Author Topic: Chainlink Fence Material Needed  (Read 3745 times)
deegeecees
« on: March 10, 2009, 02:05:35 PM »
Looking for something to map to a material for a chain link fence with opaque's for a render. I've looked for an hour now with no progress. Anyone?
James Cannon
Re: Chainlink Fence Material Needed
« Reply #1 on: March 10, 2009, 02:08:56 PM »
There's one that comes with autocad. What version ya using?
Attached, in case you don't have it.
default path for bump map folder (texture map one level up) :
C:\Documents and Settings\All Users\Application Data\Autodesk\AutoCAD 2009\R17.2\enu\Textures\Bump
deegeecees
« Reply #2 on: March 10, 2009, 02:23:22 PM »
D'oh! No wonder I couldn't find anything on the net.
Thanks Jimbo.
One of those days...
James Cannon
« Reply #3 on: March 10, 2009, 02:31:40 PM »
It's cool.
I still find new things in that folder... it's one huge composte pile of a million different things, and sometimes the filename name-ology doesn't mesh with what I typically think of, and I miss some things.
I just knew this one, because I had used it before.
Whenever I need a map with transperancy... I go to the transperancy map folder first... that way I only see ones that DO have transperancy, and I don't have to sift through 80 different CARPET patterns trying to find what I want in a CMU block or something..
  And I just realized I posted the bump map instead of the transparency/alpha map on accident.  ah well, you know where to find it, now, for sure.
deegeecees
« Reply #4 on: March 10, 2009, 02:58:49 PM »
I appreciate the gentle nudge.
