Author Topic: what computer are you using?  (Read 4379 times)
FengK
« on: March 11, 2009, 11:20:55 PM »
This is a question for those who are using C3D. After a couple of month of messing with C3D, we feel our computers need upgrade. This is what we have now and I'd like to know what you're using and whether you're happy with the performance. Thanks for your input!
Dinosaur
Re: what computer are you using?
« Reply #1 on: March 11, 2009, 11:25:33 PM »
What kind of hard drive?
FengK
« Reply #2 on: March 11, 2009, 11:26:27 PM »
is this a question for me?
Dinosaur
« Reply #3 on: March 11, 2009, 11:33:21 PM »
Yes . . . the wrong hard drive can really bog down an otherwise excellent system.
FengK
« Reply #4 on: March 11, 2009, 11:36:27 PM »
Thanks for pointing that out! I was never aware of that. Anyway, this is what we have. If it is not good. What do you recommend?
Dinosaur
« Reply #5 on: March 11, 2009, 11:46:15 PM »
If you are having problems, I would start looking right there.  It is all about plate density when you want to milk out every ms possible.  You can go with larger capacity, higher rpm speed, or both.  I was using 150gb 10000 rpm WD Raptors in raid 0 in my last work station with good performance.  Other good choices that have since become available are the perpendicular writing Seagates and the new 2 1/2 inch desktop drives.  Any of those will give you the higher plate densities that will clear most bottlenecks.
« Reply #6 on: March 12, 2009, 08:23:19 AM »
C3D will bring this machine to its knees. *sigh*
> Mainboard : Dell Computer Corp. 0F1262
  > Chipset : Intel E7505
  > Processor : Intel Xeon @ 3066 MHz
  > Physical Memory : 2048 MB (4 x 512 DDR-SDRAM )
  > Video Card : NVIDIA Quadro FX 3000
  > Hard Disk : SEAGATE (36 GB)
  > DVD-Rom Drive : JLMS DVD-ROM XJ-HD166
  > DVD-Rom Drive : _NEC DVD+RW ND-1100A
  > Monitor Type : Dell Computer DELL 2001FP - 20 inches
  > Monitor Type : Dell Computer DELL 2007FP - 20 inches
  > Network Card : Intel Corporation 82545EM Gigabit Ethernet Controller (Copper)
  > Operating System : Microsoft Windows XP Professional 5.01.2600 Service Pack 2
  > DirectX : Version 9.0c  (July 2007)
Dinosaur
« Reply #7 on: March 12, 2009, 08:42:28 AM »
I would imagine so . . . see my comments above regarding hard disk(s).  Capacity is only one consideration and probably the least important (although you are likely deficient there as well).  Those sizes make the drives appear dated and perhaps even 5400 rpm which would really clog Civil 3D.
« Reply #8 on: March 12, 2009, 08:55:28 AM »
Those are Cheetah 10K SCSI disks.
dfarris75
« Reply #9 on: March 12, 2009, 10:01:07 AM »
Here's what I have. Straight from the Dell Refurbished Store. :-D
DELL Precision T3400
This is the hard drive > http://www.provantage.com/western-digital-wd2500aajs~7WNDG2EQ.htm
Dinosaur
« Reply #10 on: March 12, 2009, 10:27:07 AM »
OK - They are better than what I thought but What you are seeing is why I am not a fan of SCSI any more.  The small drive capacity is likely choking your virtual memory settings.  Those are very expensive gb's of storage compared to the drives I suggested as well.  Better than the standard 7200 IDE and SATA drives, but not worth the extra expense IMO.
sinc
« Reply #11 on: March 12, 2009, 11:55:35 AM »
My new one, which runs C3D quite well:
Core i7 940 (2.93GHz, 8MB L3)
Asus P6T Deluxe MOBO
3x2GB (6GB total) Corsair PC12800 Tri-Channel DDR3, 1600MHz
2x500GB Seagate Barracuda 7200.11 in a RAID0
EVGA GeForce 9600GT - 1GB DDR3
Viewsonic VX2233WM 22" Widescreen LCD (1920x1080)
Vista Home Prem 64-bit OEM
With a case, power supply, and DVD burner, the total came to around $2200 last November.  (I ordered the parts and put it together.)  I think prices have dropped further, now.
ChristopherF
« Reply #12 on: March 12, 2009, 05:11:17 PM »
Intel Core 2 Duo CPU
E8400 @ 3.00 GHz
2.99 GHz, 2.98 GB of RAM
With a http://www.seagate.com/ww/v/index.jsp?vgnextoid=950b4d4b57cb0110VgnVCM100000f5ee0a0aRCRD&locale=en-US hard drive
It's not too bad so far, running C3D 2008
« Reply #13 on: March 12, 2009, 05:57:41 PM »
Laptop: Dell Inspiron 1720, Core2Duo T8300@2.40gHz, 4gb RAM, 240gb 2.5" 5400rpm HDD, nVidia GeForce 8600GT M 256mb video ram, Vista Ultimate 32-bit
Desktop: Intel Core2Quad Q9550@2.83gHz, 4gb RAM, Maxtor 500gb hdd @ 7200rpm, nVidia Quadro FX1500 256mb video ram, Vista Ultimate 64-bit
C3D2009 runs faster on the desktop, but is quite usable on the laptop.....my actual work time is probably split 60-40 between the 2 computers. I prefer the laptop display, just becasue it is so crisp! 1920x1200 on a 17" widescreen vs 1680x1050 on a 24"widescreen. That, and the fact I can sit in my comfy chair at home & watch some sports while I'm I'm working is another plus.
FengK
« Reply #14 on: March 13, 2009, 01:40:25 AM »
sinc, Thanks for the spec. I suppose those part come with warranty? For $2200, it seems to be quite a good investment. And it comes with 22" LCD monitor too. How long you've been using it? Is it possible to add the RAM to 8GB, like 4x2GB?
