Author Topic: How to delete "" nil in the list (1245 "" "add" (1 "" 2 nil "" 3 5 "" nil 6 "" 8  (Read 14418 times)
SomeCallMeDave
When the list is:
 (list 1245 "" nil "add" "" (list 1 "" 2 nil "" 3 5 "" nil 6 "" 8 9 (list 888 888 "" nil 9999 9999 nil "") 555 "" nil 666) 777 "" nil 77777)
Scope creep   :-D
Back to my little drawing board
(defun killer-n (x a)
    (if (atom x)
      (if (not (eq a x)) x)
      (vl-remove-if 'null
(cons (killer-n (car x) a)
            (killer-n (cdr x) a)))))
Thanks for 'getting w/the program', :lol:. Unfortunately it crashes when using the original poster's data. :(
my variant:
(defun f (l)
 (cond ((null l) nil)
       ((atom l) (list l))
       ((listp l) (append (f (car l)) (f (cdr l))))
 ) ;_  cond
) ;_  defun
Very pretty Evgeniy :), but flattens the list instead of merely removing the nils :oops:.
ElpanovEvgeniy
  • Moscow (Russia)
I have not truly understood a problem, I am corrected...
(defun f (l)
 (if l
  (if (listp l)
   (if (car l)
    (cons (f (car l)) (f (cdr l)))
    (f (cdr l))
   ) ;_  if
   l
  ) ;_  if
 ) ;_  if
ElpanovEvgeniy
  • Moscow (Russia)
variant 2:
(defun f (l)
 (cond ((not l) nil)
       ((atom l) l)
       ((and (listp l) (car l)) (cons (f (car l)) (f (cdr l))))
       ((f (cdr l)))
 ) ;_  cond
*Ack* i didnt see that dot. I'll get back to it when i put out a fire or two.
Your right, nice puzzle.
Very nicely done Evgeniy: both variants 1 & 2.
variant 2:
(defun f (l)
 (cond ((not l) nil)
       ((atom l) l)
       ((f (cdr l)))
 ) ;_  cond
Can be reduced to:
(defun f (l)
        ((null l) nil)
        ((atom l) l)
        ((car l) (cons (f (car l)) (f (cdr l))))
        ((f (cdr l)))
ElpanovEvgeniy
  • Moscow (Russia)
Can be reduced to:
(defun f (l)
        ((null l) nil)
        ((atom l) l)
        ((f (cdr l)))
Very nicely reduced.
Excellent work!
Not only does the OP want to remove nil but also "" 8-)
lol, missed that salient point.
Evgeny's would be easy to modify to suit, but revising my own submission:
(defun deflate ( x / a )
        ((atom x) x)
        ((null (vl-consp x)) (if (vl-every 'atom x)(vl-remove-if 'null x)(mapcar 'deflate x)))
        ((and (setq a (car x))(/= a "")) (cons (deflate a) (deflate (cdr x))))
        ((deflate (cdr x)))
Here's a more generic function using Evgeny's submission as a starting point:
(defun remove_all ( x lst / a )
        ((member x lst) nil)
        ((atom x) x)
        ((member (setq a (car x)) lst) (remove_all (cdr x) lst))
        ((cons (remove_all a lst) (remove_all (cdr x) lst)))
(setq lst '(1245 "" "add" (1 "" 2 nil "" 3 5 "" nil 6 "" 8 . 9)))
(remove_all lst '(nil ""))
=> (1245 "add" (1 2 3 5 6 8 . 9))
I reserve the right to reverse the order of the arguments; at present doesn't feel right, but gotta get back to work.
Now named properly, and arguments in proper order (in my mind anyway): :ugly:
(defun remove_items ( items lst / a )
        ((member lst items) nil)
        ((atom lst) lst)
        ((member (setq a (car lst)) items) (remove_items items (cdr lst)))
        ((cons (remove_items items a) (remove_items items (cdr lst))))
(remove_items '(nil "") lst)
gile
  • Marseille, France
More generic, using a predicate function
(defun nest-remove-if (fun lst / a )
        ((apply fun (list lst)) nil)
        ((atom lst) lst)
        ((apply fun (list (setq a (car lst)))) (nest-remove-if fun (cdr lst)))
        ((cons (nest-remove-if fun a) (nest-remove-if fun (cdr lst))))
_$ (setq lst  (list 1245 "" nil "add" "" '(1 "" 2 nil "" 3 5 "" nil 6 "" 8 . 9)))
(1245 "" nil "add" "" (1 "" 2 nil "" 3 5 "" nil 6 "" 8 . 9))
_$ (nest-remove-if '(lambda (x) (member x '("" nil))) lst)
_$ (nest-remove-if 'numberp lst)
("" nil "add" "" ("" nil "" "" nil ""))
Spike Wilbury
after seeing the last functions posted.... I start to remember the x-arch or reni urban site days.... they look to close (and I am not saying that were copied eh!) :)
