Author Topic: What is ArcGrid Metadata file?  (Read 5709 times)
dfarris75
« on: March 12, 2009, 01:14:02 PM »
I'm downloading data from USGS and I see 1" NED Elevation file that says ArcGrid Metadata file. I connected to it in Map and it looks like just a big hatched square. I'm not familiar with this type of data.
Please help.
Re: What is ArcGrid Metadata file?
« Reply #1 on: March 12, 2009, 01:39:32 PM »
that would be point data from which one could build a GRID surface...
IF one wanted to
dfarris75
« Reply #2 on: March 12, 2009, 01:56:25 PM »
Ooo me likes the sound of that, but... How the heck do I build a surface from points that are in a file referenced via data connect? I shall check the help file.
dfarris75
« Reply #3 on: March 12, 2009, 02:09:19 PM »
I also see these available:
       1" NED
       1/3" NED
       1/9" NED
       SRTM Finished 3 arc sec
       SRTM Finished 1 arc sec
1.) The smaller the number the more accurate right?
2.) What is SRTM Finished...?
dfarris75
« Reply #4 on: March 12, 2009, 02:27:41 PM »
Apparently the data is coming in from a different zone because when I zoom extents it goes way out, but I am unable to locate where it is. Is there a "zoom to" option somewhere that I don't see?
dfarris75
« Reply #5 on: March 12, 2009, 02:43:52 PM »
I was able to find it finally. There are several .adf files which I guess is the surface. The MetaData is seemingly just the hatched square and it falls into place, but the .adf files come in way down south for some reason. Oh I just got this message...
  WARNING: The problems below were found applying style(s) to element DataConnectSurface:
  There are no grid data in this element.
Failed to get bands data.
ReadNext must be called before fetching data.
There is no data in the extent of current map.
Coordinate transformation failed for this feature.
I guess I'm missing a step or something.
dfarris75
« Reply #6 on: March 12, 2009, 02:51:36 PM »
Here's what I see when I zoom in to it.
« Reply #7 on: March 12, 2009, 02:56:12 PM »
Create Surface change type to  (GRID)
Or one might build a TIN surface using the points in that file via Points>>Import Points
>>External Project Database...
dfarris75
« Reply #8 on: March 12, 2009, 03:24:06 PM »
It asks for a .mdb file and there isn't any of them in the dataset.
« Reply #9 on: March 12, 2009, 04:05:16 PM »
the default is .MDB however it will accept other ASCII data files...
use the files of type option...
« Reply #10 on: March 12, 2009, 04:08:52 PM »
and or you may have to perform a Query against the attached data, inserting points and then use those point objects within the terrain model...
may I see a copy of the entre data set this file is part of?
dfarris75
« Reply #11 on: March 12, 2009, 09:47:49 PM »
Sure Mike. I'll send it off to you in the am.
« Reply #12 on: March 13, 2009, 01:30:21 PM »
Go to this page: http://egsc.usgs.gov/isb/pubs/factsheets/fs14899.html
The NED will be delivered in the Spatial Data Transfer Standard (SDTS) raster profile. The spatially referenced metadata will be delivered in SDTS topological vector profile. Other formats may also be supported. An Internet browse of NED shaded-relief imagery with vector reference information will be provided as an aid to ordering. A customer can identify the requested area graphically through the Internet browser. That area of interest will be extracted from the NED and from the spatially referenced metadata and formatted for delivery. The data will be available to download from the Internet using file transfer protocol or on standard distribution media. As more information on the NED becomes available, it will be accessible through the Internet at gisdata.usgs.gov/ned.
I do not think this metadata is yet available in SDTS so one will not be able to build a surface from the NED product...at this time.
One would still want to get the DEM file...
Further in that page also states:
A. ArcGrid is an Arc/Info proprietary format. Some other software packages can read the ArcGrid format. Customers who specify ArcGrid will be delivered a workspace. The workspace is not tarred or gzipped.
Testing seems to suggest MAP does NOT support this format.
« Last Edit: March 13, 2009, 01:44:07 PM by mjfarrell »
dfarris75
« Reply #13 on: March 13, 2009, 03:21:32 PM »
Why then was I able to import it and get that green blob of topo to display; only in the wrong position within the coordinate zone?
dfarris75
« Reply #14 on: March 13, 2009, 03:28:30 PM »
I just started a new blank dwg with no coordinate system/zone applied, attached to the data, both the shape file METADATA and the Raster/Surface files (.adf files). Both attached exactly on top of one another. Yesterday when working in my dwg they came in different places. I guess I had assigned a zone somewhere.
If this data is attaching it has to be readable/importable by Map. Not sure. :|
If I understand correctly I should be able to product contours from this though.
