Here ya go, Kelie.
' Returns the AutoCAD Product Key
Private Function VBA_Acad_Product_Key() As String
On Error Resume Next
' Code suggested by Tony Zanzillo & Autodesk as posted by Laurie Comerford.
' Note that the code posted in 2005 does not appear to work in the 2009 products, edited to work
' in 2009 and also to output similar results as the Lisp function (vla-product-key) by Jeff Mishler
Dim oReg As Object
Dim sVer1 As String
Dim sVer2 As String
Dim sver3 As String
Dim sProduct As String
Set oReg = CreateObject("WScript.Shell")
sVer1 = oReg.RegRead("HKEY_CURRENT_USER\SOFTWARE\Autodesk\Autocad\curver")
sVer2 = oReg.RegRead("HKEY_CURRENT_USER\SOFTWARE\Autodesk\Autocad\" & sVer1 & "\curver")
'sver3 = "HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\Autocad\" & sVer1 & "\" & sVer2 & "\ProductName"
' ' As well as product name, there are a whole series of other aspects of AutoCAD which can be recovered with this code
'' In 2009 the 2 CurVer keys are found under Current_User NOT Local_Machine as was posted. However, the Key "ProductName" IS in HKLM.
''sProduct = oReg.RegRead(sver3)
''Edited to return the key instead of the Product Name.
sver3 = "SOFTWARE\Autodesk\Autocad\" & sVer1 & "\" & sVer2
sProduct = sver3
Set oReg = Nothing
If Err <> 0 Or sProduct = "" Then
Err.Clear
GoTo CantFindAutoCAD
End If
VBA_Acad_Product_Key = sProduct
Exit Function
CantFindAutoCAD:
sProduct = "Unable to find AutoCAD in the computer registry." & vbCrLf
MsgBox sProduct, vbCritical
End Function ' VBA_Acad_Product_Key
