Author Topic: My Overrule Sample  (Read 6434 times)
It's Alive!
  • BricsCAD
  • AKA Daniel
My Overrule Sample
« on: April 10, 2009, 01:09:27 AM »
Seems to work  :-o
.h
#pragma once
class DrawableOverrule : public AcGiDrawableOverrule
public:
  DrawableOverrule(void);
  virtual ~DrawableOverrule(void);
  virtual Adesk::Boolean worldDraw(AcGiDrawable* pSubject, AcGiWorldDraw * wd);
  virtual Adesk::UInt32 setAttributes (AcGiDrawable* pSubject, AcGiDrawableTraits * traits);
  virtual bool isApplicable(const AcRxObject* pOverruledSubject) const;
.cpp
#include "StdAfx.h"
#include "DrawableOverrule.h"
DrawableOverrule::DrawableOverrule(void)
DrawableOverrule::~DrawableOverrule(void)
Adesk::Boolean DrawableOverrule::worldDraw(AcGiDrawable* pSubject, AcGiWorldDraw * wd )
  if(pSubject == NULL) {  return Adesk::kFalse; }
  if(wd == NULL) { return Adesk::kFalse; }
  if(pSubject->isKindOf(AcDbPolyline::desc()))
    AcDbPolyline *pLine = AcDbPolyline::cast(pSubject);
    if(pLine == NULL) { return Adesk::kFalse; }
    if(!__super::worldDraw(pLine,wd)) { return Adesk::kFalse; }
    AcCmEntityColor oldc = wd->subEntityTraits().trueColor();
    AcCmEntityColor color;
    if(color.setColorIndex(1) != eOk) { return Adesk::kFalse; }
    wd->subEntityTraits().setTrueColor(color);
    wd->subEntityTraits().setLineWeight(AcDb::kLnWt000);
    AcDbVoidPtrArray ents;
    if(pLine->getOffsetCurves(2.0,ents) != eOk) { return Adesk::kFalse; }
    if(pLine->getOffsetCurves(-2.0,ents) != eOk) { return Adesk::kFalse; }
    for(int i =  0; i < ents.length() ; i++)
      AcDbEntity *tmp = reinterpret_cast<AcDbEntity*>(ents[i]);
      if(tmp->worldDraw(wd) != eOk)
        // sometimes this fails but I don't know why?? ok no crash;
        // acutPrintf(_T("\nFailed@tmp->worldDraw(wd)"));
      delete tmp;
    wd->subEntityTraits().setTrueColor(oldc);
    return Adesk::kTrue;
Adesk::UInt32 DrawableOverrule::setAttributes( AcGiDrawable* pSubject, AcGiDrawableTraits * traits )
  if(!__super::setAttributes(pSubject,traits)) { return Adesk::kFalse; }
  AcDbEntity *pLine = AcDbEntity::cast(pSubject);
  if(!pLine->isWriteEnabled())
    AcDbObjectId id;
    if(acdbOpenAcDbEntity(pLine,id,AcDb::kForWrite) == eOk)
     AcCmColor color;
     color.setColorIndex(1);
     pLine->setColor(color);
     pLine->setLineWeight(AcDb::kLnWt000);
     pLine->downgradeOpen();
// Note Autodesk should be consistent on using bool, Adesk::Boolean
bool DrawableOverrule::isApplicable( const AcRxObject* pOverruledSubject ) const
  if(pOverruledSubject->isKindOf(AcDbPolyline::desc()))
    AcDbPolyline *pLine = AcDbPolyline::cast(pOverruledSubject);
    // conditions we don't like
    if(pLine == NULL)                         { return false; }
    if(pLine->objectId().isNull())            { return false; }
    if(!pLine->objectId().isValid())          { return false; }
    if(!pLine->objectId().isResident())       { return false; }
    if(!pLine->isReadEnabled())               { return false; }
    if(pLine->isErased())                     { return false; }
    // condtions we like
    if(_tcscmp(pLine->layer(), _T("0")) == 0) { return true;  }
  return false;
edit bug
« Last Edit: April 10, 2009, 02:06:58 AM by Daniel »
It's Alive!
