Author Topic: Toolbox - Code Gallery ?  (Read 2349 times)
Spike Wilbury
« on: April 15, 2009, 11:45:06 PM »
I been using Visual Studio for a long time.... and just started to drag and drop some of my functions or snippets in the toolbox area, so later I just simple will drag and drop/pasted as desired or needed.
Now, does any one knows where is that data saved?
Thanks!
Included it is a little image FYI...
Re: Toolbox - Code Gallery ?
« Reply #1 on: April 16, 2009, 01:43:02 AM »
Luis,
There is a file called
CurrentSettings.vssettings
which is save in a user defined location
Options-> Import and Export settings
--> Donate to theSwamp<--
Spike Wilbury
« Reply #2 on: April 16, 2009, 09:49:25 AM »
Luis,
Kerry,
That's great, thanks !
