I had always tried to stay away from those as they are not installed on some machines.
this
While I agree with the idea these functions should not be depended on, the fact they are typically installed since I'm not sure what version makes them compelling given no other chioce.
Quote from: Joe Burke on May 14, 2009, 10:04:59 AMWhile I agree with the idea these functions should not be depended on, the fact they are typically installed since I'm not sure what version makes them compelling given no other chioce.Speaking of "no other choice" did you dump the notion of rolling your own or using George Harrison's arx?
Quote from: MP on May 14, 2009, 10:21:26 AMQuote from: Joe Burke on May 14, 2009, 10:04:59 AMWhile I agree with the idea these functions should not be depended on, the fact they are typically installed since I'm not sure what version makes them compelling given no other chioce.Speaking of "no other choice" did you dump the notion of rolling your own or using George Harrison's arx?Michael,If I knew how to roll my own I would. I don't.What I have is the ExpressTools option, and appently some ARX by George Harrison which you mentioned, and an ARX by Luis which does the same thing with the shift key. Given these choices, I'd rather depend on ET than have to include a separate ARX routine/file.Joe
