Author Topic: Macros for error messages  (Read 6518 times)
It's Alive!
  • Retired
  • AKA Daniel
« on: April 03, 2009, 12:31:08 PM »
Does anybody use macros to make things a little easier checking the status of functions?
If so do you have a cool one to share?
I.e.
#define MSGNOK(statement)  { Acad::ErrorStatus st = (statement); if (st != Acad::eOk)\
  acutPrintf(_T("\nError: Line %ld [%s]\nIn function %s"),\
  __LINE__, acadErrorStatusText(st),_T(__FUNCTION__));}
static void ArxAcGiDrawable_undoit(void)
   enableOverrule(Adesk::kFalse);
   MSGNOK(AcRxOverrule::removeOverrule(AcDbLine::desc(),NULL));
Retired
Spike Wilbury
Re: Macros for error messages
« Reply #1 on: April 03, 2009, 01:33:49 PM »
Not me.....  :-)
It's Alive!
  • Retired
  • AKA Daniel
« Reply #2 on: April 03, 2009, 09:55:25 PM »
Seems pretty neat, I will party with these for a while and see how it works
define ISEOKRET(statement)  { Acad::ErrorStatus st = (statement); if (st != Acad::eOk){\
  __LINE__, acadErrorStatusText(st),_T(__FUNCTION__)); return st; }}
#define ISEOKMSG(statement)  { Acad::ErrorStatus st = (statement); if (st != Acad::eOk)\
« Last Edit: April 04, 2009, 11:13:47 AM by Daniel »
Retired
Spike Wilbury
« Reply #3 on: April 03, 2009, 10:27:45 PM »
#define ISEOK(statement)  { Acad::ErrorStatus st = (statement); if (st != Acad::eOk)\
#define ISOKMSG(statement)  { Acad::ErrorStatus st = (statement); if (st != Acad::eOk)\
I have seen them, but so far no need of them :-(
inline int
EOK(Acad::ErrorStatus arg)
return arg == Acad::eOk;
Acad::ErrorStatus es;
es = acdbOpenObject(pBlockRef, blkRefIds[i], AcDb::kForWrite);
if (!EOK(es))
break;
inline AcDbDatabase *
CURDB()
return acdbHostApplicationServices()->workingDatabase();
AcDbBlockTablePointer pBlockTable(CURDB(), AcDb::kForRead);
#define ASSERTREADENABLED \
HRESULT _hr; \
if FAILED(_hr=assertReadEnabled()) \
return _hr;
#define ASSERTWRITEENABLED \
HRESULT _hr; \
if FAILED(_hr=assertWriteEnabled()) \
return _hr;
hmm.... now that I recall, had used them once.... some years ago - if I found more here on my samples will post them.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #4 on: April 03, 2009, 10:36:12 PM »
I guess for most, it’s ok just to return an error status, but for noobs like me, I need to be pointed to the exact line in the code where the problem took place. I guess I could use ASSERT, but that’s no fun either  :|
something like this
Acad::ErrorStatus
DatabaseTools::AddToModelSpace(AcDbEntity *pEntity, AcDbObjectId &ID, AcDbDatabase *pDb)
  if(pEntity == NULL) { ISEOKRET(Acad::eNullEntityPointer); }
  AcDbBlockTable *pBlockTable = NULL;
  AcDbBlockTableRecord  *pBlockTableRecord = NULL;
  es = pDb->getSymbolTable(pBlockTable, AcDb::kForRead);
  ISEOKRET(es);
  es = pBlockTable->getAt(ACDB_MODEL_SPACE, pBlockTableRecord,AcDb::kForWrite);
  pBlockTable->close();
  ISEOKRET(es);
  es = pBlockTableRecord->appendAcDbEntity(ID, pEntity);
  ISEOKMSG(es);
  es = pEntity->close();
  ISEOKMSG(es);
  es = pBlockTableRecord->close();
  ISEOKMSG(es);
  return es;
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #5 on: April 03, 2009, 10:39:40 PM »
Makes the code cryptic though
Retired
MickD
  • (x-in)->[process]->(y-out)
« Reply #6 on: April 03, 2009, 10:40:10 PM »
Macros, while generally avoided in C++ are a very powerful coding tool and can save you quite a lot of hand coding, the only down side is they can make code seem a bit cryptic if you don't know how they work. ARX uses quite a lot of macros too, particularly with custom objects to fill in a lot of the boiler plate code, once you understand that they are simply a preprocessing tool to write code for you automatically rather than some special compiled code they are actually pretty neat. Sort of like code snippets but they fill in the 'blanks' for you.
