Author Topic: Some of my buttons don't work v5.1.0.3  (Read 10844 times)
Re: Some of my buttons don't work v5.1.0.3
« Reply #15 on: April 15, 2009, 12:33:40 AM »
(dcl_getversionex)
;;=> "5.1.0.3"
It's Alive!
  • Retired
  • AKA Daniel
« Reply #16 on: April 15, 2009, 12:36:56 AM »
Ok,
(dcl_PROJECT_LOAD "Fields.odcl" t)
was my problem !
Doh I should have remembered this.
Thanks for all your Help kerry, I hope you feel better
« Reply #17 on: April 15, 2009, 12:38:43 AM »
Ok,
was my problem !
GREAT  !!!
I'm taking my head back to bed now :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #18 on: April 15, 2009, 07:17:31 AM »
This is still not working consistently, I can add a button, set up the events, load the dialog and it doesn’t work.
It seems I need to add another new control, delete the new control, save, then everything works.
maybe I am just doing something in the wrong order  :laugh:
