Author Topic: Entmake Insert + attrib  (Read 8692 times)
TimSpangler
  • CAD Naked!!
« on: February 26, 2009, 03:27:04 PM »
Driving me crazy.
I have created a block using entmake including attrdef's but when I try to create the insert based on that block with attrib's I get unexpected results.
Am I doing something wrong?
ACA 2015 - Windows 7 Pro
Re: Entmake Insert + attrib
« Reply #1 on: February 26, 2009, 03:29:57 PM »
Hard to tell without code.   :wink:
Here is how I add extra attributes to blocks, which recreates the insert and all attributes, so I think it will show you a way to do it.
[ http://www.theswamp.org/index.php?topic=8037.0 ]
TimSpangler
  • CAD Naked!!
« Reply #2 on: February 26, 2009, 03:34:01 PM »
Sorry 'bout that:
(defun FRAM_BUBBLE (/)
;; Create framing marker block
;; Check for the block if it is not there, create it
(if (not (tblsearch "block" "ID1"))
(entmake
(list
(cons 0 "BLOCK")
(cons 2 "ID1")
(cons 4 "Framing ID marker")
(cons 70  2)
(cons 10 (list 0.0 0.0 0.0))
(cons 8  "11T")
;; STDLIB_LAKEPLINE <POINTLIST> <LAYER> <LINETYPE> <COLOR> <CLOSE>
(STDLIB_MAKECIRC (list 0.0 0.0 0.0) 7.0 "11T" "Continuous")
(entmake
(list
(cons 0 "ATTDEF") ;; Entity type
(cons 1 "") ;; Attrib Value
(cons 2 "RTAG1") ;; Attrib Tag
(cons 3 "ID") ;; Attrib Prompt
(cons 7 "1T14") ;; Textstyle
(cons 8 "11T") ;; Layer
(cons 10 (list 0 0 0)) ;; First alignment point
(cons 11 (list 0 0 0)) ;; Second alignment point
(cons 40 4.0) ;; Text height
(cons 70 2) ;; Attribute flags
(cons 71 0) ;; Text generation flags
(cons 72 1) ;; Horizontal text justification type
(cons 74 2) ;; Vertical text justification type
(entmake
(list
(cons 0 "ENDBLK")
^^ Code to create the block
(defun FRAM_INSERT_BUBBLE (InsPoint Value /)
;; Insert block framing marker
(entmake
(list
(cons 0 "INSERT") ;; Entity type
(cons 2 "ID1")
(cons 8 "0")
(cons 10 InsPoint)
(cons 50 0.0)
(cons 70 0)
(cons 66 1) ;; Attribute follow
(entmake
(list
(cons 0 "ATTRIB") ;; Entity type
(cons 1 Value) ;; Attrib Value
(cons 10 InsPoint) ;; First alignment point
(cons 11 InsPoint) ;; Second alignment point
(cons 40 4.0) ; Text height
(cons 70 0) ;; Attribute flags: 8
(entmake
(list
(cons 0 "SEQEND") ;; Entity type
(cons 8 "0") ;; Layer
^^Code to create the insert
Everything works except when i try to edit the insert there is no "Prompt"
Why?  What am I doing wrong
« Reply #3 on: February 26, 2009, 04:16:03 PM »
I don't know how the command knows about the prompt, as I haven't figured that part out yet.  Maybe someone will be able to chime in, and enlighten us both.  Sorry Tim.
TimSpangler
  • CAD Naked!!
« Reply #4 on: February 26, 2009, 04:49:44 PM »
Worst part is that if the block is already in the dwg (from the library) everything works as expected...
Hope someone can shed some light on this for me. (us)
« Reply #5 on: February 26, 2009, 04:58:32 PM »
My guess is that your code that defines the block def fails to make the attdef, tho it does succeed at making the block def.
While your call to make the insert, c/w attribute succeeds, there is no corresponding attdef entry in the block definition, so it cannot find the associated prompt.
gile
  • Marseille, France
« Reply #6 on: February 26, 2009, 05:37:27 PM »
In the attdef entmake, change (cons 70 2) -constant attribute- to (cons 70 8 ) -predefined attribute-
« Last Edit: February 27, 2009, 08:50:13 AM by CAB »
kdub_nz
  • Mesozoic keyThumper
  • SuperMod
« Reply #7 on: February 26, 2009, 06:55:16 PM »
Just a general note about comments ...
Tim, If you had made the comments for the 70,71, 72, 74 keys explicit the 'error' may have become apparent.  :-)
Called Kerry in my other life
I live at UTC + 13.00
TimSpangler
  • CAD Naked!!
« Reply #8 on: February 27, 2009, 07:30:50 AM »
That did the trick....Thanks
« Last Edit: February 27, 2009, 08:50:28 AM by CAB »