"The E in Javascript stands for 'easy'." ó Florin Pop tweet
MickD
« Reply #7 on: April 03, 2009, 10:40:45 PM »
good timing their Daniel :)
Spike Wilbury
« Reply #8 on: April 03, 2009, 10:43:37 PM »
the macros looks ugly.... I simple end up using something like this for example:
static AcDbObjectId AddEntityToDataBase(AcDbEntity *pEnt, Adesk::UInt16 color = 7)
AcDbObjectId pOutputId = AcDbObjectId::kNull;
AcDbDatabase* pDb = acdbHostApplicationServices()->workingDatabase();
AcDbBlockTableRecordPointer pBTR(pDb->currentSpaceId(), AcDb::kForWrite);
if (pEnt && Acad::eOk == pBTR.openStatus())
pEnt->setDatabaseDefaults();
pEnt->setColorIndex(color);
pBTR->appendAcDbEntity(pOutputId, pEnt);
pEnt->close();
return pOutputId;
or the well known....
bool postToDatabase (AcDbObjectId blkName, AcDbEntity *pEntity)
AcDbBlockTableRecordPointer pBlk(blkName, AcDb::kForWrite);
if (pBlk.openStatus() != Acad::eOk) return (false);
return (pBlk->appendAcDbEntity(pEntity) == Acad::eOk);
The coding looks cleaner.... IMO
Spike Wilbury
« Reply #9 on: April 03, 2009, 10:45:58 PM »
and lately I started to do something like:
static void AddEntityToDataBase(AcDbEntity *pEnt, AcDbObjectId &pOutputId, Adesk::UInt16 color = 7)
pEnt->close();
It's Alive!
  • Retired
  • AKA Daniel
« Reply #10 on: April 03, 2009, 11:01:59 PM »
Iím starting on a application thatís going to be fairly large, maybe a hundred thousand lines of code or more,
so Iím just trying to get a handle on error handling up front. Any advice on this topic is appreciated  :mrgreen:
Retired
« Reply #11 on: April 03, 2009, 11:07:49 PM »
Iím starting on a application thatís going to be fairly large, maybe a hundred thousand lines of code or more ... any advice on this topic is appreciated :mrgreen:
Engineering Technologist ē CAD Automation Practitioner
cadanalyst@gmail.com ē http://cadanalyst.slack.com ē http://linkedin.com/in/cadanalyst
It's Alive!
  • Retired
  • AKA Daniel
« Reply #12 on: April 03, 2009, 11:15:11 PM »
Big time! Espresso with a red bull chaser + a shot of ibuprofen
Retired
It's Alive!
  • Retired
  • AKA Daniel
« Reply #13 on: April 03, 2009, 11:33:20 PM »
One side effect of doing this is multiple error messages, .. Stack trace ?
Retired
MickD
« Reply #14 on: April 03, 2009, 11:38:04 PM »
I can't find the link I'm looking for but it was something like 'writing effective C' but a quick search failed to locate it, it's more C based but very helpful and covers errors and macros among other things.
Have a look at the ARX macros (go to definition) to see how they do the hard work, basically you write the macro once with 1 or more keywords that are replaced with the keywords used when calling the macro, basically the preprocessor replaces the macro with the code (this may be many lines!) the macro represents in it's place on the fly which saves quite a lot of typing and possible mistakes.
