Author Topic: ( Challenge ) How many 'carrys'?  (Read 6925 times)
  • Custom Title
« on: March 18, 2009, 11:00:55 AM »
It has been a long time since we have had a challenge around here. I hope this one keeps you occupied for a little while.
When you do addition you 'carry' the 1 if the total is greater than 9. For example if we add 109 and 209 we would have one 'carry';
  1  <- one 'carry'
109
209
318
Challenge:
given two integers return how many 'carrys' we have.
The attached file has a two integers per line, you can use it or user input.
Not my idea, it was borrowed.
P.S. Additional languages are allowed
Re: ( Challenge ) How many 'carrys'?
« Reply #1 on: March 18, 2009, 11:35:00 AM »
Oh good one. Im going to think about this one at lunch.
VovKa
  • Ukraine
« Reply #2 on: March 18, 2009, 12:41:29 PM »
(defun test (n1 n2)
  (if (or (zerop n1) (zerop n2))
    0
    (if (< 9 (+ (rem n1 10) (rem n2 10)))
      (1+ (if (= 9 (rem (/ n1 10) 10))
    (test (/ n1 10)
  (if (= 9 (rem (/ n2 10) 10))
    (/ n2 10)
    (1+ (/ n2 10))
    (test (1+ (/ n1 10)) (/ n2 10))
      (test (/ n1 10) (/ n2 10))
« Last Edit: March 18, 2009, 01:18:57 PM by VovKa »
gile
  • Marseille, France
« Reply #3 on: March 18, 2009, 12:53:59 PM »
Very nice Vovka !
SomeCallMeDave
« Reply #4 on: March 18, 2009, 01:14:01 PM »
Does it have to be a LISP solution?
I have been playing with Ruby and cobbled this one together
def count_the_carry(string1, string2)
  #assumes strings are same length and numeric
  array1 = string1.split(//).collect{|x| x.to_i}
  array2 = string2.split(//).collect{|x| x.to_i}
  sum_array = Array.new
  array1.size.times {|i| sum_array[i]=array1[i]+array2[i]}
  carry_count = 0
  sum_array.each {|x| carry_count += 1 if x >=10}
  carry_count
end
input_file = File.new("c:/jobs/random_ints.txt", "r" )
output_file = File.new("c:/jobs/counts.txt", "w")
while (line = input_file.gets)
   nums = line.split
   count = count_the_carry(nums[0], nums[1])
   output_file.write(count.to_s + "\n")
end
input_file.close
output_file.close
My answers are attached
VovKa
  • Ukraine
« Reply #5 on: March 18, 2009, 01:21:24 PM »
thanx gile
i'm sorry but there was a mistake in the routine
i hope now it's ok
  • Custom Title
« Reply #6 on: March 18, 2009, 01:43:55 PM »
Nope! :)
SomeCallMeDave
« Reply #7 on: March 18, 2009, 02:01:10 PM »
Thanks, Mark.
Not only did I not read the original post correctly, I posted a solution that doesn't work.  :-)
There is a particular case where my algorithm fails.  I won't spoil everyone else's fun by post it now.
Back to the drawing board for me.  At least Ruby is fun to play with.
Tuoni
  • I do stuff, and things!
« Reply #8 on: March 18, 2009, 02:17:21 PM »
To me that's two carries... you carry once into the 10's column then once into the 100's column?  Am I alone in this?
