Author Topic: How to list all the blocks in a directory form?  (Read 6022 times)
highflyingbird
  • Later equals never.
« on: March 26, 2009, 09:25:18 PM »
In a dwg file,there are a lot of blocks.  Some blocks is nested. How to list all the blocks in a directory form?
for example ,These are blocks: "1" "2" "3" "4" "5" "6" "7"; "7" in "6","6" "5" in "4", "4"  "3" "2" in "1";
this function return value likes below:
("1" ("2" "3"  ("4"  ("5" ("6" ("7"))))))
How to get it?
Actually, I found  a way to list all the nested blocks in a Insert.But for this ,I have no idea...
I am a bilingualist,Chinese and Chinglish.
Re: How to list all the blocks in a directory form?
« Reply #1 on: March 26, 2009, 11:34:10 PM »
If you want to flatten the list this will help:
http://www.theswamp.org/index.php?topic=4064.0
Otherwise I'm lost. 8-)
I've reached the age where the happy hour is a nap. ()
« Reply #2 on: March 26, 2009, 11:50:15 PM »
I believe he wants the opposite of flattening Alan (a block def tree), but I could be wrong. :)
Simply walk thru each block definition collection (starting with the master blocks collection), recursively drilling into, and then out of each nested definition, indenting, and then de-indenting accordingly | appropriately before printing the block collection names. Should be 50 lines of code or less.
\|// Set goal. Experiment tirelessly until
|Oo| practice has become expertise.  Loop.
|- | LinkedIn | Dropbox
highflyingbird
« Reply #3 on: March 27, 2009, 12:20:15 AM »
Yes,extractly,I want a block def tree.
« Reply #4 on: March 27, 2009, 12:42:07 AM »
REALLY QUICK, REALLY DIRTY.
But should work <starting point anyway>:
(defun c:BlockDefTree ( / foo blocks )
    (defun foo ( blocks block indent )
        (repeat indent (princ "    "))
        (princ (vla-get-name block))
        (princ "\n")
        (vlax-for object block
            (if (eq "AcDbBlockReference" (vla-get-objectname object))
                (foo blocks (vla-item blocks (vla-get-name object)) (1+ indent))
    (vlax-for block
        (setq blocks
            (vla-get-blocks
                (vla-get-activedocument
                    (vlax-get-acad-object)
        (foo blocks block 0)
Tried to stretched it out but it only spans 29 lines.  :|
cjw
« Reply #5 on: March 27, 2009, 01:21:07 AM »
        (princ "\n")
    (vlax-for block
        (setq blocks
            (vla-get-blocks
Nice job! MP
Could you make this function return value likes below:
« Last Edit: March 27, 2009, 01:24:13 AM by cjw »
The slow need to start early!
« Reply #6 on: March 27, 2009, 01:29:26 AM »
Sure could but it's late. By the time I look at this thread tomorrow there will likely be 10 versions posted, so just wait a bit. :D
highflyingbird
« Reply #7 on: March 27, 2009, 02:25:23 AM »
MP,thanks a lot.
But I want the return value is a list,(I think it is a multiway tree structure), and  if a blockdef has many same name nested blockdef in it, I just want a single ,remove those Duplicates.
Ha,What a different between our time! When we are working ,you are sleeping.Have a good dream!
« Last Edit: March 27, 2009, 02:52:28 AM by highflybird »
cjw
« Reply #8 on: March 27, 2009, 02:38:03 AM »
:-D
Time difference!!!
jxphklibin
« Reply #9 on: March 27, 2009, 04:14:49 AM »
 How my codes?
(defun AllBlkNInBlkdef (blkn / blkdef e typ bn bnl e-l)
  (setq bnl '() blkdef (tblobjname "block" blkn))
  (while (setq e (entnext blkdef))
    (setq typ (cdr (assoc 0 (entget e))))
    (if (= typ "INSERT")
      (setq bn (vla-get-name (vlax-ename->vla-object e))
    bnl (if bn
  ;;(append (list (list bn (AllBlkNInBlkdef bn))) bnl)
  (cons (list bn (AllBlkNInBlkdef bn)) bnl)
      ;(setq el (cons e el))
    (setq blkdef e)
  bnl
(defun c:ABnInBl1 (/ i en ss blknlst ABblknlst)
  (setq ss   (ssget '((0 . "INSERT")))
ABblknlst '()
  (if ss
      (setq en       (ssname ss (setq i (1- i)))
    blkn      (vla-get-name (vlax-ename->vla-object en))
    blknlst   (AllBlkNInBlkdef blkn)
    ABblknlst (append (list (list blkn blknlst)) ABblknlst)
    (princ "*** 你没有选择任何图块 ***")
  ;(princ)
« Last Edit: March 27, 2009, 04:57:49 AM by jxphklibin »
highflyingbird
« Reply #10 on: March 27, 2009, 04:46:35 AM »
OK! Now I got it!
