Hi, i´m just starting with .NET and AutoCAD playing... so first sorry for any, 'stupid' question...
my task is that I should round up the corners of an existing polyline. Under specific Angles, there
must be a pre-defined radius that should be inserted instead of the 'corner'.
So I would appreciate if someboy could give me a hint or a small peace of rope to climb up a bit out of that swamp...
1. Question... when i draw something with 'pline', there is a display of the angle where I´m moving...
-> is there a way to get this information via API/NET ?
2. Question... is there a function/command that could be used for, let´s say 'trimming' the corner in that way I described
above and passing points/vertices etc. as rgument or do I have to split up the polyline into segments and draw an arc by
at the specific location by hand (code) ?
Sorry for my english, I hope the text is making sence
(code snippets would be appreciated)
Thanks in advance.
