Author Topic: "-4" code in SSGet Filter List  (Read 6266 times)
« on: May 07, 2009, 05:12:16 PM »
I know using such a code for logical conditionals such as:
(-4  .  "<OR")    (-4  .  "OR>")
(-4  .  "<AND")    (-4  .  "AND>")
(-4  .  "<XOR")    (-4  .  "XOR>")
(-4  .  "<NOT")    (-4  .  "NOT>")
etc etc
But recently, I have seen it used in the following way:
(0 . "CIRCLE")
(-4 . "*,=,*")
(assoc 10 dxf_ent)
where "dxf_ent" is the (entget) return for another Circle.
I was just wondering, what is the deal with this "-4" group code?  Is there somewhere a list of all the possibilities in which it can be used?
Your input and advice is much appreciated  8-)
Cheers
Lee    :lol:
Re: "-4" code in SSGet Filter List
« Reply #1 on: May 07, 2009, 05:33:00 PM »
Look in the help for ' selection set filter lists '.  These are what they help is calling ' Relation tests '.  Here is a quick cut from the help.
Relational operators for selection set filter lists
Operator
 Description
 Anything goes (always true)
 Equals
 Not equal to
 Not equal to
 Not equal to
 Less than
 Less than or equal to
 Greater than
 Greater than or equal to
 Bitwise AND (integer groups only)
 Bitwise masked equals (integer groups only)
« Reply #2 on: May 07, 2009, 05:34:38 PM »
Cheers Tim, I'll check that out  :-)
« Reply #3 on: May 07, 2009, 05:39:02 PM »
You're welcome.
« Reply #4 on: May 07, 2009, 11:06:28 PM »
An old thread:
http://www.theswamp.org/index.php?topic=1333.msg16766#msg16766
Here are some examples I have tucked away:
CAB 03.29.08
get any nornal that is not 0 0 1
(setq ss (ssget "X" '((-4 . "<NOT")(210 0.0 0.0 1.0)(-4 . "NOT>")(-4 . "*,*,*")(210 0.0 0.0 1.0))))=======================================================================
 Example by CAB
 Find a circle with a given center point
If the center point of the circle & the start point of the plines are the same this will get them.
(setq mdn (ssget "x" (list '(0 . "circle") (append '(10) stp))) )
If you need some wiggle room try this: [ignoring the z]
(setq wiggle 0.05)
                            '(-4 . ">,*,*") (list 10 (- (car stp) wiggle) 0 0)
                            '(-4 . "<,*,*") (list 10 (+ (car stp) wiggle) 0 0)
                            '(-4 . "*,>,*") (list 10 0 (- (cadr stp) wiggle) 0)
                            '(-4 . "*,<,*") (list 10 0 (+ (cadr stp) wiggle) 0)
Reads like this:
(if  (and  (> (center x) (- (pt x) wiggle))
(< (center x) (+ (pt x) wiggle))
(> (center y) (- (pt y) wiggle))
(< (center y) (+ (pt y) wiggle))
Example by Luis  uses a list of points
(setq filter (append (list '(-4 . "<AND") '(0 . "AECC_POINT") '(-4 . "<OR"))
                     (mapcar (function (lambda (x) (cons 90 x)))
                             num_list
                     (list '(-4 . "OR>") '(-4 . "AND>"))
(ssget "X" filter)
« Reply #5 on: May 08, 2009, 05:41:08 AM »
Thanks CAB, some nice examples there  :-)
