Author Topic: ( Challenge ) StringToBinary  (Read 10587 times)
gile
  • Marseille, France
Re: ( Challenge ) StringToBinary
« Reply #30 on: March 21, 2009, 10:21:02 AM »
However, you're returning a string, in C# you should return a string array.
It does return a string array.
Vovka's one translation
static string[] StringToBinary(string str)
    Byte[] bytes = Encoding.ASCII.GetBytes(str);
    string[] result = new string[bytes.Length];
    for (int i = 0; i < bytes.Length; i++)
        result[i] = DecToBin(bytes[i], 8);
    return result;
static string DecToBin(int dec, int len)
    return len < 2 ? (dec % 2).ToString() : DecToBin(dec / 2, len - 1) + (dec % 2).ToString();
« Reply #31 on: March 21, 2009, 10:23:21 AM »
OOPS. Sorry Gile, I shouldn't post before my first coffee; forgive me.
« Reply #32 on: March 21, 2009, 10:35:34 AM »
    return result;
Translated to Python:
def stringToBinary(s):
    bytes=list(map(ord,s)); result=[]
    for i in range(0,len(bytes)):
        result+=[decToBin(bytes[i])]
    return result
def decToBin(dec,bits=8):
    return str(dec%2) if bits < 2 else decToBin(dec//2,bits-1) + str(dec%2)
Hope you don't mind, I need the practice and this is a fun way to achieve it. :)
gile
  • Marseille, France
« Reply #33 on: March 21, 2009, 10:45:42 AM »
So do I.
gile
  • Marseille, France
« Reply #34 on: March 21, 2009, 12:11:05 PM »
Another way
LISP
(defun StringToBinary (str / d2b left0)
  (defun d2b (n i / m)
    (if (zerop (setq m (lsh n i)))
      0
      (if (zerop (rem m 2))
(d2b n (1- i))
(+ (expt 10 (- i)) (d2b n (1- i)))
  (defun left0 (s l)
    (while (< (strlen s) l) (setq s (strcat "0" s)))
  (mapcar '(lambda (x) (left0 (itoa (d2b x 0)) 8))
  (vl-string->list str)
C#
        result[i] = String.Format("{0:00000000}", dec2bin(bytes[i], 0));
    return result;
static int dec2bin(int n, int i)
    int s = n >> i;
    return s == 0 ? 0 : s % 2 == 0 ? dec2bin(n, i + 1) : (int)Math.Pow(10, i) + dec2bin(n, i + 1);
« Last Edit: March 21, 2009, 12:14:22 PM by gile »
« Reply #35 on: March 21, 2009, 12:54:08 PM »
    return result;
    int s = n >> i;
Converted to Python:
        result+=[bin(bytes[i])[2:].zfill(8)]
    return result
Revising one of my earlier submissions:
    return list(map(lambda a: bin(ord(a))[2:].zfill(8),s))
:D
« Reply #36 on: March 21, 2009, 01:13:51 PM »
    return result
If one preferred the use of a pre-allocated list rather than appending the result:
    bytes=list(map(ord,s)); result=['']*len(bytes)
        result[i]=bin(bytes[i])[2:].zfill(8)
    return result
Such a cool language. :)
« Reply #37 on: March 21, 2009, 04:03:43 PM »
Turns out I could have employed the range function more efficiently:
Original:
    for i in range([color=red]0,[/color]len(bytes)):
    return result
Improved:
    for i in range(len(bytes)):
    return result
Subtitle: If the intent is to iterate over the indexes of an indexed iterable object, there's no need to specify the lower boundary (0) because the range function will supply 0 in the absence of a specific lower bound; cool. :lightbulb:
/carry on
adalea03
« Reply #38 on: March 22, 2009, 09:52:02 AM »
While I admire the beauty of the posted examples, I'm puzzled.
So, from a "pea brained" person's perspective...Why?
What is the intended purpose?
There is occupational incentive for me to continue to learn Lisp/VL,
so can I assume that this challenge would likely be carried to the level
of implementing the code for a purpose.
And if it is "just  for the fun of it", that's okay too.
You folks amaze me.
Tony
« Reply #39 on: March 22, 2009, 10:02:22 AM »
Why? What is the intended purpose?
Not sure I understand Tony ... why bother writing binary functions? (was just for academic fun) or why am I trying to use/learn Python? (I've been wanting to learn it for years for general programming, especially web based stuff).
There is occupational incentive for me to continue to learn Lisp/VL, so can I assume that this challenge would likely be carried to the level
In my own use I've only ever penned binary functions to illuminate what happens at the binary level to those just beginning to program.
And there's this. :)
You folks amaze me.Tony
The skills of our friends from around the world are impressive and I'm glad they've decided to hang their hats here and share their expertise. We all win.
« Last Edit: March 22, 2009, 10:26:20 AM by MP »
adalea03
« Reply #40 on: March 22, 2009, 11:21:19 AM »
So very true (re:all winning ).
It is for that dose of commaraderie and the display of those "impressive skills" that I return when I can.
(to see, that is; I have none to disply, yet.)
I still wonder; Is Python a language that is effective for Acad?