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #9 on: March 18, 2009, 02:25:29 PM »
(defun test1 (a b)
 (if (zerop a)
  0
  (+ (/ (+ (rem a 10) (rem b 10)) 10) (test1 (/ a 10) (/ b 10)))
 ) ;_  if
« Reply #10 on: March 18, 2009, 02:30:47 PM »
(defun test1 (a b)
 (if (zerop a)
  0
 ) ;_  if
That's slick :kewl:
VovKa
  • Ukraine
« Reply #11 on: March 18, 2009, 02:32:05 PM »
ElpanovEvgeniy,
(test1 89 11) -> 1
should be 2
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #12 on: March 18, 2009, 02:37:52 PM »
(defun test-lst (l)
 ;;;(test-lst '(250 250 259 259))
 (if (cdr l)
  ((lambda (a)
    (+ a (test-lst (cons a (vl-remove 0 (mapcar '(lambda (a) (/ a 10)) l)))))
   (/ (apply '+ (mapcar '(lambda (a) (rem a 10)) l)) 10)
  0
 ) ;_  if
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #13 on: March 18, 2009, 02:41:46 PM »
ElpanovEvgeniy,
(test1 89 11) -> 1
should be 2
Correction:
(defun test1 (a b)
 (if (zerop a)
  0
  ((lambda (c) (+ c (test1 (/ (+ c a) 10) (/ b 10))))
 ) ;_  if
VovKa
  • Ukraine
« Reply #14 on: March 18, 2009, 02:45:54 PM »
ElpanovEvgeniy,
(test1 99 11) -> 1
should be 2
« Reply #15 on: March 18, 2009, 02:59:09 PM »
python 3.x:
def carries (a, b):
    return (a%10 + b%10)//10 + carries (a//10, b//10) if a else 0
is cleaner, but may execute slower than:
def carries (a, b):
    return 0 if not a else (a%10 + b%10)//10 + carries (a//10, b//10)
or
def test (a, b):
    if a: return (a%10 + b%10)//10 + carries (a//10, b//10)
    return 0
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #16 on: March 18, 2009, 03:26:09 PM »
ElpanovEvgeniy,
(test1 99 11) -> 1
should be 2
My strategy was unsuccessful...
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #17 on: March 18, 2009, 03:33:52 PM »
(defun test1 (a b) (test-lst (list a b)))(test1 99 11) => 2
uncoolperson
« Reply #18 on: March 18, 2009, 03:37:44 PM »
not pretty, but I had fun
(DEFUN carry (num1 num2)
  (SETQ carried 0
tocarry 0
index 0
str1 (ITOA num1)
str2 (ITOA num2)
  (SETQ list1 (REVERSE
(MAPCAR '(LAMBDA (someitem) (ATOI (CHR someitem)))
(VL-STRING->LIST str1)
  (SETQ list2 (REVERSE
(VL-STRING->LIST str2)
  (WHILE (< index (MAX (LENGTH list1) (LENGTH list2)))
    (IF (NOT
  (ZEROP
    (SETQ tocarry (REM (+ (NTH index list1) (NTH index list2) tocarry)
       10
      (SETQ carried (1+ carried))
    (SETQ index (1+ index))
and again (same idea, kinda but funner)
  (SETQ carried 0
tocarry 0
index 0
str1 (ITOA num1)
str2 (ITOA num2)
  (dowork list1 list2 0)
(DEFUN dowork (list1 list2 carry)
  (COND ((AND list1 list2)
(+ (COND ((> (SETQ tocarry (/ (+ (CAR list1) (CAR list2) carry) 10))
      0
   1
  (T 0)
    (dowork (CDR list1) (CDR list2) tocarry)
(list1 (dowork list1 '(0) carry))
(list2 (dowork '(0) list2 carry))
(T 0)
« Last Edit: March 18, 2009, 04:07:15 PM by uncoolperson »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #19 on: March 18, 2009, 03:48:45 PM »
(defun test-lst (l)
 (if (cdr l)
  ((lambda (a) (+ a (test-lst (vl-remove 0 (cons a (mapcar '(lambda (a) (/ a 10)) l))))))
  0
 ) ;_  if
) ;_  defun
(defun test2 (/ f l)
 (setq f (open "D:\\random_ints.txt" "r"))
 (while (car (setq l (cons (read-line f) l))))
 (close f)
 (setq f (open "D:\\carry.txt" "a"))
 (foreach a (reverse (cdr l)) (write-line (itoa (test-lst (read (strcat "(" a ")")))) f))
 (close f)
« Reply #20 on: March 18, 2009, 04:52:19 PM »
My kludge.  :-)
(defun carries (a b / c clast)
  (setq clast 0
        c 0)
  (and (= (type a) 'INT) (setq a (float a)))
  (and (= (type b) 'INT) (setq b (float b)))
  (mapcar
    (function
      (lambda(m n)
        (if (> (+ m n clast -96) 9)
          (setq c (1+ c)
                clast 1)
          (setq clast 0)
    (reverse(vl-remove 46(vl-string->list(rtos a 2 10))))
    (reverse(vl-remove 46(vl-string->list(rtos b 2 10))))
  c
test code:
(defun c:test ()
  (princ (carries 9999 8888))           ;#=> 4
  (princ (carries 1111 8888))           ;#=> 0
  (princ (carries 56 45))               ;   #=> 2
  (princ (carries 11 89))               ;   #=> 2
  (princ (carries 11 79))               ;    1
  (princ (carries 99 11))               ;  2
  (princ (carries 99.795 11.54))        ;  4
« Last Edit: March 18, 2009, 05:43:58 PM by CAB »
SomeCallMeDave
« Reply #21 on: March 18, 2009, 05:07:56 PM »
Revised Ruby
def count_the_carry2(string1, string2)
  array1 = string1.split(//).collect{|x| x.to_i}.reverse!
