Hey Mike, thanks for your feedback. I'd be interest in a sample as well, especially
if it created class instances and serialized the data. I don't know if I'll ever get
back into C# except to support some legacy code, otherwise .Net 2.5, EntitySpaces,
and CodeXS have served me well for a number of years.
Unfortunately, none of them are true. There is no overhead, there doesn't need to be sharing between apps, and size of app has nothing to do with whether or not to use Xml. The determining factor is how easily do you want to deal with your data? And, how much code do you want to write?
Though your opinion probably won't change, I would point out that parsing XML string data is very CPU intensive and
source files are much bigger than most other format methods, neither of which are free.
Paul
