Author Topic: How can you attribute the layout # into the title block?  (Read 1688 times)
Dr. After
« on: March 24, 2009, 08:31:25 AM »
I have a title block with attributes already, but would like for the value to automaticaly be there.  In the title block I have "Sheet # of #" and I would like those "#'s" to have a value in relation to the actual layout tab and total layouts.  Any help would be much appreciated!!!
Re: How can you attribute the layout # into the title block?
« Reply #1 on: March 24, 2009, 09:08:15 AM »
I think most people are using FIELDs.
Can you replace the attribute with a Field?
Otherwise you would need to build a reactor or a lisp that ran during startup.
Shinyhead
« Reply #2 on: March 24, 2009, 09:35:39 AM »
set a field for ctab.
copy paste this in to that attribute
%<\AcVar ctab>%
it will show whatever the layout tab name is then.
Dr. After
« Reply #3 on: March 24, 2009, 09:39:11 AM »
It ended up wanting to use this:  %<\AcVar ctab \f "%tc1">%
but regardless it worked great!  I hadn't toyed with "fields" yet...  Thanks guys!
« Reply #4 on: March 24, 2009, 09:55:38 AM »
looks like you want to explore Fields and Sheets Sets...a liitle further
