Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
Home
Help
Login
Register
TheSwamp
Code Red
VB(A)
Topic:
Using UNDO with VBA
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Using UNDO with VBA (Read 3029 times)
iliekater
Guest
Using UNDO with VBA
on:
April 05, 2009, 06:35:46 AM »
Is there a way to use the UNDO command through VBA ? Well , at the end if there is no other way , I can still send the Lisp version to the command line and do my job , but I would like to do it with VBA .
Logged
Bob Wahr
Guest
Re: Using UNDO with VBA
Reply #1 on:
April 05, 2009, 10:13:08 AM »
Don't have it available to chech ATM. Worst case you can use sendcommand.
Logged
Dnereb
Guest
Reply #2 on:
April 07, 2009, 04:31:25 PM »
Worst case... is only case.
Unless you did something in lisp or VBA you can retrieve, the sendcommand would be the only option.
If not you could log all Lisp or VBA executions. and reverse them by reading your log file.
Note: this would be a good way to procede all vba/vb.net executions anyways.
Logged
Glenn R
Guest
Reply #3 on:
April 08, 2009, 04:38:41 PM »
You can set undo marks though:
ThisDrawing.StartUndoMark
ThisDrawing.EndUndoMark
Logged
iliekater
Guest
Reply #4 on:
May 03, 2009, 04:34:57 AM »
OK , thank you all for your replies .
Logged
Print
Pages: [
1
Go Up
« previous
next »
TheSwamp
Code Red
VB(A)
Topic:
Using UNDO with VBA
