Author Topic: What am I doing wrong?  (Read 3334 times)
whdjr
« on: October 19, 2004, 09:24:05 AM »
I am trying to read data from a dwg that is open, but may or may not be active.  I am using the vla-item method to acces one of the dwg's from the documents collection, but my syntax is wrong or something.  I not sure.  Could you guys help me out?
;*docs* = (vla-get-documents (vlax-get-acad-object))
;document = "Y:\\Common\\Projects\\School\\0303\\index of drawings.dwg"
(vla-item *docs* document)
Please help me?
whdjr
« Reply #1 on: October 19, 2004, 09:38:00 AM »
Ok
I managed to get this to work, but is there a away to not have to use strcat?
(vla-item *docs* (strcat (vl-filename-base document) ".dwg"))
  • Custom Title
« Reply #2 on: October 19, 2004, 09:38:32 AM »
Try this;
(setq docs (vla-get-documents (vlax-get-acad-object)))
(vlax-for dwg docs
  (setq doc_lst (cons (vla-get-name dwg) doc_lst))
; doc_lst = ("ARC.dwg" "0104-296.dwg" "710-151.dwg")
(setq dwg1 (vla-item docs (last doc_lst)))
; dwg1 = #<VLA-OBJECT IAcadDocument 01117570>
  • Custom Title
« Reply #3 on: October 19, 2004, 09:40:22 AM »
The dwg is loaded into acad right?
whdjr
« Reply #4 on: October 19, 2004, 09:44:33 AM »
Mark,
I knew I could use vlax-for I just didn't want to have to iterate through the docs because I knew the file I wanted and it is loaded.
SMadsen
« Reply #5 on: October 19, 2004, 09:57:20 AM »
I think what Mark was trying to tell is that when using VLA-ITEM by name, it should be the name without path - as returned by the document's Name property.
So your strcat and filename-base thingie would be a proper way to extract the name.
whdjr
« Reply #6 on: October 19, 2004, 10:02:37 AM »
Thanks guys.
I appreciate the responses.
  • Custom Title
« Reply #7 on: October 19, 2004, 10:07:20 AM »
Also;
(reverse
  (vlax-for dwg docs
; doc_lst = ("710-151.dwg" "0104-296.dwg" "ARC.dwg")
; we know we want "710-151.dwg" so how about this
(setq this_dwg (vla-item docs (vl-position "710-151.dwg" doc_lst)))
« Reply #8 on: October 19, 2004, 10:13:53 AM »
Ok Stig.. you lost me on that ....tis ok ... I frequently get lost .....
After looking at it a little closer I think I understand now .....
and you are correct strcat with filename-base is the short way around the problem.
