Hello all,
I am currently working on something for my boss.
Basically this is a excel file where we going to merge a lot of document together and information about each project.
I discovered a lisp file able to read specific cell in excel (READCELL) and another one able to write a specific cell in a specific worksheet (PUTCELL).
What i need: -I would like to be able to extract each block quantity into specific cell in excell using the command PUTCELL i have.
; Syntax: (PutCell StartCell$ Data$) or (PutCell StartCell$ DataList@)
; Example: (PutCell "A1" (list "GP093" 58.5 17 "Base" "3'-6 1/4\""))Condition:-Many of our block are dynamic with different name *Ublahblah , impossible to count, But i'm going to add invisible attribute with the name of the item in each block, for better calculation later.
-The zone of the block selection should be generated automatically, to prevent clone of the same block (counted twice) like the same detail with 2-3 different view. i'm going to design each floor above X + Z axis (meaning top right of the X-Y icon in model space), and every detail under X axis (X-1 to 500 etc.) this way the block attribute extraction selection does not count extra block.
Begging:Can someone explain me how to do this with example please? my Lisp scripting is limited to adjusting other people script to fit my needs, but i cannot find something similar actually
thank you very very much for your help!