  • BricsCAD
  • AKA Daniel
Re: My Overrule Sample
« Reply #1 on: April 10, 2009, 01:13:23 AM »
and the command
static int setLwDisplay(int flag)
   resbuf rb;
   rb.restype = RTSHORT;
   rb.resval.rint = flag;
   return acedSetVar(_T("LWDISPLAY"),&rb);
 static int getLwDisplay(int flag)
   resbuf rb;
   acedGetVar(_T("LWDISPLAY"),&rb);
   return rb.resval.rint;
 static void enableOverrule(Adesk::Boolean flag)
   setLwDisplay(flag);
   DrawableOverrule::setIsOverruling(flag);
   acedCommand(RTSTR,_T("REGEN"),0);
 static void ArxAcGiDrawable_doit(void)
   DrawableOverrule::addOverrule(AcDbPolyline::desc(),drawableOverrule,Adesk::kTrue);
   enableOverrule(Adesk::kTrue);
 static void ArxAcGiDrawable_undoit(void)
   enableOverrule(Adesk::kFalse);
   DrawableOverrule::removeOverrule(AcDbPolyline::desc(),drawableOverrule);
edit, added the solution and Arx
« Last Edit: April 10, 2009, 07:31:43 AM by Daniel »
pkohut
« Reply #2 on: April 10, 2009, 01:18:51 AM »
Is this a derived entity?  What version of AC is the screen shot from?
Send me a PM w/ email addy, I've got something you might like.
Paul
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #3 on: April 10, 2009, 01:22:11 AM »
Itís the new feature in Acad 2010, where you can overrule how an entity draws
See this link
pkohut
« Reply #4 on: April 10, 2009, 01:31:55 AM »
Cool I get it now (mostly, have to study code some more), thanks.
Paul
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #5 on: April 10, 2009, 02:10:35 AM »
DoH! had a bug.
if you use the ArxAcGiDrawable.arx
the command is doit to load
draw a few polylines
and undoit to unload
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #6 on: April 10, 2009, 02:30:05 AM »
hehe before and after 8-)
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #7 on: April 10, 2009, 08:53:36 AM »
add a circle at every vertex  :laugh:
    for(unsigned int j = 0 ; j < pLine->numVerts() ; j++)
      AcGePoint3d cp;
      if(pLine->getPointAt(j,cp) == eOk)
        AcDbCircle *pCircle = new AcDbCircle(cp, AcGeVector3d(0,0,1), 1.0);
        pCircle->worldDraw(wd);
        delete pCircle;
      AcDbPolyline *tmp = reinterpret_cast<AcDbPolyline*>(ents[i]);
      tmp->worldDraw(wd);
      delete tmp;
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #8 on: April 10, 2009, 09:47:32 AM »
last one for now  :lol:
    AcDbVoidPtrArray ents1;
    AcDbVoidPtrArray ents2;
    if(pLine->getOffsetCurves(2.0,ents1) != eOk) { return Adesk::kFalse; }
    if(pLine->getOffsetCurves(-2.0,ents2) != eOk) { return Adesk::kFalse; }
    for(int i =  0; i < ents1.length() ; i++)
      AcDbPolyline *tmp = reinterpret_cast<AcDbPolyline*>(ents1[i]);
      for(unsigned int j = 0 ; j < tmp->numVerts() ; j++)
        AcGePoint3d cp;
        tmp->setBulgeAt(j, 0.1);
      tmp->worldDraw(wd);
      delete tmp;
    for(int i =  0; i < ents2.length() ; i++)
      AcDbPolyline *tmp = reinterpret_cast<AcDbPolyline*>(ents2[i]);
        AcGePoint3d cp;
        tmp->setBulgeAt(j, -0.1);
      tmp->worldDraw(wd);
      delete tmp;
Spike Wilbury
« Reply #9 on: April 11, 2009, 12:27:33 PM »
That looks pretty good, to bad I still don't have this version of AutoCAD to play.
ahlzl
« Reply #10 on: April 12, 2009, 12:02:04 AM »
I am Daniel's fans!
« Reply #11 on: April 12, 2009, 12:54:50 AM »
I am Daniel's fans!
I understand what you're saying.
I have this thing for Elle Macpherson, but she can't  programme very well at all  ...
--> Donate to theSwamp<--
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #12 on: April 12, 2009, 10:03:11 AM »
Me Too!  :laugh:
Spike Wilbury
« Reply #13 on: April 12, 2009, 11:29:03 AM »
Elle Macpherson
I can be a fan of her too. :)
BTW, Tony Tanzillo just posted a C# sample about this new feature here:
autodesk.autocad.customization.dotnet
The link below includes a simple example of using the Overrule Api
in a way that will not bog down AutoCAD performance (mainly during
object dragging).
    http://www.caddzone.com/OverruleSample.zip
See the included code comments for the theory/explanation about
performance issues that will occur when this API is used incorrectly.
It's Alive!
  • BricsCAD
  • AKA Daniel
« Reply #14 on: April 12, 2009, 08:40:56 PM »
Yeah, I didnít follow Kean on Tonyís point either, I made mine for Polylines only, here.
ARX also has far more control over the API than .NET does because you can override the isApplicable method.
One of the issues that I ran into was creating entities of the same type inside the worldDraw method,
which could cause end endless loop if not handled correctly.
