Author Topic: Thumbnail Retrieval Speed  (Read 3695 times)
frostrap
« on: March 03, 2009, 12:48:37 PM »
Hello all,
I'm using the function shown below to retrieve thumbnail images from drawings. Thanks to some help on another post, the code seems to be generally stable. Unfortunately, it can also be rather slow, especially when reteiving the thumb from large files.
Right now it seems as though the entire file is being loaded into memory, which takes a lot of time. Isn't there a method for extracting the thumbnail without having to load the entire drawing file into memory first?
Is there another method for retrieving the thumbnail image from a dwg that is not so time hungry?
Looking forward to your ideas,
Joe
Public Function DrawThumbnail(ByVal DWGPath As String, ByVal PictureBoxWidth As Integer, ByVal PictureBoxHeight As Integer, _
                                      Optional ByVal InvertThumbs As Boolean = False) As Bitmap
            Dim mytransman As DatabaseServices.TransactionManager
            Dim myTrans As DatabaseServices.Transaction
            Dim myDB As DatabaseServices.Database
            myDB = New Autodesk.AutoCAD.DatabaseServices.Database(False, True)
            mytransman = myDB.TransactionManager
            myTrans = mytransman.StartTransaction
            Try
                myDB.ReadDwgFile(DWGPath, IO.FileShare.ReadWrite, True, "")
                'check to make sure the file has a thumbnail. If it doesn't, return a placeholder image.
                If IsNothing(myDB.ThumbnailBitmap) Then
                    Dim theThumb As New Bitmap(PictureBoxWidth, PictureBoxHeight)
                    Dim gr As Graphics = Graphics.FromImage(theThumb)
                    gr.CompositingQuality = Drawing2D.CompositingQuality.HighQuality
                    gr.DrawString("N/A", New Font("Verdana", 12, FontStyle.Regular), New SolidBrush(Color.Red), 15, 10)
                    gr.Dispose()
                    Return theThumb
                End If
                'if we're here, the dwg has a preview thumbnail
                ' Set the scale factor.
                Dim WidthScale As Single = PictureBoxWidth / myDB.ThumbnailBitmap.Width()
                Dim HeightScale As Single = PictureBoxHeight / myDB.ThumbnailBitmap.Height()
                Dim theScale As Single = WidthScale
                If WidthScale > HeightScale Then
                    theScale = HeightScale
                End If
                ' Get the source bitmap.
                Dim bm_source As New Bitmap(myDB.ThumbnailBitmap)
                ' Make a bitmap for the result.
                Dim bm_dest As New Bitmap( _
                    CInt(bm_source.Width * theScale), _
                    CInt(bm_source.Height * theScale))
                ' Make a Graphics object for the result Bitmap.
                Dim gr_dest As Graphics = Graphics.FromImage(bm_dest)
                gr_dest.SmoothingMode = Drawing2D.SmoothingMode.AntiAlias
                gr_dest.CompositingQuality = Drawing2D.CompositingQuality.HighQuality
                gr_dest.InterpolationMode = Drawing2D.InterpolationMode.HighQualityBilinear
                ' Copy the source image into the destination bitmap.
                gr_dest.DrawImage(bm_source, 0, 0, bm_dest.Width + 1, bm_dest.Height + 1)
                If InvertThumbs Then
                    Dim X As Integer
                    Dim Y As Integer
                    Dim r As Integer
                    Dim g As Integer
                    Dim b As Integer
                    For X = 0 To bm_dest.Width - 1
                        For Y = 0 To bm_dest.Height - 1
                            r = 255 - bm_dest.GetPixel(X, Y).R
                            g = 255 - bm_dest.GetPixel(X, Y).G
                            b = 255 - bm_dest.GetPixel(X, Y).B
                            bm_dest.SetPixel(X, Y, Color.FromArgb(r, g, b))
                        Next Y
                    Next X
                End If
                'Return the result.
                Return bm_dest
                'commit the transaction
                myTrans.Commit()
                'clean up the graphics resources
                gr_dest.Dispose()
                bm_dest.Dispose()
                bm_source.Dispose()
            Catch ex As Exception
                MsgBox(ex.Message & ControlChars.CrLf & ex.StackTrace)
                Return Nothing
            Finally
                myTrans.Dispose()
                myDB.Dispose()
            End Try
        End Function
KewlToyZ
Re: Thumbnail Retrieval Speed
« Reply #1 on: March 03, 2009, 03:00:45 PM »
Just a guess, what about the Windows Explorer thumbs.db?
Thmubnails are viewable in Explorer....
mohnston
  • CAD Programmer
« Reply #2 on: March 03, 2009, 05:50:55 PM »
I've tried several dwg thumbnail/preview options.
My home-grown control did fine until drawing file format changed in 2007. Then it slowed way down. Who knows what will work with the new 2010 file format.
I ended up using DWGTHUMBNAILLib from Autodesk.
CAD Programming Solutions
ben.smuda
« Reply #3 on: March 03, 2009, 10:07:15 PM »
You can't count on Thumbs.db being there for you.  The file is only generated on demand (when Thumbnail or Filmstrip view is used on the folder in Explorer) and is easily deleted.  Somewhere in that process, AcThumbnail16.dll is involved.  It's a shell extension for the DWG file type.
I'm pretty sure, though, that DWGPROPS are stored in a separate stream on the DWG file (ie. Structured Storage).  I wonder if the Thumbnail is stored similarly or in the same stream?  Would make sense, but I'm now in way over my head.
wannabe
« Reply #4 on: March 09, 2009, 03:57:27 PM »
I can't offer the slightest bit of advice.....sorry.
However, I am feeling nosey and would like to know exactly, or in general, what your program needs these for and ultimately what it does?
Cheers.
TonyT
« Reply #5 on: March 09, 2009, 04:34:26 PM »
DWGPROPS in 2007 or later are stored as header variables
(e.g., system variables that are saved with the dwg file).
There's no OLE Structured Storage stream.
ben.smuda
« Reply #6 on: March 13, 2009, 04:21:32 PM »
Thanks for the update, Tony.  I skipped from 2005 to 2009.  Missed the change, I guess.
[/quote]
[/quote]
KewlToyZ
« Reply #7 on: March 18, 2009, 01:10:03 PM »
The option to place it into the header of the file can be turned off in the Options of AutoCAD also.
pb.Perksa
« Reply #8 on: March 22, 2009, 08:07:54 PM »
I've shown a way that this can be done very very quickly in this thread...
http://www.theswamp.org/index.php?topic=26621.0;all
I've written applications in this method that create libraries of bitmaps retrieved from drawings on-the-fly.
