Author Topic: The reactor callback funtion couldn't modify the owner???  (Read 2609 times)
cjw
« on: May 18, 2009, 01:43:57 AM »
[How]
Change the number'color to "red",if the number smaller than 500;
Else,change the number'color to "bylayer"
;;By carrot1983 2009-05-18
(defun C:TT (/ DATA_LST E OWN_LST)
  (if (setq E (car (entsel "\nSelect the number: ")))
      (setq DATA_LST (list 500))
      (setq OWN_LST (list (vlax-ename->vla-object E)))
      (vlr-pers
(vlr-object-reactor
  OWN_LST
  DATA_LST
  '((:vlr-modified . REACTOR-CHANGE-COLOR))
(defun REACTOR-CHANGE-COLOR (OWNER DATA PAR / DATA_LST E1 TXT V1)
  (setq TXT (vla-get-textstring OWNER))
  (setq DATA_LST (vlr-data DATA))
  (if (< (read TXT) (car DATA_LST))
    (setq A (vl-catch-all-apply
      'vla-put-color
      (list OWNER 1)
      'vla-put-color
      (list OWNER acbylayer)
;;After modified
;;(VL-CATCH-ALL-ERROR-MESSAGE A)
;;Error: AutoCAD.Application: ....
kozmos
Re: The reactor callback funtion couldn't modify the owner???
« Reply #1 on: May 18, 2009, 02:46:48 AM »
your code will continue changing the object color after the reactor is originally fired and, that will trigger an non-stopable calling for ur call-back function becoz changing color will also fire vlr:modified.
You need to record the old color of object and to detect if a color change is necessary. So the scenario of changing might be:
1: u change the number
2: callback function is fired as object is changed by content, then object color is changed if necessary
3: callback function is fired again if object color is changed
4: as the color is already be correct, then no change of color is needed any more. And then u can quit reactor callback function normally.
KozMos Inc.
Chuck Gabriel
« Reply #2 on: May 18, 2009, 07:30:28 AM »
Have you actually tried this, because I think the problem is actually a little deeper.  You actually can't modify the object that issued the notification because it is potentially still open for writing.
What you can do is add the object's id to a list and then grab it from its id and modify it in an editor reactor rather than a database reactor.  It means you end up with an extra reactor, but to my knowledge, it is the only safe means of doing what you want.
kozmos
« Reply #3 on: May 18, 2009, 08:33:48 AM »
Yes you are right.
KozMos Inc.
Chuck Gabriel
« Reply #4 on: May 18, 2009, 09:16:48 AM »
I can't believe I actually used the word "actually" that many times in a single paragraph. :D
cjw
« Reply #5 on: May 20, 2009, 04:34:34 AM »
Thank you, kozmos Chuck Gabriel !
My english is not good.so....
I have no idea to fix it.
I don't know how to understand it.
Could realize it by Lisp code?
Chuck Gabriel
« Reply #6 on: May 20, 2009, 07:28:27 PM »
Fair warning, this is hacky code, but it should get you started.
(setq *TT:NOTIFYING* T)
(defun TT:COMMAND-ENDED (reactor commandName)
  (setq *TT:NOTIFYING* nil)
  (foreach ent *TT:MODIFIED_LESS*
    (vla-put-color ent 1)
  (foreach ent *TT:MODIFIED_GREATER*
    (vla-put-color ent acbylayer)
  (setq
    *TT:NOTIFYING*   T
    *TT:MODIFIED_LESS*   nil
    *TT:MODIFIED_GREATER* nil
(defun TT:CLEANUP ()
  (mapcar 'vlr-remove-all
  '(:vlr-acdb-reactor
    :vlr-editor-reactor
    :vlr-linker-reactor
    :vlr-object-reactor
(defun TT:OBJECT-CHANGED (OWNER DATA PAR / DATA_LST TXT)
  (if *TT:NOTIFYING*
(setq *TT:MODIFIED_LESS*
       (if *TT:MODIFIED_LESS*
(if (member OWNER *TT:MODIFIED_LESS*)
   *TT:MEMBER_LESS*
   (cons OWNER *TT:MODIFIED_LESS*)
(list OWNER)
(setq *TT:MODIFIED_GREATER*
       (if *TT:MODIFIED_GREATER*
(if (member OWNER *TT:MODIFIED_GREATER*)
   (cons OWNER *TT:MODIFIED_GREATER*)
(list OWNER)
(or *commandReactor*
    (setq *commandReactor*
   (vlr-command-reactor
     nil
     '((:vlr-commandEnded . TT:COMMAND-ENDED))
(or *cleanupReactor*
    (setq *cleanupReactor*
   (vlr-dwg-reactor
     nil
     '((:vlr-beginClose . TT:CLEANUP))
      (setq
DATA_LST (list 500)
      (vlr-object-reactor
OWN_LST
DATA_LST
'((:vlr-modified . TT:OBJECT-CHANGED))
cjw
« Reply #7 on: May 20, 2009, 08:41:22 PM »
Chuck Gabriel ,Thanks for your kindness!!
Learning  your code...
Thank you very much.
cjw
« Reply #8 on: May 20, 2009, 09:02:47 PM »
After did the test,I found it can't work,so add two code.Like this.
So now it work...I am studying....
Thanks again.
     *TT:MEMBER_LESS*
   (list OWNER)
[color=red] (setq *TT:MODIFIED_GREATER* NIL);_ADD CODE[/color]
   (list OWNER)
[color=red] (setq *TT:MODIFIED_LESS* NIL);_ADD CODE[/color]
« Last Edit: May 20, 2009, 09:05:49 PM by cjw »
