Author Topic: PDF plot utility for pages layed out in MSpace  (Read 3197 times)
rhino
« on: March 28, 2009, 10:37:38 PM »
This is the PDF version of code posted here
http://www.theswamp.org/index.php?topic=27682.msg335680#msg335680
;  Plot PDF - PDF Plot Utility © CJC aka 'RHINO' 28/03/2009 ;
; This routine lets the user window select 'views' of page layouts in Model Space and then plots each ;
; view to a PDF file ;
; - Limitations : Currently works for ModelSpace only ;
; - Printer driver used : DWG to PDF.pc3 ;
; - Paper Size : ISO expand A3 (420.00 x 297.00 MM) ;
; - Plot Orientation : Landscape ;
; - Plot Output Location : /ThisDrawingFileDirPath/ThisDrawingFileName-Page-#.pdf ;
; Note- ;
; It is advisable to modify the custom properties of "DWG to PDF.pc3" plot driver to the following: ;
; - Uncheck "Open in PDF viewer when done" (does not open each plotted file in PDF viewer) ;
; - Uncheck "Include Layer Information"    (depends on user requirement) ;
(defun c:pdf (/) (c:plot_pdf))
(defun c:plot_pdf (/ usercmd userosm space dir_path dwg_name pages pdf_name cntr pg# plot *error* )
(defun *error* (msg)
    (if (not
          (member msg '("console break" "Function cancelled" "quit / exit abort" "" nil))
    (and usercmd (setvar "cmdecho" usercmd)
userosm (setvar "osmode" userosm)
  ) ; end error function
; routine starts here
  (setq usercmd (getvar "cmdecho")
userosm (getvar  "osmode")
  (setq space (getvar "tilemode"))
  (if (= space 0)
      (prompt "\nCurrently this utility does not support plots from PaperSpace!
\nYou may use the AutoCAD Publish command instead "
    ); end if modelspace = false
  (if (= space 1)
  (setvar "cmdecho"  0)
  (setvar "osmode"   1)
  (setq dir_path (getvar "dwgprefix")
dwg_name (getvar "dwgname"))
  (princ "\nThis routine will plot each page layout to PDF file(s)
  \nThe pdf file(s) will be saved to: /ThisDrawingFileDirPath/ThisDrawingFileName-Page-#.pdf
  \nAny file with the same name will be overwritten!"
  (initget 7)
  (setq pages (getint "\nPlease Input the # of unique pages for plotting: "))
  (setq cntr 1)
    (while (<= cntr pages)
      (setq pg# (strcat "Page-"(itoa cntr)""))
(prompt
   (strcat "\nSelect each page to set plot view (Page-"(itoa cntr)") : ")
(command "_-view" "_window" pg# pause pause)
(setq cntr (1+ cntr))
  ) ;end view creation loop
  (initget "Yes No")
    (setq plot (getkword
      (strcat "\n"(itoa (1- cntr))" page views have been created...proceed with plot? [Yes/No] <Yes>: ")))
      (or plot (setq plot "Yes"))
  (if (= plot "Yes")
      (setq cntr 1)
pdf_name (strcat dir_path (substr dwg_name 1 (- (strlen dwg_name) 4)) " - " pg# ".pdf")
    (command "._-plot"
"_yes"
"DWG to PDF.pc3"
"ISO expand A3 (420.00 x 297.00 MM)"
"_millimeters"
"_landscape"
"_no"
"_view"
pg#
"_fit"
"_center"
"_yes"
"monochrome.ctb"
"_yes"
"as"
pdf_name
"_No"
"_Yes"
) ;end plot loop
     (prompt
       (strcat "\n"(itoa (1- cntr))" Pages successfully plotted! "))
     (prompt "\nCreated by CJC aka 'RHINO'")
     ); end if modelspace = true
  (*error* "")
  (prompt "\n plot_pdf is now available - type <pdf> to run! ")
