(defun gps->about( / str )
(setq str
"Dim oIE, doc1
Set oIE = CreateObject(\"InternetExplorer.Application\")
oIE.Navigate \"about:blank\"
oIE.Visible = 1
oIE.ToolBar = 0
oIE.StatusBar = 0
oIE.Width=750
oIE.Height=700
Do While (oIE.Busy): Loop
Set doc1 = oIE.Document
doc1.open
doc1.writeln \"<html><head><title>显示系统环境变量</title></head>\"
doc1.writeln \"<body bgcolor='silver'><pre><center><font color=red size=5>系统环境变量</font></center><p><font color=blue size=3>\"
Set wshshell = CreateObject(\"#wscript#.Shell\")
For Each EnvirSYSTEM In wshshell.Environment(\"SYSTEM\")
enOutSYSTEM=enOutSYSTEM&\"当前\"&EnvirSYSTEM&vbCrlf
Next
For Each EnvirPROCESS In wshshell.Environment(\"PROCESS\")
enOutPROCESS=enOutPROCESS&\"当前\"&EnvirPROCESS&vbCrlf
Next
For Each EnvirUSER In wshshell.Environment(\"USER\")
enOutUSER=enOutUSER&\"当前\"&EnvirUSER&vbCrlf
Next
For Each EnvirVOLATILE In wshshell.Environment(\"VOLATILE\")
enOutVOLATILE=enOutVOLATILE&\"当前\"&EnvirVOLATILE&vbCrlf
Next
doc1.writeln enOutSYSTEM&enOutPROCESS&enOutUSER&enOutVOLATILE
doc1.writeln \"</font></p></pre></body></html>\"
doc1.close
set wshshell=nothing
set oIE=nothing
(setq #wscript# (vlax-create-object "ScriptControl"))
(vlax-put #wscript# 'language "vbs")
(vlax-invoke-method #wscript# 'ExecuteStatement str)
(setq retun (vlax-invoke-method #wscript# 'eval "ret"))
