Author Topic: Filtering strings . . .  (Read 5385 times)
jbuzbee
« on: March 18, 2009, 12:02:32 PM »
How would I accomplish the following:
I read in a list of strings from a text file including blank lines - the blank lines help with reading the info:
01          INTERIOR KEYNOTES
01.001    SCHEDULED DOOR
01.002    WALL PARTITION
01.100    USE PEANUT BUTTER TO CAULK WINDOW FRAME
01.101    TEMPERED GLASS
01.200    BLH, BLAH, BLAH
02          EXTERIOR KEYNOTES
So in a listbox control I only want to show the 01 keynotes.  The code I have doesn't recognize the blank spaces so it messes up the formating.  I think I need to use a while loop to know when I've left the 01 keynotes and stop looking but can't figure it out.  I don't need code, maybe a pseudo code outline.
Thanks for any help!
James Buzbee
Windows 8
Re: Filtering strings . . .
« Reply #1 on: March 18, 2009, 12:07:49 PM »
Why not use ' wcmatch ' with a pattern of ' 01* '?
« Reply #2 on: March 18, 2009, 02:19:01 PM »
If the blank line come in as "" then use
(vl-remove "" lst-of-strings)
« Reply #3 on: March 18, 2009, 02:54:19 PM »
^^ Or dont even store it in the first place (use T.Willey's idea).
« Reply #4 on: March 18, 2009, 03:01:13 PM »
Quote from: OP
Quote from: OP
Sounds like they need the blank lines to me. :)
« Reply #5 on: March 18, 2009, 03:20:46 PM »
I though he meant that the blank line helped reading that data file when editing it.  :-o
« Reply #6 on: March 18, 2009, 03:50:30 PM »
My file reader. Reads the entire file into a list before processing the list.
;;  return only lines that start with "01"
(defun c:frtest (/ fname fn ln AllLines lst)
  (setq fname "MyFile.txt"
        prefix "01"
        pflen  (strlen prefix))
  (if (setq fn (findfile fname)) ; only if the file is found
    (progn ; fn contains the full path
      (setq fn (open fn "r")) ; open file for reading
      ;;  for speed read all the lines in the file
      (while (setq ln (read-line fn))
(setq AllLines (cons ln AllLines))
      (close fn) ; close the open file handle
      (foreach ln AllLines ; note AllLines is reversed
        ;;  remove leading and trailing tabs & spaces
        (setq ln (vl-string-trim " \t" ln))
        ;;  exclude empty & non numeric lines
        (if (and (/= ln "")
                 (= (substr ln 1 pflen) prefix)
          (setq lst (cons ln lst)) ;  collect the line
 lst
jbuzbee
« Reply #7 on: March 18, 2009, 03:58:32 PM »
I think I'm confusing everyone  :?
When "filtered" I want this:
not this:
Does that make any more sense?
James Buzbee
Windows 8
Matt__W
  • I like my water diluted.
« Reply #8 on: March 18, 2009, 04:04:50 PM »
"Peanut butter"... silly architects.   :roll:
Autodesk Expert Elite
« Reply #9 on: March 18, 2009, 04:28:53 PM »
jbuzbee , I could have sworn that i gave you a file reader once in a PM but anyways...
(defun filereader (str file)
  ;; filereader
  ;; Reads all lines in a file into a list.
  ;;      ( (lambda ( / f my-list )
  ;;          (setq f (open "c:\\Example.ini" "R"))
  ;;          (setq my-list
  ;;              (apply
  ;;                'append
  ;;                   (iniread (read-line f) f)))
  ;;          (close f)
  ;;          my-list ) )
  ;; => ("var1=val1" "var2=val2" "var4=val4")
  ;; By: John (7) K
  ( (lambda (s f)
      (if s
        (cons
            (list s)
          (filereader (read-line f) f))))
   str
   file ) )
;; one example of how to read from one file and write to another.
 ( (lambda ( / f )
     (setq f (open "c:\\Test.txt" "R"))
     (setq my-list
         (apply
            'append
           (close f)
         (setq f (open "c:\\Test-output.txt" "W"))
         (foreach s my-list
   (write-line s f))
     (close f)) )
« Reply #10 on: March 18, 2009, 04:31:45 PM »
OK, maybe this
(defun c:frtest (/ fname fn ln AllLines lst blank)
        prefix "01"
      (foreach ln (reverse AllLines)
        ;;  filter
          ((and (not blank) (= ln ""))
           (setq lst (cons " " lst)) ;  add one space line
           (setq blank t)
          ((= (substr ln 1 pflen) prefix)
           (setq blank nil)
          (blank (setq blank t))
 (reverse lst)
« Reply #11 on: March 18, 2009, 04:32:31 PM »
Perhaps I'm not understanding, but given a list of strings, perhaps harvested from a file, this is all that's needed:
(vl-remove-if-not
   '(lambda ( x ) (wcmatch (vl-string-trim " \t" x) "01`.###*"))
        "01          INTERIOR KEYNOTES"
        "01.001    SCHEDULED DOOR"
        "01.002    WALL PARTITION"
        "01.100    USE PEANUT BUTTER TO CAULK WINDOW FRAME"
        "01.101    TEMPERED GLASS"
        "01.200    BLH, BLAH, BLAH"
        "02          EXTERIOR KEYNOTES "
If you want to retain the blank lines just change the wcmatch pattern to "01`.###*,".
« Reply #12 on: March 18, 2009, 04:35:06 PM »
Michael he wants the blank lines included, I think. 8-)
Although they need to be of one space character.
John, it is the filtering he is struggling with.
« Reply #13 on: March 18, 2009, 04:37:04 PM »
Yep, ergo the last sentence. :)
But thanks for the heads up Alan. :)
« Reply #14 on: March 18, 2009, 04:39:38 PM »
      (if str
        (cons
  (if (or (wcmatch str "01`.###*" ) (eq str ""))
            (list str))
          (filereader (read-line file) file))))
Like this? ...im lost.
