Author Topic: Ethics on combing 2 lisp routines diff. authors and got a better Background Mask  (Read 8078 times)
doggarncity
Hi all
    I have found 2 routines by 2 different authors and want to know if the credits show in the code
can I post the combined with the little bit of my addon to call it a new routine? I have found
one nice Background mask routine that toggles, but didn't have the offset declared and was to big.
Next found a routine I could declare the offset added my settings and combinded the two routines
to make a better one. Is it okay to post that combined and share that works in acad 2009?
authors:
BMask v1.0 January, 2007 ©Timothy Spangler
MT ©Lee Ambrosius Created on: 4/7/2004
MJP
Sure. As long as your giving credit where credit is due, people cant get angry at you. If they didnt want you to use it then they wouldn't have posted it right?
Post away!
TimSpangler
  • CAD Naked!!
I would like to see it......   :-P
ACA 2015 - Windows 7 Pro
doggarncity
I'm working on it... the only thing I wanted to do to yours is declare/set the mask offset. If you have done
that I'll not go any further and would love to see it. The Offset Mask is to large for me. I found Lee's and it can be
declared in the lisp.
MJP
TimSpangler
  • CAD Naked!!
I actually havent done it.  I use it how it is, but you idea sound like a good addition.  I'll look at it this evening and get back to you, if you get done in the meantime post what you have.
Krushert
  • FREE BEER Tomorrow!!
I use Lee's routine but I am curious, what don't you like about it.  For me it is too many enters to get to the point of selecting text.  Minor Annoyance that pops into my mind from time to time.
sourdough
My biggest problem is that I like the toggle from Tim, but also love the ability in Lee's to keep the mask much closer to the text with a minor edit to code.
MJP
sourdoug/doggarncity for now
LDC 2009/C3D 2010/C3D 2011/C3D 2016
Win 10 64bit
sourdough
Okay here is a go at a hybrid of Vlisp/lisp that will work so keep an open mind.
;;; command is : BM
;;; This is a hybrid of code from 2 authors (below) and modified by Michael J. Perry from Raleigh, NC to 3-17-09
;;; Overcome the background mask offset of Mtext. I have noted in code where to make the change
;;; I also included a toggle at the end of masking to flip one textmasking off. Would love to loop it till done,
;;; this is what I could combine in 2 days to get it to work. Feel free to complete this if someone can
;;; add the loop in or more.
;;;    BMASK.lsp v1.0
;;;    Copyright © January, 2007
;;;    Timothy G. Spangler
;;;    Permission to use, copy, modify, and distribute this software
;;;    for any purpose and without fee is hereby granted, provided
;;;    that the above copyright notice appears in all copies and
;;;    that both that copyright notice and the limited warranty and
;;;    restricted rights notice below appear in all supporting
;;;    documentation.
;;;    THIS SOFTWARE IS PROVIDED "AS IS" WITHOUT EXPRESS OR IMPLIED
;;;    WARRANTY. ALL IMPLIED WARRANTIES OF FITNESS FOR ANY PARTICULAR
;;;    PURPOSE AND OF MERCHANTIBILITY ARE HEREBY DISCLAIMED BY THE
;;;    PROGRAMMER.
;; Written by: Lee Ambrosius
;; Created on: 4/7/2004
;; This program allows you to add Background Mask to several Mtext objects
;; at one time instead of using the Mtext editor for each object or the Properties Palette.
;; The Properties Palette in 2005 doesn't allow you to set Background Color or Border Offset.
