJECT IAcadLayer 06ca9ad4>
(GetItem (vla-get-Layers (vla-get-ActiveDocument (vlax-get-acad-object))) "test")
returns nil (if there's no "test" layer in the collection)
Using the same way, I have another one to get an object from its handle if it hasn't been erased (otherwise nil).
(defun HandleToObject (handle / obj)
  (vl-catch-all-apply
    '(lambda ()
       (setq obj (vla-HandleToObject
   handle
  obj
Re: Using VLA-ITEM
« Reply #6 on: June 01, 2009, 12:05:15 PM »
OR
Thanks Alan, I always seem to overlook vlax-map-collection when vlax-for always seems the easier method, but I am grateful for your informative examples  :-)
Re: Using VLA-ITEM
« Reply #7 on: June 01, 2009, 12:09:26 PM »
  (vl-catch-all-apply
    '(lambda ()
   handle
  obj
Gile,
Thank you for your response,
I realise that your first example is similar to that posted by CAB earlier in this thread to handle errors returned from vla-item.
However, I do have a question regarding your second posted example,
Why would you use an Object's Handle in operations?
Excuse me if my question seems a little "simple", but I have never used an Object Handle in this way.
Thanks,
Lee
gile
  • Marseille, France
Re: Using VLA-ITEM
« Reply #8 on: June 01, 2009, 12:43:03 PM »
Yes, but using GetItem avoid to write:
(if (not (vl-catch-all-error-p (setq LayObj (vl-catch-all-apply (vla-item ...))))) (do_something ...))
Just write:
(if (setq LayObj (GetItem ...)) (do_something ...))
An entity's name can change from one editing session to the next, but an entity's handle remains constant. So if you need to store objects using xdatas, ldatas or xrecords in a dictionary from one session to another, you have to store their handles.
For example, I use this way to store the objects which are linked to some block reference in TotalArea.lsp
Re: Using VLA-ITEM
« Reply #9 on: June 01, 2009, 01:24:00 PM »
I have in fact used your TotalAreas.lsp - an impressive bit of kit indeed - well done.
Thank you for your superb explanation of object handles, I hadn't considered that aspect before, and originally thought that the object handle also changed with the entity name from session to session - thank you for clarifying this.
Cheers,
Lee
gile
  • Marseille, France
Re: Using VLA-ITEM
« Reply #10 on: June 01, 2009, 01:37:25 PM »
Thanks Lee Mac, you're welcome.
Re: Using VLA-ITEM
« Reply #11 on: February 04, 2010, 11:42:05 AM »
  (vl-catch-all-apply
  obj
gile,
I was doing some research & ran across this old thread.
Wouldn't (vlax-erased-p Obj) work as well as your (defun GetItem ?
Just wondering if there are any pitfalls with using vlax-erased-p
Re: Using VLA-ITEM
« Reply #12 on: February 04, 2010, 02:41:40 PM »
CAB,
I assume you may be referring to Gile's post about the HandletoObject method?
I don't see why vlax-erased-p would cause a problem, but I would be far more inclined to use:
(entget (handent <handle>))
Which returns nil with no error if the object is erased.
PS> This thread seems like ages ago, its amazing how much I have learnt from you guys since then...  :wink:
Lee
Re: Using VLA-ITEM
« Reply #13 on: February 04, 2010, 03:27:13 PM »
I should have been more clear with my comment.
This is what I had in mind.
(defun GetItem (col name)
  (if (not (vlax-erased-p name))
    (vla-item col name)
PS you've been on the "Fast Track"  8-)
Re: Using VLA-ITEM
« Reply #14 on: February 04, 2010, 03:30:41 PM »
Ooo, I've never seen it used in that way before...
At a first glance, without testing anything, I thought that vlax-erased-p just checked the erased flag of an object, so if an item never existed in a collection, then I would assume it would error out...
EDIT:
(GetItem (vla-get-layers *doc) "Lee")
; error: unable to get ObjectID: "Lee"
« Last Edit: February 04, 2010, 03:34:36 PM by Lee Mac »
