Author Topic: [IronPython] Using C# derived form in your Ipy script  (Read 3859 times)
  • (x-in)->[process]->(y-out)
« on: May 14, 2009, 11:58:54 PM »
As mentioned in other threads and elsewhere, it's possible to create your winforms dialogs etc in VS or Sharpdevelop so you have a nice ide to place and arrange controls with. Just compile the class lib and import it into your Ipy module.
You then need to derive from it and add your event handlers and change properties as required.
Here's a quick example based on Daniel's count layers demo.
import sys
sys.path.append('C:\\Program Files\\AutoCAD 2009')
sys.path.append('D:\\_Dev\\IPyCADv1.1\\IPyCADv1.1\\bin\\Debug')
sys.path.append('C:\\DCS_3D\\ipyscripts')
import clr
clr.AddReferenceToFile('acdbmgd.dll')
clr.AddReferenceToFile('acmgd.dll')
clr.AddReferenceToFile('IpyForm.dll')
from IpyForm import *
import Autodesk.AutoCAD.DatabaseServices as dbs
import Autodesk.AutoCAD.ApplicationServices.Application as app
class My_form(IpyForm):
        def __init__(self):
                IpyForm.__init__(self)
                self.Text = "IronPython Demo"
                self.Controls["label1"].Text = "Wow it's Python"
                self.Controls["label2"].Text = "0"
                self.Controls["button1"].Text = "Count Layers"
                self.Controls["button2"].Text = "Close"
                self.Controls["button1"].Click += self.lay_click
                self.Controls["button2"].Click += self.close_click
        def count_layers(self):
                try:
                        db = dbs.HostApplicationServices.WorkingDatabase
                        print db.ToString()
                        tm = db.TransactionManager
                        tr = tm.StartTransaction()
                        ltbl = tm.GetObject(db.LayerTableId, dbs.OpenMode.ForRead, False)
                        i = 0
                        for layer in ltbl:
                                i = i + 1
                        tr.Commit()
                        tr.Dispose()
                        return i
                except:
                        tr.Dispose()
                        print "error"
        def close_click(self,*args):
                self.Close()
        def lay_click(self,*args):
                self.Controls["label2"].Text = str(self.count_layers())
my_form = My_form()
app.ShowModalDialog(my_form)
And the piccy of the form as designed in VS2005
Lao Tzu: “To attain knowledge, add things
every day; to obtain wisdom, remove things every day.”
  • BricsCAD
Re: [IronPython] Using C# derived form in your Ipy script
« Reply #1 on: May 15, 2009, 12:02:49 AM »
Pretty slick!  8-)
« Reply #2 on: May 15, 2009, 12:23:02 AM »
Yep, pretty simple :)
  • BricsCAD
« Reply #3 on: May 15, 2009, 07:25:47 AM »
What do you guys think about BOO?
« Reply #4 on: May 15, 2009, 10:01:17 AM »
I think BOO is very cool (Tim Wiley introduced us to it looooooong ago). The only thing that concerns me is wasted development investment should it wither and die.
PS: Nice demo Mick. :)
Engineering Technologist • Programmer Analyst • CAD Specialist
Multi-Discipline • Design • Drafting • Document Control • Automation.
cadanalyst@gmail.com • www.linkedin.com/in/cadanalyst
Spike Wilbury
« Reply #5 on: May 15, 2009, 10:09:21 AM »
Wasn't other Tim now using other identity: r  ?
« Reply #6 on: May 15, 2009, 10:14:40 AM »
I dunno, maybe he goes by Ringo -- he does march to a different drummer.
Spike Wilbury
« Reply #7 on: May 15, 2009, 10:16:56 AM »
He he.....
  • BricsCAD
« Reply #8 on: May 15, 2009, 10:18:38 AM »
Seems a good way to go, its statically typed and supports attributes, no fuss, no muss, just netload and run.
« Reply #9 on: May 15, 2009, 10:20:20 AM »
the clean python like syntax / syntactic sugar is very appetizing and surprisingly lo cal :D
  • BricsCAD
« Reply #10 on: May 15, 2009, 10:24:57 AM »
Syntactic Sucralose :|
« Reply #11 on: May 15, 2009, 10:27:00 AM »
wow, "boo seems good" to "boo will give you cancer" in just a couple posts; i be confused
  • BricsCAD
« Reply #12 on: May 15, 2009, 10:29:27 AM »
 :laugh:
  • BricsCAD
« Reply #13 on: May 15, 2009, 10:34:50 AM »
Installing BoolLangStudio now
  • BricsCAD
« Reply #14 on: May 15, 2009, 11:19:22 AM »
nope BooLangStudio is DOA with VC2008sp1  too bad
