Author Topic: Editing TEXT OVERRIDE with AutoLISP  (Read 18073 times)
  • Custom Title
« on: November 18, 2003, 09:33:42 AM »
If you were going to write a program to edit the text overrides of a dimension what would you like the program to do?
daron
« Reply #1 on: November 18, 2003, 10:14:49 AM »
append text to the default values, either in front of or after the default value. Something like this:
(vla-put-TextOverride DimObj "{\\Farchquik.shx;<>\\XBSL}")
SMadsen
« Reply #2 on: November 18, 2003, 10:20:09 AM »
Is it correctly understood that your DPSX command adds texts to the properties TextPrefix and/or TextSuffix? If so, it results in creation of XData that overrides the parent dimstyle's DIMPOST variable.
Another method could be to use the TextOverride property. This will add text to group code 1 of the dimension's entity list. If it doesn't include "<>" then it will totally override the dimension text. If it includes "<>" then it will allow TextSuffix, Measurement and TextPrefix to show as well.
SMadsen
« Reply #3 on: November 18, 2003, 10:21:34 AM »
Beaten by Daron in .. umm, 6 minutes. Man, I'm a slow typer!
daron
« Reply #4 on: November 18, 2003, 10:23:53 AM »
6 minutes. Too funny, Stig. You fall asleep?
ELOQUINTET
« Reply #5 on: November 18, 2003, 10:24:03 AM »
mark i would like it setup just like the one we've already created but instead of adding the text as a suffix it would add it as an override so it would show up in the mtext editor for easy removal if need be. it would be nice if it could wipeout an existing override as well because if i have to erase the other one i might as well just type it in since i'm there. and again we wouldn't want the double suffix error. i would also like to have it so i can easily add overrides as i need them. that's it basically if you have any more questions i'm here all day long  :wink:
dan
SMadsen
« Reply #6 on: November 18, 2003, 10:26:00 AM »
zzzzZZZZZZZZZZZ
daron
« Reply #7 on: November 18, 2003, 10:32:58 AM »
I didn't see your previous one, but in a vba form or dcl file you could have a textbox or whatever it's called that contains the text string you intend to overwrite. Or, you could have buttons that ask if you want to overwrite or append.
WAKE UP Stig. The boss is coming.
ELOQUINTET
« Reply #8 on: November 18, 2003, 10:55:22 AM »
yes something along those lines daron
  • Custom Title
« Reply #9 on: November 18, 2003, 11:01:58 AM »
Quote from: eloquintet
dan
So we're going to have two lists, one for the front of the dim(<>) and one for the back. The TextOverride will go on the front, back, or both depending on what the user selects from the lists.
Do you want an option to remove any overrides that exist?
Do you always want to overwrite any existing text? <- this is a biggey
ELOQUINTET
« Reply #10 on: November 18, 2003, 11:17:31 AM »
umm a remove option would be great. the overwrite would not be neccesary if it showed the existing overrides and gave me the option to remove them then add the new ones.
dan
  • Custom Title
« Reply #11 on: November 18, 2003, 11:42:42 AM »
dan
Sorry, I'm still confused! Lets say you have a dim that looks like this;
15.0" BACK
You start the program, select an item from the "back" list that reads "OTHER", you then select the dim 15.0" BACK on the screen. Do you;
A) replace BACK with OTHER so it looks like 15.0" OTHER
B) append OTHER to the dim like so 15.0" BACK OTHER
C) option to do B above.
ELOQUINTET
« Reply #12 on: November 18, 2003, 11:49:15 AM »
A) would do fine
i was thinking that the dialog would have the existing override but neglected to remember that you would have to select the dimension first to have that option. A) is fine. just as long as it tells you that the dimension has an existing override. i don't think i would ever append just replace.
dan
  • Custom Title
« Reply #13 on: November 18, 2003, 12:00:39 PM »
but wouldn't you see that when you select the dim?
  • Custom Title
« Reply #14 on: November 18, 2003, 12:04:05 PM »
Editing the two .txt files isn't easy enough? Or do you have something else in mind?
