I was hoping that my application would be robust enough to deal with a number of filetypes: .txt, .csv, .doc. Have I correctlly inferred that your suggesting I should convert all the files to XML first and then let the core of my application deal with XML files. So there is methodology, or just a method, to convert my original file to XML and then the core components of my application to populate a collection with a record from each line of the XML file?
My knowledge of XML needs some development, so tonight I will do a bit of research.
Thanks for the input.