;;;Main Function
(defun c:BT (/ AllLst bkTree)
  (setq *APP (vlax-get-acad-object))
  (setq *DOC (vla-get-ActiveDocument *APP))
  (setq *BLK (vla-get-blocks *DOC))
  (vlax-for blk *BLK
    (setq AllLst (cons (GetNestedName blk) AllLst))
  (foreach n AllLst
    (setq bkTree (cons (Tree (car n)) bkTree))
  (princ bkTree) ; Now BkTree is the return value, it's a blockDef tree.
;;;Get all names of Nested Blocks in A blockDef
(defun GetNestedName (blk / lst iName)
  (vlax-for n blk
    (if (or
          (= (vla-get-objectname n) "AcDbBlockReference")
          (= (vla-get-objectname n) "AcDbMInsertBlock")
        (setq iName (vla-get-name n))
        (if (not (member iName lst))
          (setq lst (cons iName lst))
  (cons (vla-get-name blk) lst)
;;;to Construct The BlockDef Tree
(defun Tree (name / lst)
  (foreach n (cdr (assoc name AllLst))
    (setq lst (cons (Tree n) lst))
  (if lst
    (cons name (list lst))
    name
« Last Edit: March 27, 2009, 12:11:38 PM by highflybird »
« Reply #11 on: March 27, 2009, 09:10:35 AM »
I misunderstood what you wanted but it appears you have what you need now so all is good.
PS: I don't know if you've been formerly welcomed to the swamp, so 'Welcome to the swamp highflybird'.
« Reply #12 on: March 27, 2009, 01:41:49 PM »
I modded my original little contribution. It doesn't list redundant entries, makes it look like a tree of sorts, flags xrefs.
(defun c:BTree ( / walk main )
    (defun walk ( blocks block indent / names )
        (repeat (1- indent) (princ "    "))
        (if (< 0 indent) (princ "+-- "))
        (princ (if (eq :vlax-true (vla-get-isxref block)) " <XREF>\n" "\n"))
                (if (null (member (setq name (vla-get-name object)) names))
                        (setq names (cons name names))
                        (walk
                            blocks
                            (1+ indent)
    (defun main ( / blocks index )
        (princ "\n")
        (foreach block
            (mapcar 'car
                (vl-sort
                    (vlax-for block
                        (setq blocks
                            (vla-get-blocks
                                (vla-get-activedocument (vlax-get-acad-object))
                        (setq index
                            (cons
                                (cons block (vla-get-name block))
                                index
                   '(lambda (a b) (< (cdr a) (cdr b)))
            (walk blocks block 0)
    (main)
For what it's worth.
Edit: Modded so primary block collection is sorted.
« Last Edit: March 27, 2009, 03:24:43 PM by MP »
jxphklibin
« Reply #13 on: March 27, 2009, 08:46:16 PM »
Now , It is works.
(defun AllBlkNInBlkdef (blkn / blkdef e typ bn bnl e-l nl)
  (setq bnl    '()
    bnl (if bn
  (append (list(if (setq nl (AllBlkNInBlkdef bn))
    (list bn nl)
    (list bn)
  bnl
    (setq blkdef e)
  bnl
(defun c:ABnInBl (/ i en ss blknlst ABblknlst)
ABblknlst '()
  (if ss
    ABblknlst (append (list(if blknlst
(list blkn blknlst)
(list blkn)
      ABblknlst
  (princ ABblknlst)
The new modified codes ,it works very exactly:
  (setq ;bnl    '()
    bnl (if bn
  (cons (if (setq nl (AllBlkNInBlkdef bn))
    (list bn nl)
    bn
  bnl
    (setq blkdef e)
  bnl
;ABblknlst '()
  (if ss
    ABblknlst (cons (if blknlst
(list blkn blknlst)
blkn
      ABblknlst
  (princ ABblknlst)
« Last Edit: March 27, 2009, 09:19:40 PM by jxphklibin »
highflyingbird
« Reply #14 on: March 27, 2009, 09:37:06 PM »
Oh, It looks awesome ! beautiful!
