Ok, I am having some major problems with opening, saving and closing files.
;This first function is from another website, unfortunately I forgot to write down where I found it, so if it looks familar to you, please let me know and I will add the proper credit.
(defun OpenFile(FilePath Activate / oFile)
(if (findfile FilePath)
(if (vl-file-systime FilePath)
(vl-catch-all-error-p
(setq oFile
(vl-catch-all-apply
'vla-open
(list
(vla-get-Documents
(vlax-get-acad-object)) FilePath))))
(alert
(strcat "ERROR.\n Can't open file: " FilePath))
(if Activate(vla-Activate oFile))
); end if
(alert
(strcat "ERROR. File " FilePath
"\n may be opened, inaccessible or password protected."))
); end if
(alert
(strcat "ERROR.\n File not found: " FilePath))
); end if
oFile
); end of OpenFile
(defun c:tst (); This routine is to open each file.
(setq images (dos_dir (strcat (dos_getdir "" "h:\\BEI-TEMP\\" "Select the folder with the backgrounds that need to be cleaned up:" T) "*.dwg") 1))
(if (/= rpt nil)
(if (< a (+ rpt 1))
(setq FileString (strcat pth (nth (- a 1) images)))
(setq a (+ a 1))
(OpenFile FileString T)
(setq rpt nil)
(defun c:RunAtDocumentLoad () ;This routine will have everything in it that will run when the document loads, this version of it causes AutoCAD to completely crash.
(vl-cmdf "._QSAVE")
(vl-cmdf "._close")
(defun c:RunAtDocumentLoad () ;This routine will have everything in it that will run when the document loads, this version does not actually close the files for some reason.
(vla-close (vla-get-documents (vlax-get-acad-object)) :vlax-true)
Please note that I am doing this with OpenDCL, and the routines are run on document activation.