Tony
hermanm
« Reply #41 on: April 05, 2009, 03:39:12 PM »
OK, old thread, but here is my entry:
;;using lambda function - no apparent speed advantage to named function call
(defun string->bin_strings (str / )
  (mapcar '(lambda (str / mask out)
            (setq out "" mask 128)
              (repeat 8
                (if (zerop (logand arg mask))
                  (setq out (strcat out "0"))
                  (setq out (strcat out "1"))
              (setq mask (/ mask 2))
            out
   (vl-string->list str))
After I got past this garbage:
;;naive iterative version - 8 bits - a real dog
(defun byte->bin_string (arg / n out power2)
   (setq n 8 out "")
   (repeat 8
      (setq n (1- n)
            power2 (expt 2 n))
      (if (>= arg power2)
                arg (- arg power2))
   out
I tried 3 ways of doing basically the same thing:
;;iterative - using logand from high bit - much faster than first one (no surprise)
(defun int->bin_string-l (arg / mask out)
   (repeat 8
   out
;;iterative - using logand from low bit - slightly slower than above!
(defun int->bin_string-r (arg / mask out)
   (setq out "" mask 1)
   (repeat 8
        (setq out (strcat "0" out))
        (setq out (strcat "1" out))
      (setq mask (* mask 2))
   out
;;iterative - using logand & lsh from low bit - slower than using multiply!
(defun int->bin_string-lsh (arg / mask out)
   (repeat 8
      (setq mask (lsh mask 1))
   out
Test results using BenchRRB by Robt. Bell:
Note: -> results not 100% repeatable - I am not sophisticated enough to know why
So, I suggest running the same test multiple times (like, 5 or 6)
(This could be a whole 'nother topic)
Command: (bench '(int->bin_string-l int->bin_string-r int->bin_string-lsh)
(_> '(255) 1000)
INT->BIN_STRING-L
Elapsed: 15
Average: 0.0150
INT->BIN_STRING-R
Elapsed: 16
Average: 0.0160
INT->BIN_STRING-LSH
Elapsed: 32
Average: 0.0320
Test of posted complete functions:
;;;timing using BenchRRB <- not 100% consistent - must run multiple times
Command: (bench '(_strtobin eea-str2bin stringtobinary-tw stringtobinary-gile
('(_> string->bin_strings) '("ABCD") 1000)
_STRTOBIN - MP
Elapsed: 110
Average: 0.1100
EEA-STR2BIN
Elapsed: 79
Average: 0.0790
STRINGTOBINARY-TW
Elapsed: 78
Average: 0.0780
STRINGTOBINARY-GILE - 1st Post
Elapsed: 94
Average: 0.0940
STRING->BIN_STRINGS
Elapsed: 78
Average: 0.0780
@ MP:
I think (expt) is slowing yours down
Yes, I see that part of your intention was to compare language solutions, so probably you could write faster LISP if you intended to only do that. Now, I am determined to explore some .NET - it is time.:)
@ Gile:
I didn't test your subsequent LISP post
@ TW:
Your entry is far from "cheesy"
@ Vovka:
Sorry, I kept getting a "cannot reenter LISP" error when I tried to wrap your nice recursion, so I had to omit yours.
Please accept my apology for not being able to find my error.
@ Evgeny:
Impressive. Concise & fast.
You da man.:)
Comments:
I would naively expect (lsh) to beat * or /. However, the results I got here agree with my past experience, that (lsh) is not as fast as one might expect, given its definition. I conclude it is implemented in a way not very close to the hardware.
hermanm
« Reply #42 on: April 05, 2009, 03:51:01 PM »
Whoops:
              (repeat 8
                (if (zerop (logand str mask))
            out
Attached: Robert Bell's "Bench" program, which I used to test speed of posted functions.
Anyone is free to dissect that, or provide a better one.
It's Alive!
  • Retired
  • AKA Daniel
« Reply #43 on: April 06, 2009, 01:59:15 AM »
mine
static int ads_stringtobinary(void)
    TCHAR outbuff[33];
    TCHAR formatedBuff[33];
    const int padding = (sizeof(int)*8+1);
    struct resbuf *pArgs =acedGetArgs () ;
    struct resbuf *pHead = acutNewRb(RTSTR);
    struct resbuf *pTail = pHead;
    while(pArgs)
      if(pArgs->restype == RTSTR)
        pTail = pTail->rbnext = acutNewRb(RTLB);
        for(int i = 0 ;i < _tcsclen(pArgs->resval.rstring) ; i++)
          pTail = pTail->rbnext = acutNewRb(RTSTR);
          _itot(pArgs->resval.rstring[i] , outbuff, 2);
          _stprintf_s(formatedBuff,sizeof(formatedBuff),_T("%08s"),outbuff);
          pTail->resval.rstring = _tcsdup(formatedBuff);
        pTail = pTail->rbnext = acutNewRb(RTLE);
      pArgs = pArgs->rbnext;
    if(pHead->rbnext) { acedRetList (pHead->rbnext); };
    acutRelRb(pHead);
    return (RSRSLT) ;
It's Alive!
  • Retired
  • AKA Daniel
« Reply #44 on: April 06, 2009, 05:26:41 AM »
my C# version
[LispFunction("StrToBin")]
    public static ResultBuffer StrToBin(ResultBuffer args)
      List<string> strings = new List<string>();
      ResultBuffer rb = new ResultBuffer();
      if (args != null)
        foreach (TypedValue tv in args)
          if (tv.TypeCode == (int)LispDataType.Text)
            strings.Add((string)tv.Value);
        strings.ForEach(S =>  new List<byte>
          (Encoding.ASCII.GetBytes(S)).ForEach
            (B => rb.Add(new TypedValue((int)LispDataType.Text,(Convert.ToString(B, 2).PadLeft(8,'0'))))));
      return rb;
