this is what I use
Public Sub SetupAndPlot(ByRef Plotter As String, CTB As String, SIZE As String, PSCALE As String, ROT As String)
Dim Layout As AcadLayout
On Error GoTo Err_Control
Set Layout = ThisDrawing.ActiveLayout
Layout.RefreshPlotDeviceInfo
Layout.ConfigName = Plotter ' CALL PLOTTER
Layout.PlotType = acExtents
Layout.PlotRotation = ROT ' CALL ROTATION
Layout.StyleSheet = CTB ' CALL CTB FILE
Layout.PlotWithPlotStyles = True
Layout.CanonicalMediaName = SIZE ' CALL SIZE
Layout.PaperUnits = acInches
Layout.StandardScale = PSCALE 'CALL PSCALE
Layout.ShowPlotStyles = False
ThisDrawing.Plot.NumberOfCopies = 1
Layout.CenterPlot = True
Layout.ScaleLineweights = False
ThisDrawing.Regen acAllViewports
ZoomExtents
Set Layout = Nothing
ThisDrawing.Save
Exit_Here:
Exit Sub
Err_Control:
Select Case Err.Number
Case "-2145320861"
MsgBox "Unable to Save Drawing- " & Err.Description
Case "-2145386493"
MsgBox "Drawing is setup for Named Plot Styles." & (Chr(13)) & (Chr(13)) & "Run CONVERTPSTYLES command", vbCritical, "Change Plot Style"
Case Else
MsgBox "Unknown Error " & Err.Number
End Select
