Author Topic: Read only ACAD files  (Read 10059 times)
CADaver
« Reply #15 on: October 16, 2004, 02:22:18 PM »
Quote from: MP
Indeed. Mine processed text | attribs separately (i.e. retained as text), but it sounds like you prefer the full lobotomy ('course, that makes sense given the original post). :)
I WANT them to call and complain, PLEASE call me.
Oh yes, PLEASE call me and complain about my drawings you DIMENSION-EXPLODING, EYE-BALL-DRAFTING, NOTHING-ON-COORDINATE, 3-PIECES-OF-TEXT-FOR-ONE-LINE, LINE-BREAKING-FOR-LINETYPE-DRAFTING, TITLE-BLOCK-EXPLODING, MOUTH-BREATHIN'...
... ummm ....
... excuse me, got a little carried away there...
« Reply #16 on: October 16, 2004, 02:27:12 PM »
Some might think this is an exaggerated froth. It's not. Having been a CAD Janitor for the last ten years I feel your pain and commend you for what amounts to a restrained response.
CADaver
« Reply #17 on: October 16, 2004, 02:55:39 PM »
Quote from: MP
Fortunately it's only one or two that are outside my contractual control.  But in time, they too, will be assimilated or eliminated. :twisted:
« Reply #18 on: October 17, 2004, 02:04:53 PM »
Looks like CADaver is turning into the BORG of the CAD universe....
whdjr
« Reply #19 on: October 18, 2004, 09:34:29 AM »
Quote from: CADAver
Quote from: MP
... ummm ....
Here!Here!
My sentiments exactly.[/quote]
Andrew H
« Reply #20 on: October 18, 2004, 10:41:47 AM »
I was thinking there was a way to change the access of the file (from windows explorer), but retain the ability to xref the drawing(s). I was trying it on my drawing, but with no luck. Maybe someone else knows more about this approach.
Maybe there is a way to password protect the files. Adjust the properties of the file to be read-only, then put a password on the file so that someone could still xref it, but couldn't actually modify it without the password.
Maybe someone could come up with a lisp that could do this?
CADaver
« Reply #21 on: October 18, 2004, 11:31:30 AM »
Quote from: Andrew H
Your method above works, but locks you out of your own file.
We setup directory "rights" on our network, based on discipline.   Mechanical guys can only WRITE to Mechanical directories, but they can READ everything else.  Saves a load of headaches.
Andrew H
« Reply #22 on: October 18, 2004, 11:37:43 AM »
We save our drawings to a new folder before e-mailing the current drawing to clients. That way we have a copy of the drawing exactly as the client received it and can track our changes. This fills up the server, but every so often we put the older stuff onto CDs to free up server space. One could change the rights on the saveas-ed copy and send that one (adding a password). Even if you didn't need to keep a copy of it, so the client can't change the information.
But I don't know how this would work over someone elses network, as in rights on there server. The only thing I can think of is a password.
« Reply #23 on: October 18, 2004, 12:03:41 PM »
Quote from: CADaver
That's exactly the way we have out network set up, tho us janitor types have full rights to all CAD related drives / directories; moo haa haa haa. :twisted:
CADaver
« Reply #24 on: October 18, 2004, 12:29:58 PM »
Even the password can be fooled with a SAVEAS, so the client can edit the data.
CADaver
« Reply #25 on: October 18, 2004, 12:31:04 PM »
Quote from: MP
Quote from: CADaver
yeah, only with that "priviledge" comes all the grunt work of a "janitor".
Andrew H
« Reply #26 on: October 18, 2004, 12:34:27 PM »
Hmmm... If I receive a file I can only xref (because there is a password) and I do a save as, then the new drawing (the saveas file) would still have the xref that is password protected. The password I'm thinking of wouldn't go through ACAD, but rather through windows some how. This may or may not be a possibility, but maybe worth looking into if its that important.
« Reply #27 on: October 18, 2004, 12:34:33 PM »
Quote from: CADaver
of a "janitor".
"Wet mop isle 42, we have a CADD spill. Move it, move it!"
CADaver
« Reply #28 on: October 18, 2004, 01:12:23 PM »
Opening the XREF'd file and SAVEAS a different file kills the protection.  The original file can then be replaced by the new file that is no longer protected.
Andrew H
« Reply #29 on: October 18, 2004, 02:18:01 PM »
That's true be the client would have to have the password to open the file.