(defun c:bm ( / kWordBackgroundMaskCurrent dOffsetCurrent ssMtext dxf90 dxf63 dxf45 dxf441 TextObj TextEntList vlText vlFill *error*)
(setvar "users1" "")
  (prompt "\nSelect Multiple/Single Mtext to Mask or 'Enter to Toggle Off")
    (setq kWordBackgroundMask "Background")
  (if (= kWordBackgroundMask nil)
    (setq kWordBackgroundMask kWordBackgroundMaskCurrent)
  (cond ((= kWordBackgroundMask "Color")
            (if (or (= maskClr nil) (/= (type maskClr) 'LIST))
               (setq maskClr (acad_truecolorcli 1))
               (if (= (assoc 420 maskClr) nil)
                 (setq maskClr (acad_truecolorcli (cdr (assoc 62 maskClr))))
                 (setq maskClr (acad_truecolorcli (assoc 420 maskClr)))
        ((= kWordBackgroundMask "Background")(setq maskClr 256))
        ((= kWordBackgroundMask "None")(setq maskClr 0 dOffset 1.0))
  (if (/= maskClr nil)
      (if (/= kWordBackgroundMask "None")
          (setq dOffsetCurrent dOffset)
          (if (= dOffsetCurrent nil)
            (setq dOffset 1.0 dOffsetCurrent 1.0)
          (setq dOffset 1.15);  ********** change Offset masking here eg 1=text frame
          (if (= dOffset nil)
            (setq dOffset dOffsetCurrent)
          (if (> dOffset 5)(setq dOffset nil))
          (if (< dOffset 1)(setq dOffset nil))
          (while (= dOffset nil)
            (setq dOffset (getreal (strcat "\nSpecify border offset factor: <" (rtos dOffsetCurrent 2 3) ">: ")))
        (if (= dOffset nil)
          (setq dOffset 1.0)
      (if (setq ssMtext (ssget (list (cons 0 "MTEXT"))))
          (cond ((= kWordBackgroundMask "None")
                    (setq mask_list (list (cons 90 2)(cons 63 0)(cons 45 dOffset)(cons 441 0))
                          dxf90 2
                          dxf63 nil
                          dxf45 nil
                          dxf441 nil
                ((and (= kWordBackgroundMask "Color")(/= (assoc 420 maskClr) nil))
                    (setq mask_list (list (cons 90 1)(cons 63 1)(cons 421 (cdr (assoc 420 maskClr)))(cons 45 dOffset)(cons 441 (cdr (assoc 420 maskClr))))
                          dxf90 1
                          dxf63 2
                          dxf45 dOffset
                          dxf441 (cdr (assoc 420 maskClr))
                ((and (= kWordBackgroundMask "Color")(= (assoc 420 maskClr) nil))
                    (setq mask_list (list (cons 90 1)(cons 63 (cdr (assoc 62 maskClr)))(cons 45 dOffset)(cons 441 2146608))
                          dxf90 1
                          dxf63 (cdr (assoc 62 maskClr))
                          dxf45 dOffset
                          dxf441 nil
                    (setq mask_list (list (cons 90 3)(cons 63 3)(cons 45 dOffset)(cons 441 0))
                          dxf90 3
                          dxf63 256
                          dxf45 dOffset
                          dxf441 0
          (setq emax (sslength ssMtext)
                sscount 0
          (while (< sscount emax)
            (setq EN (entget (ssname ssMtext sscount))
  tempEN nil)
            (if (/= dxf90 nil)
                (if (/= (assoc 90 EN) nil)
                  (setq EN (subst (cons 90 dxf90) (assoc 90 EN) EN))
                  (setq EN (append EN (list (cons 90 dxf90))))
                (setq CNT 0
                      nMembers (member (assoc 90 EN) EN))
                (if (= nMembers nil)
                  (setq nMembers 0)
  (setq nMembers (length nMembers))
                (repeat (- (length EN) nMembers)
                  (setq tempEN (append tempEN (list (nth cnt EN))))
                  (setq CNT (1+ CNT))
(if (> nMembers 0)
    (setq CNT 1)
                    (repeat (- nMembers 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 90 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN
      tempEN nil)
            (if (/= dxf63 nil)
                (if (/= (assoc 63 EN) nil)
                  (setq EN (subst (cons 63 dxf63) (assoc 63 EN) EN))
                  (setq EN (append EN (list (cons 63 dxf63))))
                (setq CNT 0
                      nMembers (member (assoc 63 EN) EN))
                  (setq nMembers 0)
                  (setq CNT (1+ CNT))
(if (> nMembers 0)
    (setq CNT 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 63 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN
      tempEN nil)
            (if (/= dxf45 nil)
                (if (/= (assoc 45 EN) nil)
                  (setq EN (subst (cons 45 dxf45) (assoc 45 EN) EN))
                  (setq EN (append EN (list (cons 45 dxf45))))
                (setq CNT 0
                      nMembers (member (assoc 45 EN) EN))
                  (setq nMembers 0)
                  (setq CNT (1+ CNT))
(if (> nMembers 0)
    (setq CNT 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 45 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN
      tempEN nil)
            (if (/= dxf441 nil)
                (if (/= (assoc 441 EN) nil)
                  (setq EN (subst (cons 441 dxf441) (assoc 441 EN) EN))
                  (setq EN (append EN (list (cons 441 dxf441))))
                (setq CNT 0
                      nMembers (member (assoc 441 EN) EN))
                  (setq nMembers 0)
                  (setq CNT (1+ CNT))
(if (> nMembers 0)
    (setq CNT 1)
                      (setq tempEN (append tempEN (list (nth cnt (member (assoc 441 EN) EN)))))
                      (setq CNT (1+ CNT))
                (setq EN tempEN)
            (entmod EN)
            (setq sscount (1+ sscount))
  (command "draworder" "p" "" "front")
 (Princ "\nThe Masking is complete.")
 ;;; Begin Error Handler -------------------------------------------------
  (defun *error* (MSG)
  (if (not (member MSG '("Function cancelled" "quit / exit abort")))
  (princ (strcat "\n*** Program Ended: "))
  (princ "\n... Program Cancelled ...")
  (while (< 0 (getvar "cmdactive"))
  (command)
  (setvar "CMDECHO" OldCmdEcho)
;; Set variables
(setq OldCmdEcho (getvar "CMDECHO"))
(setvar "CMDECHO" 0)
 ;; Select object
  ;(while(null(setq TextObj(car(entsel "\nToggle MTEXT Mask: "))))
  ;(princ " \nNothing Selected...Try Again ")
  ;; Get text entity list
  (setq TextEntList (entget TextObj))
  ;; Check for MTEXT
  (if (not (= (cdr (assoc 0 TextEntList)) "MTEXT"))
  (alert "Selected entity is not MTEXT")
  ;; Reset variables
  ;; Restart the program
  (C:BM)
 ;; Create activeX text
  (setq vlText (vlax-ename->vla-object TextObj))
  ;(c:mtt)
  ;; Check for background fill
  (setq vlFill (vlax-get-property vlText 'backgroundfill))
  ;; If no background fill exsists
  (if (= vlFill :vlax-false)
  ;; Set background fill for text
  (vlax-put-property vlText 'backgroundfill :vlax-true)
  (princ "\n Background fill applied")
  (vlax-put-property vlText 'backgroundfill :vlax-false)
  (princ "\n Background fill removed")
  ;; Set the draworder to bring text front
(command "draworder" TextObj "" "front")
;; Reset variables
;;; Echos to the command line
;(princ "\n BMask v1.0 ©Timothy Spangler, \n  January, 2007....loaded.")
(terpri)
;(princ "C:BM")
(print)
;;; End echo
;(prompt "\nType MT to run the command")
Hope this helps some who have fought the border offset Dilemma in Mtext
MJP
sourdoug
« Last Edit: March 17, 2009, 01:24:46 PM by sourdoug »
Win 10 64bit
Krushert
MJP
sourdoug
Okay I like it, the only thing I would suggest is to allow multiple selection of text when wanting to toggle off the mask.  I can make multiple section for toggling it on but not off.  I could be screwing something up though.  I have been known to do that.
sourdough
MJP
sourdoug
Hey if you or someone else can get it I'll really be doing a Happy Dance. I get so wrapped up when I get started
on a project like this. Just wish I had the knowledge to do it all.
MJP
Mike
Win 10 64bit
Ive looked at 60 or so lines so far and i have quite a few comments. All being that after 63 lines the code does nothing more then set and evaluate and reevaluate variables with no chance to alter those variables from the end user (so why evaluate and reevaluate if nothing can be changed?)
I only have a few minutes left on lunch so i will see how far i get. ...maybe we can do a re-write on this for ya.
sourdough
Wow, that would be a GodSend if you could. I'm not that much of a programmer but can organize thoughts
on how to and by working my imagination come up with the what if and see if it works. This time it did but not
the right way for sure. I have seen hundreds of posts on this. Who knows maybe Autodesk will add it as a variable to
do a textmask offset that is global. I hope anyway, but till then this works a little bit. I highly respect the work
that was done by the original authors and hope they might want to take it to the next progression.
MJP
Mike
Win 10 64bit
Want to learn?
We can do this together if you want. I ask questions, you give answers. I ask you questions i already know the answer to and you look them up (learn) You ask questions and i give answers to...we code this *together*
sourdough
Want to learn?
sounds good always up for a good programming challenge.
MJP
Mike
Win 10 64bit
Do you have a directory on your computer where you keep all your lisp's? If not, make one. Mine is in
"My Documents\Programing\AutoLisp" But you can make it where ever you want.
Then go grab this program:
[ http://www.theswamp.org/index.php?topic=26914.0 ]
Unzip and take the exe from the bin directory and put in your programing directory (mine is located here: "My Documents\Programing\AutoLisp") You can trash the rest if you want, all that is left is the manual and the source code; you dont need that.
next double click the exe and a new directory will be created for you called "lsp_proj" rename it to what (What do you want to call this program)?
sourdough
Okay did the directory, I have tons of lisp routines from the last 10+ years. I understand the order of things for this. A name would TBM, I think it has a ring to it.
MJP
Win 10 64bit
Ok, I'll name mine the same in the morning. BTW, i forgot to mention that you need to rename the "main.lsp" to "TBM.lsp".
Do you want to do the Pseudo code or would you like me to?
sourdough
Hi
   Got your message this morning and responded there. Yes, to you doing the code. Time is precious right now.
I'm also in the throws of a second project in C3D and learning new aspects. So, whatever you can do to make it
better please do. Where is the Main.lsp you are referring to.
MJP
Mike
Win 10 64bit
We'll pick this up when you have more time.
Here is a shortened version (i think) of what you posted. I say "I think" cause i trimmed it down from 300 to 40 lines of code so i think i might be missing something (or several) features. I hope not but, we'll see.
(defun c:tbm ( / ssMtext doffset ent)
  (defun sel2lst ( sel / l len )
    ;; convert SELection set to LiST of e-names
    ;; Vladimir Nesterovsky
    ;; 04/30/96 03:40:05
    (if (= 'PICKSET (type sel))
      (repeat (setq len (sslength sel))
              (setq len (1- len) l (cons (ssname sel len) l)))))
  (setq ssMtext (ssget '((-4 . "<OR") (0 . "MTEXT") (-4 . "OR>")))
        ssMtext (sel2lst ssMtext))
  (foreach x ssMtext
              (setq ent (entget x))
              (if (< (cdr (assoc 90 ent)) 3)
                  (if (null doffset)
                    (setq doffset
                            ((getreal
                               (strcat
                                 "\nSpecify border offset factor [1.5]: ")))
                            (1.5)))
                  ;; mask not present set it.
                  (setq ent (append ent (list (cons 90 3))))
                  (setq ent (append ent (list (cons 63 256))))
                  (setq ent (append ent (list (cons 45 doffset))))
                  (setq ent (append ent (list (cons 441 0))))
                ;; mask present, kill
                (setq ent (subst  (cons 90 2) (assoc 90 ent) ent))
              (entmod ent)
              ;; write the ent
  ;;;    (Princ "\nThe Masking is complete.")
(princ "\nEnter \"TBM\" to start mask routine.")
