Author Topic: Define Xreffiledialog in registry  (Read 5520 times)
lamarn
« on: March 25, 2009, 06:22:08 AM »
I would like my xref manager to look (display) always in my current dir where the DWG is
The value is stored in the registry. See att.
Somehow i want to change this value this to the value of "savepathfile"
The initial value also the "savepathfile" at startup
How can this be done with lisp or VBA?
Re: Define Xreffiledialog in registry
« Reply #1 on: March 25, 2009, 11:07:30 AM »
Look at the ' vl-registry-... ' functions.  With that being said, it might not change until Acad is opened again.
lamarn
« Reply #2 on: April 08, 2009, 03:16:21 PM »
Found this in Tim Spangler's Layercreator. Should work..
(defun LC_SET_PROG (/ Temp)
;; Check for Version
(and
(LC_CHECK_REG "HKEY_CURRENT_USER\\Software\\Layer Creator" "Version"); Check that the registry key exsists
(= "v1.7" (vl-registry-read "HKEY_CURRENT_USER\\Software\\Layer Creator" "Version")); Check that the version is correct
(setq Version (vl-registry-read "HKEY_CURRENT_USER\\Software\\Layer Creator" "Version")); Set the version variable
(setq Version (vl-registry-write "HKEY_CURRENT_USER\\Software\\Layer Creator" "Version" "v1.7")); Write Version to registry
;; Check for BaseDirectory
(if (LC_CHECK_REG "HKEY_CURRENT_USER\\Software\\Layer Creator" "BaseDirectory")
(setq BaseDirectory (vl-registry-read "HKEY_CURRENT_USER\\Software\\Layer Creator" "BaseDirectory")); Check that the registry key exsists
(setq BaseDirectory (vl-registry-write "HKEY_CURRENT_USER\\Software\\Layer Creator" "BaseDirectory" (LC_FIND_FILE "Locating Layer Creator Directory" "Layer Creator" "lsp"))); Write new BaseDirectory to registry
;; Check for the LayerCreator lisp in the search path
(if (not (findfile (strcat BaseDirectory "\\LayerCreator.lsp")))
;; Check for LayerFiles folder
(setq Temp (strcat BaseDirectory "\\Layer Files"))
(if (not (vl-file-directory-p Temp))
(alert "** Layer Files folder was not found.  Add the Layer Files folder to the base directory and re-run **")
(exit)
;; Create list of .lyr files from directory w/o extension
(if (not (setq LayerGroupList (LC_GET_LAYER (strcat BaseDirectory "\\Layer Files") ".lyr")))
(alert "** No layer definition files were found **")
(exit)
;; If GBL:Current does not exsist set it
;; Variable used to make inserted layer current
(if (not GBL:Current)
(setq GBL:Current "0"); Clear "Make Layer Current" toggle
;; If GBL:Update does not exsist set it
;; Variable used to update inserted layers
(if (not GBL:Update)
(setq GBL:Update "1")
;; If LayerGroupPos does not exsist set it
;; Variable used to get position of Layer group Tile
(if (not LayerGroupPos)
(setq LayerGroupPos 0); Set LayerGroupPos variable to first group in list
;; If LayerNamePos does not exsist set it
;; Variable used to get position of Layer name tile
(if (not LayerNamePos)
(setq LayerNamePos 0); Set LayerNamePos variable to first group in list
« Reply #3 on: April 08, 2009, 04:12:25 PM »
Try putting this in your startup:
(if (not *rjp-commandreactors*)
  (setq *rjp-commandreactors* (vlr-command-reactor nil '((:vlr-commandwillstart . strtcmd))))
(defun strtcmd (calling-reactor strtcmdinfo / dp hkcu key regpath)
  (if (and (= (getvar 'dwgtitled) 1) (wcmatch (car strtcmdinfo) "*XREF,XATTACH"))
    (progn (setq dp   (getvar 'dwgprefix)
                 hkcu (strcat "HKEY_CURRENT_USER\\" (vlax-product-key))
                 key  (strcat hkcu "\\Profiles\\" (getvar 'cprofile) "\\Dialogs\\")
           (setq regpath (strcat key "XattachFileDialog"))
           (vl-registry-write regpath "InitialDirectory" dp)
           (setq regpath (strcat key "XrefFileDialog"))
lamarn
« Reply #4 on: April 10, 2009, 03:46:49 AM »
Works Great ! Save a lot of Browse time.
Could this also be done with OpenSaveAnavDialog?
(this way it would not matter if you open from the browser (double-click) or with file => open within Autocad)
« Reply #5 on: April 10, 2009, 12:04:17 PM »
Give this a whirl...it's the whole enchilada  :-D
           (wcmatch (car strtcmdinfo) "*XREF,XATTACH,*SHEET*,ETRANSMIT,OPEN")
           (setq regpath (strcat key "Sheet Set Wizard"))
           (vl-registry-write regpath "BrowseForLayoutsPath" dp)
           (vl-registry-write regpath "SheetSetCreatePath" dp)
           (setq regpath (strcat key "eTransAddFile"))
           (setq regpath (strcat key "SSMNavigator"))
           (vl-registry-write regpath "OpenSheetSetPath" dp)
           (vl-registry-write regpath "ImportLayoutsAsSheetsPath" dp)
           (setq regpath (strcat key "OpenSaveAnavDialogs"))
cyberiq
« Reply #6 on: April 10, 2009, 01:00:05 PM »
Copy the following code in your ACADDOC.LSP file. If you don't have one, just create it. If you have one and it contains a S::STARTUP function, paste it inside. The file should be in the SUPPORT folder of your AutoCAD install directory.
I wasn't able to find this registry key one neither of my AutoCAD installs (2006 French and English, 2008 French and English, 2009 English, 2010 English) and although I would suggest something more general, like
vl-registry-write
  (strcat
    "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" (getvar "cprofile") "\\Dialogs\\XrefFileDialog"
    "InitialDirectory"
    (getvar "dwgprefix")
maybe it's a better idea to try this hard coded version (copied from your posted image) first:
(vl-registry-write
  (strcat
    "HKEY_CURRENT_USER\\Software\\Autodesk\\AutoCAD\\R17.0\\ACAD-5001:409\\Profiles\\<<Unnamed Profile>>\\Dialogs\\XrefFileDialog"
    "InitialDirectory"
and if it works, you can try the first one too.
HTH
lamarn
« Reply #7 on: November 30, 2010, 04:06:04 AM »
I would like to have my 'plot to file' directory the same as my project directory.
Anyone a clue how to do this.
Somehow the code i thought could work doesn't do the job...
                 key  (strcat hkcu "\\Profiles\\" (getvar 'cprofile) "\\General\\")
           (setq regpath (strcat key "PlotToFilePath"))
« Reply #8 on: November 30, 2010, 11:34:49 AM »
Try something like this:
(vla-put-defaultplottofilepath
  (vla-get-output (vla-get-preferences (vlax-get-acad-object)))
  (getvar 'dwgprefix)
lamarn
« Reply #9 on: December 03, 2010, 02:17:53 AM »
It doesn't seem to work.
This location is not affected.. see att
« Reply #10 on: December 03, 2010, 07:20:03 AM »
Sometimes ACAD needs to be restarted to apply registry changes.
lamarn
« Reply #11 on: December 03, 2010, 07:37:02 AM »
  (getvar 'dwgprefix)
is this stored in registry?
« Reply #12 on: December 03, 2010, 07:42:23 AM »
Yes:
(getenv "PlotToFilePath")
or
(vl-registry-read (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\Initial Setup Profile\\General") "PlotToFilePath")