  array2 = string2.split(//).collect{|x| x.to_i}.reverse!
  carry = 0
  carry_count = 0
    sum = array1[i]+array2[i]
    carry_count += ((sum+carry) >= 10 ? 1 : 0 )
    carry = (sum >= 10 ? 1 : 0)
  carry_count
end
Tests
puts count_the_carry2("9999", "8888")   #=> 4
puts count_the_carry2("1111", "8888")   #=> 0
puts count_the_carry2("56", "45")          #=> 2
puts count_the_carry2("11", "89")          #=> 2
puts count_the_carry2("11", "79")          #=> 1
gile
  • Marseille, France
« Reply #22 on: March 18, 2009, 05:18:09 PM »
LISP
(defun test (a b)
  (if (zerop a)
    0
    ((lambda (d / c)
       (+ c (/ d 10) (test d (/ b 10)))
      (+ (/ a 10) (setq c (/ (+ (rem a 10) (rem b 10)) 10)))
C#
public static int test(int a, int b)
            int c = (a % 10 + b % 10) / 10, d = a / 10 + c;
            return (a == 0) ? 0 : c + d / 10 + test(d , b / 10);
« Last Edit: March 18, 2009, 06:18:59 PM by gile »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #23 on: March 19, 2009, 01:35:42 AM »
Hi gile! :-)
(test 11 89) => ; error: bad argument type: numberp: nil
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #24 on: March 19, 2009, 01:40:24 AM »
Hi CAB! :)
(carries 9 91) => 1
gile
  • Marseille, France
« Reply #25 on: March 19, 2009, 02:09:01 AM »
Corrected (I hope...)
LISP
(defun test (a b / c d)
  (if (zerop a)
    0
    d (/ a 10)
      (+ c (test d c) (test (+ d c) (/ b 10)))
C#
            int c = (a % 10 + b % 10) / 10, d = a / 10;
            return (a == 0) ? 0 : c + test(d, c) + test(d + c , b / 10);
« Last Edit: March 19, 2009, 02:55:57 AM by gile »
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #26 on: March 19, 2009, 03:31:21 AM »
Good code gile!
ElpanovEvgeniy
  • Moscow (Russia)
« Reply #27 on: March 19, 2009, 04:59:15 AM »
Not recursion...
(defun carries (a b / c i)
 (setq c 0 i 0)
 (while (not (zerop (+ a b)))
  (setq c (/ (+ (rem a 10) (rem b 10) c) 10)
        i (+ c i)
        a (/ a 10)
        b (/ b 10)
 i
« Reply #28 on: March 19, 2009, 09:03:11 AM »
Hi CAB! :)
(carries 9 91) => 1
Thanks for testing.
  (setq clast 0
        c 0)
  (setq a (reverse(vl-remove 46(vl-string->list(rtos a 2 10)))))
  (setq b (reverse(vl-remove 46(vl-string->list(rtos b 2 10)))))
  (if (> (length a)(length b)) ; add leading zero
    (setq a (append a (list 48)))
    (setq b (append b (list 48)))
  (while (> (length a)(length b)) (setq b (append b (list 48))))
  (while (> (length b)(length a)) (setq a (append a (list 48))))
  (mapcar
    (function
      (lambda(m n)
          (setq c (1+ c) clast 1)
          (setq clast 0)
    a b
  c
(defun c:test ()
  (print (carries 9999 8888))           ;  4
  (print (carries 1111 8888))           ;  0
  (print (carries 56 45))               ;  2
  (print (carries 11 89))               ;  2
  (print (carries 11 79))               ;  1
  (print (carries 99 11))               ;  2
  (print (carries 99.795 11.54))        ;  4
  (print (carries 99 1))                ;  2
