Author Topic: Quick Mtext Question  (Read 4205 times)
M-dub
« on: May 28, 2009, 10:52:10 AM »
When editing mtext, is there a way to 'Enter' out of it like you can when editing dtext?  Similarly, when editing attributes, you can tab down to the OK button and hit enter.  I just hate having to use the mouse to OK out of the mtext editor.
James Cannon
Re: Quick Mtext Question
« Reply #1 on: May 28, 2009, 10:58:13 AM »
CTRL+Enter
*edit*  This goes for the attribute-editor as well, and most any dialog where you want to his "OK" but don't know how many times you'd have to hit 'tab' to switch focus to the 'enter/ok' button.
M-dub
« Reply #2 on: May 28, 2009, 11:01:35 AM »
Awesome.  Thanks d00d.  :)
« Reply #3 on: May 28, 2009, 11:04:18 AM »
Picking outside the editor window will also close the editor, but you probably knew that.
M-dub
« Reply #4 on: May 28, 2009, 11:04:32 AM »
Hmph... doesn't work on my machine... CTRL+Enter does the same as plain ol' Enter.
James Cannon
« Reply #5 on: May 28, 2009, 11:05:28 AM »
weird.  I just double checked and it works for me.
Oh well.  Just means I'm cooler.... yea... that's.. it...
M-dub
« Reply #6 on: May 28, 2009, 11:11:32 AM »
Yep, thanks... That's what I was trying to avoid...
I use this routine to edit all of my text / attribute entities by selecting them in the order I want to edit them in and hate having to use the mouse at all... I just want to use the keyboard.
M-dub
« Reply #7 on: May 28, 2009, 11:12:00 AM »
Sucks to be me, I guess... :(
Matt__W
  • I like my water diluted.
« Reply #8 on: May 28, 2009, 11:12:13 AM »
:roll:
Autodesk Expert Elite
sinc
« Reply #9 on: May 28, 2009, 12:33:31 PM »
How old is your software?  They added the CTRL+ENTER thing in...  2005?
M-dub
« Reply #10 on: May 28, 2009, 12:35:00 PM »
2009
M-dub
« Reply #11 on: May 28, 2009, 01:20:52 PM »
What would I search for in the AutoCAD help files for what CTRL+Enter does?
I'm wondering if it's a variable I have turned off somehow...
sinc
« Reply #12 on: May 28, 2009, 01:24:30 PM »
I just searched for CTRL ENTER, and got a page called "Format Characters Within Multiline Text" that says:
To save your changes and exit the editor, use one of the following methods:
  • On the MTEXT ribbon contextual tab, in the Close panel, click Close Text Editor.
  • Click in the drawing outside the editor.
  • Press CTRL+ENTER.
sinc
« Reply #13 on: May 28, 2009, 01:25:54 PM »
Don't see anything about any way to turn it on or off.
Matt__W
« Reply #14 on: May 28, 2009, 01:28:46 PM »
It must be a "feature" in the Canadian version.   :roll:
