Author Topic: Trim (and Extend) with automatic Fence  (Read 3709 times)
ANA
« on: March 15, 2009, 06:20:15 PM »
This is something I've wanted ever since I first used Autocad, and finally made with help and guidance from Greg S at the Bricscad forum. It's two separate commands, TR and EX, and both have automatic switching between standard and Fence mode.
–If your pick doesn't find an object to be trimmed (or extended), you change automatically to Fence mode. That pick point is used as the first fence point, and you're prompted for the next fence point.
–You automatically switch back to normal mode by clicking within pickbox range of any object (though the pickbox isn't displayed, unfortunately). The object you clicked on is trimmed (or extended) if possible.
–Hitting Enter exits the command from either mode.
I've tested it in Bricscad v9. It doesn't work in Bricscad v8, but it might work in Autocad.
EDIT: Maybe it does work in v8. It passed a brief test just now, prompted by gskelly's reply.
Is there any way to make something that looks like the pickbox (but maybe grey?) appear at the crosshairs (or, ideally, instead of the crosshairs) during a GETPOINT function, with Object Snap turned off? Osnap has to be off. I'm using GETPOINT during fence mode because that's the only way I know to get a rubber-band line from the last fence point to the cursor. Or is there some way to get that during an ENTSEL function?
;;; sub-routine to highlight a selection set (without grips)
(defun hilite (set33 OnOff / N ObjN)
(if (= (type set33) 'PICKSET)
    (setq N 0)
      (repeat (sslength set33)
        (and
          (setq ObjN (vlax-ename->vla-object (ssname set33 N)))
          (vlax-method-applicable-p ObjN "Highlight")
          (vla-highlight ObjN OnOff)
          ) ;; end And
        (setq N (1+ N))
      ) ;; end Repeat
    ) ;; end Progn
  ) ;; end IF
;;; subroutine to handle errors
(defun IfAbort (emsg)
(prompt "\n-- Abnormal termination due to: ")
(prompt emsg)
(setvar "CMDECHO" SaveCE)         ;; restore command echo status
(setvar "OSMODE" SaveOS)          ;; restore Object Snap setting
(setq *error* SaveErr)            ;; restore previous error-handling function
(hilite ss1 0)                    ;; turn off highlighting
;;; TRIM command with Fence mode automatically turned on and off
(defun c:TR (/ )
(setq SaveCE (getvar "CMDECHO"))  ;; save Command Echo status
(setq SaveOS (getvar "OSMODE"))   ;; save Object Snap setting
(setq SaveErr *error*)            ;; save current error-handling function
(setq *error* IfAbort)            ;; make IfAbort the error-handling function
(princ "Select cutting objects: ")
(setq ss1 (ssget))                    ;; select cutting edges
(sssetfirst nil ss1) (sssetfirst nil) ;; turn off grips of any pre-selected set
(setvar "CMDECHO" 0)              ;; suppress command echo
(setvar "OSMODE" 0)               ;; turn off object snap
(setq pt1 nil pt2 nil NewPt nil)  ;; clear fence points & pick point
(setq LoopFlag 1)                 ;; set Loop flag
;------------------------------ Begin Loop, get user input
(while (equal LoopFlag 1)         ;; Loop till no point is picked
  (setq e1 nil)
  (setq NewPt nil)
  (hilite ss1 1)                  ;; highlight cutting edges
  (if pt1 ;;----------1: Is there a fence start point?
    (progn                   ;; If so, look for a new fence vertex.
      (setq NewPt (getpoint pt1 "Next fence point, or object to trim: "))
      (if NewPt ;;---------2: Did the user actually pick a new point?
        (progn                    ;; If so,
          (if (ssget NewPt) ;;---------3: Is there an object at NewPt?
            (progn                               ;; If so,
              (setq e1 (ssname (ssget NewPt) 0)) ;;   make it e1,
              (setq ObjFound 1)      ;;   set the Object Found flag,
              (setq pt1 nil pt2 nil) ;;   and clear the fence points.
            ) ;; end Progn.
            (setq ObjFound 0)        ;; If not, clear the Object Found flag.
            ) ;;---end IF-3.
          ) ;; end Progn.
        (progn               ;; If not (no new point because user hit Enter),
          (setq pt1 nil pt2 nil) ;;   clear the fence points,
          (setq LoopFlag 0)      ;;   and prepare to end the loop.
          ) ;;end Progn.
        ) ;;---end IF-2.
      ) ;; end Progn
    (progn    ;; If not (no fence start point), look for an object to trim
      (setvar "ErrNo" 0) ;; (entsel) error 7 = none found, error 52 = Enter
      (setq e1 (entsel "Object to trim, or start point of fence: "))
      (setq NewPt (getvar "LASTPOINT"))
      (if (equal (getvar "ErrNo") 7) ;;-------4: Was an object found?
        (progn                       ;; If one was found (no errror 7),
          ) ;;end Progn.
        ) ;;---end IF-4
      (if (equal (getvar "ErrNo") 52) ;;-------5: Did the user hit Enter?
        (progn                        ;; If so,
          ) ;;end Progn.
        ) ;;---end IF-5
      ) ;; end Progn
    ) ;;---end IF-1
;;;-------------------------- Continue Loop, process user input
  (if (= ObjFound 1) ;;--------6: Was an object found during user input?
    (command "Trim" ss1 "" NewPt "")   ;; If so, trim the object,
    (progn                             ;; If not (no object found),
      (if pt1 ;;---------7: Is there a fence start point?
         (progn                        ;; If so,
           (setq pt2 NewPt)            ;;   make the new point the fence end point,
           (command "Trim" ss1 "" "F" pt1 pt2 "" "") ;;   trim the fence objects,
           (setq pt1 pt2)              ;;   allow continuation of the fence line,
           (setq pt2 nil)              ;;   and get rid of the old end point.
           ) ;; end Progn
           (setq pt1 NewPt)            ;;   make this pt1,
           (setq pt2 nil)              ;;   and get rid of the old pt2.
           ) ;; end Progn
         ) ;;---end IF-7
       ) ;; end Progn
    ) ;;---end IF-6
) ;; end WHILE loop
(setvar "CMDECHO" SaveCE)         ;; restore Command Echo status
;;; EXTEND command with Fence mode automatically turned on and off
(defun c:EX (/ )
(princ "Select boundary objects to extend to: ")
(setq ss1 (ssget))                    ;; select boundary objects
  (setq e1 nil)
  (setq NewPt nil)
      (setq NewPt (getpoint pt1 "Next fence point, or object to extend: "))
        (progn                    ;; If so,
            (progn                   ;; If so,
            ) ;; end Progn.
            ) ;;---end IF-3.
          ) ;; end Progn.
          ) ;;end Progn.
        ) ;;---end IF-2.
      ) ;; end Progn
    (progn    ;; If not (no fence start point), look for an object to extend
      (setq e1 (entsel "Object to extend, or start point of fence: "))
          ) ;;end Progn.
        ) ;;---end IF-4
        (progn                       ;; If so,
          ) ;;end Progn.
        ) ;;---end IF-5
      ) ;; end Progn
    ) ;;---end IF-1
    (command "Extend" ss1 "" NewPt "") ;; If so, extend the object,
         (progn                        ;; If so,
           (command "Extend" ss1 "" "F" pt1 pt2 "" "") ;;   extend fence objects,
           ) ;; end Progn
           ) ;; end Progn
         ) ;;---end IF-7
       ) ;; end Progn
    ) ;;---end IF-6
) ;; end WHILE loop
« Last Edit: March 15, 2009, 10:15:32 PM by ANA »
Re: Trim (and Extend) with automatic Fence
« Reply #1 on: March 15, 2009, 06:32:49 PM »
Does Bricscad have (grread)
Gotta run..back later.
gskelly
« Reply #2 on: March 15, 2009, 07:51:21 PM »
CAB, yes Bricscad does have grread.
ANA, I took your TR and EX for a quick test drive on Bricscad v8 and v9. Seems to work on both for me.
Bricscad v12
ANA
« Reply #3 on: March 15, 2009, 10:12:12 PM »
Very interesting, CAB. I've never heard of GRREAD before. From the Bricscad manual, it looks like
(while (= (setq gIn (grread 1 5 2)) 5) .....)
would allow me to display a pickbox-type cursor and continuously read the mouse coordinates (and in fence mode draw a rubber band line from the last fence point to the cursor) until there's a click or a keypress.
And when the WHILE loop ends, (cdr gIn) would be either a point or a keyboard character, depending on whether (car gIn) is 3 or 2.
Or I could run the WHILE loop until I get
(or (= car (gIn 3)) (= gIn (or (2 13) (2 116) (2 101))) )
i.e., until there's a click, Enter, T, or E.
So in addition to everything my present commands do, a command using GRREAD could accept a user's T or E to switch back and forth between trimming and extending to the same set of cutting/boundary objects. The two commands could be identical except that one starts in Trim mode and the other starts in Extend mode.
Is that right?
gskelly, when I first tried it in v8, something went wrong and I just gave up. But I tried it again after what you said and now I can't find any problem in v8.
« Reply #4 on: March 16, 2009, 12:27:53 AM »
There are many examples of grread here at the Swamp.
Take a look at this one to see how it can be used.
http://www.theswamp.org/index.php?topic=27747.0
