Author Topic: Too few arguments  (Read 9620 times)
POCKETS
Re: Too few arguments
« Reply #15 on: May 13, 2009, 04:54:51 PM »
When I type '!trans' I get "lisp command not available"
Cab I'm thinking you're right that my AutoCAD has a bug
POCKETS
« Reply #16 on: May 13, 2009, 05:12:12 PM »
When I try using flexduct I get the following:
Duct diameter is set to 16.0
Select center line of flex duct.[Diameter]<16.0> Enter to quit.d
Specify duct diameter <16.0000>: 4
Duct diameter is set to 4.0
Select center line of flex duct.[Diameter]<4.0> Enter to quit.bad function:
VLAX-CURVE-GETPOINTATPARAM
Command:
The VLAX-CURVE-GETPOINTATPARAM also appears when I use pl2cloud27a
« Reply #17 on: May 13, 2009, 05:24:03 PM »
Try this test version. I removed the TRANS function.
POCKETS
« Reply #18 on: May 14, 2009, 08:10:53 AM »
CAB,
Thank you, Thank you!
Works like a charm
Pockets
« Reply #19 on: May 14, 2009, 09:33:12 AM »
OK see attached a special version of pl2cloud with the trans removed.
« Reply #20 on: May 14, 2009, 09:35:50 AM »
For those that need the TRANS see attached the latest version, and debug code turned OFF.
POCKETS
« Reply #21 on: May 14, 2009, 01:35:48 PM »
CAB,
Again, Thank you, Thank you!
It works!!!!!!
« Reply #22 on: May 14, 2009, 01:38:29 PM »
Maybe search through all your lisp codes that run within acad, and see if you have anything that has ' defun trans '.  I can't believe anyone would do that, but maybe one of the codes you are using has it, which caused this problem.
POCKETS
« Reply #23 on: May 14, 2009, 02:30:39 PM »
That I shall do.
Many thanks to you as well.
Pockets
POCKETS
« Reply #24 on: May 14, 2009, 02:35:51 PM »
T. Willey
Another thought just came to mind.  Do I delete the DEFUN TRANS?  Is there any text associated with DEFUN TRANS?
Again, Thanks
Pockets
« Reply #25 on: May 14, 2009, 02:41:46 PM »
I would do a text search of all lisp files with the following:
Files:   *.lsp
Text:  "defun (trans"
See if you get any hits. If so, then open that file, or better yet post that file here & we will see if it can be cleaned up.
« Reply #26 on: May 14, 2009, 02:45:32 PM »
Files:   *.lsp
Don't put the parenthesis before ' trans '.  Below is how you should search.  I think Alan just typed too fast.   :wink:
Files:   *.lsp
Text:  "defun trans"
T. Willey
Again, Thanks
Pockets
As for deleting it, I would say no.  I would just rename it, and then make sure you change all the calls to it within that lisp function.  If you delete it, the lisp won't work as it should.
« Reply #27 on: May 14, 2009, 02:53:17 PM »
Thanks Tim you're quite right. :)
Use defun trans  as Tim siggested.
POCKETS
« Reply #28 on: May 14, 2009, 03:05:36 PM »
Again,
Many thanks to the both of you.
Pockets
POCKETS
« Reply #29 on: May 14, 2009, 03:11:32 PM »
...and again, I show my ignorance.  How do you do a text search?  I did a search using the start up search program for file and folders and found nothing.
Pockets
