Author Topic: 09 rendering issue?  (Read 5244 times)
Barry Clark
09 rendering issue?
« on: April 20, 2009, 01:07:02 PM »
Ok, maybe something changed.
Once was able to type RENDER at the command line and I could get a rendering of the object I created.
Now... nothing.
Any ideas?
Attached the drawing I am dealing with.
Thanks all!
James Cannon
Re: 09 rendering issue?
« Reply #1 on: April 20, 2009, 01:11:16 PM »
Could you expand on "nothing" ?
Does the command execute?
Does the render window pop up?
Does it render, but only show solid black?
Barry Clark
« Reply #2 on: April 20, 2009, 02:08:00 PM »
Command seems to execute. Window pops up. Just a solid black image pops up. Lighting is at default as i have always done it.
James Cannon
« Reply #3 on: April 20, 2009, 02:24:08 PM »
I'll check out the file now that I'm back in the office.  You may just be too far from 0,0,0 for Autocad to know how to think.
Barry Clark
« Reply #4 on: April 20, 2009, 02:26:39 PM »
Strange, it always seemed to just render the view before. Thank you for looking into it.
James Cannon
« Reply #5 on: April 20, 2009, 02:30:04 PM »
I'm using 09.
I duplicated your problem.
Drew a line from 0,0,0 to a point on one of your objects and saw that it was a decent ways away.
Autocad is retarded sometimes, and this is one of those cases, imo.  Move your objects closer to 0,0,0 and try rendering again.
Barry Clark
« Reply #6 on: April 20, 2009, 02:43:25 PM »
Worked like a charm! Thanks sir!