Hope this works for ya; i took an ultra simplified approach to this and redid the whole thing.
sourdough
  (foreach x ssMtext
                  (if (null doffset)
                    (setq doffset
                            ((getreal
                               (strcat
                            (1.5)))
              (entmod ent)
              ;; write the ent
This is awesome, it does it all. My only pref. is that the default be 1.15 to keep it close to the text outline.
But, you did it all (Toggle-Background Mask and multi-selection). Now, I'm going to study what you did and learn.
Many Thanks
MJP
Mike
Win 10 64bit
Change those 1.5's to 1.15's in the COND statement and that's done. However, CAB may have a few good improvements for us.
Krushert
Many Thanks
MJP
Mike
It works for me, the only hiccup (and maybe is not a hiccup) is that it allowed the user to select multiple text entities but only the first entity selected was toggled. The rest were ignored.   Much more efficient than Lee's by less enter key strokes to get thru.
I cant reproduce that error.
Just some minor modifications:
(defun c:tbm (/ ssMtext MtextList doffset ent x)
  (and (setq ssMtext (ssget '((-4 . "<OR") (0 . "MTEXT") (-4 . "OR>"))))
       (setq MtextList (vl-remove-if 'listp (mapcar 'cadr (ssnamex ssMtext))))
  (foreach x MtextList
    ;; If no background fill exist
(or doffset
  (setq doffset
   ((getdist "\nSpecify border offset factor [1.15]: "))
   (1.15) ; default here
(setq ent (append ent (list '(90 . 3) '(63 . 256)(cons 45 doffset) '(441 . 0))))
    (entmod ent)
    ;; write the ent
  (and ssMtext (command "draworder" ssMtext "" "front"))
<edit: bug fix>
« Last Edit: March 18, 2009, 03:22:17 PM by CAB »
TimSpangler
  • CAD Naked!!
Jumped on this a little today at lunch, didn't add multi select but I did add color background colors.
;;;    TEXT_BMASK.lsp v2.0
;;;    Copyright © March 16, 2009
;;;    documentation.
;;;    PROGRAMMER.
(defun C:BM (/ *error* OldCmdEcho BMaskOffset TextObj BMaskOffset BMaskColor TextElist)
(princ (strcat "\n*** Program Error: " (strcase MSG) " ***"))
(command)
;; Set variables
(setq BMaskOffset 2.0);<-- Set default offset
;; Get selection
(setq TextObj (car (entsel "\n Select MTEXT to mask or [ENTER] for Settings: ")))
(if (= (type TextObj) nil)
;; Set the settings
(setq BMaskOffset (getreal (strcat "\n Enter offset distance <" (rtos BMaskOffset 2 2) ">")))
(setq BMaskColor (acad_colordlg 256 T))
(setq TextElist (entget TextObj))
;; Check for MTEXT
(if (not (= (cdr (assoc 0 TextElist)) "MTEXT"))
;; If not mtext, alert the user and restart
;; Reset variables
(C:BM)
;; If is mtext add/remove the mask
(if (or (= (cdr (assoc 90 TextElist)) 1)(= (cdr (assoc 90 TextElist)) 3))
(setq TextElist (subst (cons 90 2) (assoc 90 TextElist) TextElist))
(setq TextElist (subst (cons 90 3)(assoc 90 TextElist) TextElist))
(setq TextElist (append TextElist (list (cons 45 BMaskOffset))))
;; Check for a masking color
(if (and BMaskColor (< BMaskColor 256))
(setq TextElist (subst (cons 90 1) (assoc 90 TextElist) TextElist))
(setq TextElist (append TextElist (list (cons 63 BMaskColor))))
(setq TextElist (append TextElist (list (cons 441 0))))
;; Modify the enityt list
(entmod TextElist)
;; Reset variables
(princ "\n BMask v2.0 ©Timothy Spangler, \n  March, 2009....loaded.")
(terpri)
(princ "C:BM")
(print)
;;; End echo
I will try to get time tonite to add multiselect and gripselect
BTW great code 7, CAB....
septicad
here is the version i wrote a while back... just another way to do it...  works well for me and it provides some feedback on the # of entities modified... just select everything and then the function cycles through the selection set toggling the mask on or off.... adding a line to modify the mask border could be added pretty easily.
