Author Topic: Some of my buttons don't work v5.1.0.3  (Read 10838 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: April 14, 2009, 11:26:52 PM »
Some of my buttons don't work, I can't see what I'm doing wrong
v5.1.0.3
ps I copied and pasted those three from the top one  :angel:
Re: Some of my buttons don't work v5.1.0.3
« Reply #1 on: April 14, 2009, 11:43:15 PM »
I've been in bed with a weird head so I may not be seeing this correctly ...
Have you selected the Click event for each event in the editor you want to use ...
« Reply #2 on: April 14, 2009, 11:50:02 PM »
I've been in bed with a weird head ...
Does it respond to your voice?
Hope you get better soon. :)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #3 on: April 14, 2009, 11:50:37 PM »
Yes, I did add the event, and copied the source to my lisp file.
I have tried replacing the three offending buttons, now one more seems to work.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: April 14, 2009, 11:52:17 PM »
Hey wait, was it not toggled when you opened my file?
« Reply #5 on: April 14, 2009, 11:54:01 PM »
what a sick joke
 :-P
« Reply #6 on: April 14, 2009, 11:55:05 PM »
nope ...
may still be a buglet though ...
It's Alive!
  • Retired
  • AKA Daniel
« Reply #7 on: April 14, 2009, 11:56:34 PM »
hmm they are all checked on my machine.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #8 on: April 15, 2009, 12:05:17 AM »
I’ll see if I can get an older editor, are you using the same version a me?
« Reply #9 on: April 15, 2009, 12:16:22 AM »
Drag/Drop Allow Begin
Toggle it OFF for the buttons ..
« Reply #10 on: April 15, 2009, 12:20:51 AM »
a tip ;
for development, change this
  ;; (LoadODCLProjDev "Fields.odcl")
to this ...
  (dcl_PROJECT_LOAD "Fields.odcl" t)
so the ODCL will reload each time ( to refresh changes )
« Reply #11 on: April 15, 2009, 12:25:15 AM »
A Tip ;
On the Menu Bar=> Tools .. Select Clear Lisp Symbol Names
This will leave the VarName property field empty and the Editor will look after making sure the name is correctly concatenated.
« Reply #12 on: April 15, 2009, 12:28:22 AM »
In your code, and editor, check the Initialise event call
You had
(defun c:Fields_FormFieldset_OnInitialize (/)
in the code
and
(defun c:Fields_FormField_OnInitialize (/)
in the editor
Though this may have been a result of my resetting the events ..  :-(
It's Alive!
  • Retired
  • AKA Daniel
« Reply #13 on: April 15, 2009, 12:28:34 AM »
I don’t have that selected
It's Alive!
  • Retired
  • AKA Daniel
« Reply #14 on: April 15, 2009, 12:32:01 AM »
Ok , let me try your tips
