Author Topic: vla-put-Coordinate  (Read 6879 times)
vla-put-Coordinate
« on: May 09, 2009, 06:52:15 PM »
Hi Guys,
Just wondering how to use the above method?
I have been trying the follow, but to no avail:
(vla-put-Coordinate <vla-object>  (vlax-3D-point (list (car pt) (cadr pt))) <Int>)
Where <vla-object> is an LWPOLYLINE, and pt is a point, and <Int> is an Integer representing a vertex parameter.
But I keep getting the error:
"Lisp has no Coercion to VARIANT with this type: <variant8197>..."
Any help or advice is appreciated :)
Cheers
Lee
Re: vla-put-Coordinate
« Reply #1 on: May 09, 2009, 07:01:06 PM »
You need to use vla-put-Coordinates
Note the s
« Reply #2 on: May 09, 2009, 07:02:46 PM »
Is there no way to use
vla-put-Coordinate?
« Reply #3 on: May 09, 2009, 07:05:25 PM »
Oh, you want to update a single coordinate?
You need to use the coordinate number.
(vla-put-coordinate obj param# coord)
try this:
(vla-put-Coordinate <vla-object> <Int>  (vlax-3D-point (list (car pt) (cadr pt))))
« Last Edit: May 09, 2009, 07:09:40 PM by CAB »
« Reply #4 on: May 09, 2009, 07:10:28 PM »
Sorry CAB, I don't quite follow you -
Is Coord a "variant" or just a list?
Also, is param# an integer?
« Reply #5 on: May 09, 2009, 07:33:35 PM »
just like you had it but the integer was in the wrong place.
« Reply #6 on: May 09, 2009, 07:52:16 PM »
Many thanks CAB  8-)
I needed to make a safearray and variant, as I realised it was a 2D point, not 3D - hence vlax-3D-point would not work.
But I did get it working   :lol:
Lee
« Reply #7 on: May 09, 2009, 07:54:52 PM »
Great, I just got this to work.
(defun c:test(/ ent obj vlapt)
  (setq obj (vlax-ename->vla-object (car(entsel))))
  (setq vlapt (vlax-make-safearray vlax-vbdouble '(0 . 1)))
  (vlax-safearray-fill vlapt '(2 2))
  (vla-put-Coordinate obj 1  vlapt)
As you say it's not a 3-d point. 8-)
« Reply #8 on: May 09, 2009, 09:27:50 PM »
I think if you use the (vlax-get\vlax-put obj 'Coordinate\s) you don't have to supply a variant.
« Reply #9 on: May 10, 2009, 09:19:02 AM »
Thanks for the tip Ron  :-)
« Reply #10 on: May 10, 2009, 09:57:35 AM »
This works:
(vlax-get obj 'Coordinates) ; returns a point list
This does not:
(vlax-get obj 'Coordinate 1)
« Reply #11 on: May 10, 2009, 11:22:36 AM »
Yeah, the get/put shortcut does not work with this property. Another one of those cases you must use the "long way" to do something.