I screwed around with this for a while too and i found that the default mask size was acceptable under most circumstances, so what the point to add it to this function.  But its a good way to learn!
I borrow code from where ever i can find it! How much to i need to modify before It's my code?
;;;--- Toggle's background for mText entities --------------
(defun c:mtw (/ $CMDECHO ent obj sset1 sset2 newent cnt cnt2 cnt3)
;; get big selection set
  (setq sset1 nil)
  (if (= (last (ssgetfirst)) nil)
   ; IF
      (prompt "\nSelect entities to Toggle Background Fill [only mText will be modified]:")
      (setq sset1 (ssget))
   ; ELSE
    (setq sset1 (last (ssgetfirst)))
 (if (/= sset1 nil)
(setq $CMDECHO (getvar "CMDECHO"))
      ;; run through each entity selected
      (setq cnt -1 cnt2 0 cnt3 0)
      (while (< (setq cnt (1+ cnt)) (sslength sset1))
        (setq obj     (vlax-ename->vla-object (ssname sset1 cnt))
              ObjType (vla-get-ObjectName obj)
          ((= ObjType "AcDbMText")
            (setq cnt2 (1+ cnt2))
            (setq ent (ssname sset1 cnt))
            (if (= (vla-get-BackgroundFill obj) :VLAX-TRUE)
              ;;;--- IF TRUE - already filled
               (vla-put-BackgroundFill obj :VLAX-FALSE)
               (vla-update obj)
               (setq cnt3 (1+ cnt3))
              ;;;--- IF FALSE - no fill
               (setq sset2 (ssadd))
               (ssadd ent sset2)
       (command "draworder" sset2 "" "F")
;;; ADD NEW CODE HERE;;;;
;;; TO MODIFY MASK BORDER;;;;
               (setq ent (entget ent))
               (if (= 1 (cdr(assoc 90 ent)))
                    (setq ent
                     (subst (cons 90 1)
                     (cons 90 3)
                     ent)
            (entmod ent)
                    (entupd (cdr(assoc -1 ent)))
            (setq newent (append ent (list(cons 90 3))))
            (entmod newent)
                    (entupd (cdr(assoc -1 newent)))
        )  ; end COND
      )   ; end WHILE
      (prompt
       (strcat "\nmText Background(s) Modified <"
       (rtos (- cnt2 cnt3) 2 0) " turned ON> "
       "<" (rtos cnt3 2 0) " turned OFF>\n")
      (setvar "CMDECHO" $CMDECHO)
    ); end progn
  ); end if
); end MTW
KewlToyZ
(or doffset
  (setq doffset
    (entmod ent)
    ;; write the ent
<edit: bug fix>
Hello CAB,
I wanted to know where I would look up the codes for MTEXT.
Reading this line
(or doffset
  (setq doffset
So far it appears 90 is code of the list in MTEXT object variables?
MTEXT DXF Reference codes?
Note: I found 90 in the Developer Documentation. Thanks.
I was trying to do something similiar with just MTEXT colors in the contents of the MTEXT object properties.
I just wanted to set them bylayer or 0 for the color where for example it reads:
{\C2;100'-6"\PT.O. PARAPET}
« Last Edit: April 27, 2009, 05:16:24 PM by KewlToyZ »
KewlToyZ
After looking through them, I'm not sure it applies to content formatting of the text itself?
90
 Background fill setting:
0 = Background fill off
1 = Use background fill color
2 = Use drawing window color as background fill color
63
 Background color (if color index number)
420 - 429
 Background color (if RGB color)
430 - 439
 Background color (if color name)
347
 Hard-pointer ID/handle to material object (present if not BYLAYER)
 BYLAYER
62
 Color number (present if not BYLAYER); zero indicates the BYBLOCK (floating) color; 256 indicates BYLAYER; a negative value indicates that the layer is turned off (optional)
I wondered if 62 may be a place to start?
« Last Edit: April 27, 2009, 05:30:10 PM by KewlToyZ »
